Old 24th September 2012, 04:58   #15841  |  Link
AmigaFuture
AmigaFuture's Avatar
I've never had any issues with Toy Story. "Toy Story 3" however is a different matter and was a catalyst for several changes to BD-RB's handling of multipart sources.
Has BD-RB 42.03 been part of your recent tests with Toy Story; and have you checked the times I typed? Thank You.
Old 24th September 2012, 08:10   #15842  |  Link
JoeH
Originally Posted by JoeH View Post
Upon converting the original Blu-ray of "For Greater Glory" to DVD-5, some of the Spanish subtitles were invisible... maybe most of them. Others appear (maybe the shorter ones?). http://www.walmart.com/ip/21553994?findingMethod=rr
Unfortunately I deleted the conversion log, but it didn't report any errors. I can redo it if you need it. Here is a link to the subtitle file on SkyDrive. Let me know when you have it so I can delete it: http://sdrv.ms/SbcxJk
Edit: The conversion was done using v 0.41.01
Bump.
JoeH is offline   Reply With Quote
Old 24th September 2012, 12:54   #15843  |  Link
Originally Posted by SquallMX View Post
Interlaced VC-1 is rare nowadays and LAVF is very useful if for some reason you canīt use the recommended FFDShow build, please continue supporting LAVF .
Not as rare as you think. You just don't see it because BD-RB automatically adjusts and uses DirectShow.
Old 24th September 2012, 12:58   #15844  |  Link
Bump.
Unfortunately with no log and no intermediate files to examine etc... I'm not sure of anything I can do to help unless I go out and buy it. And frankly, I'm not getting enough donations to cover the cost of the discs I've already bought -- let alone my time. It's all I can do to convince myself to spend my spare time on BD-RB. If it wasn't for "pride" I would have let this project go a long time ago.
Old 24th September 2012, 14:45   #15845  |  Link
JoeH
Totally understand, I just wanted to make sure you didn't miss it. I mentioned I would be glad to redo the log if you need to - just confirm (if what I say now doesn't clear it up). I posted the subtitle file. Is that not enough? Or would it be more helpful for me to cut a minute from a part of the video where it doesn't work and then post that, with video and subtitles?
I thought you were planning on charging for BD-RB eventually??
Old 25th September 2012, 01:13   #15846  |  Link
AmigaFuture
Toy Story as MKV Audio Intact
Hi. I thought since rerendering is producing choppy effects I'd have BD-RB do an MKV output.
[09/24/12] BD Rebuilder v0.42.03 (beta)
[14:45:29] Source:  TOY_STORY_PLAYLIST_00150
  - Input BD size: 19.48 GB
  - Approximate total content: [01:21:04.901]
  - Windows Version: 6.1 [7601]
  - Mode: MKV Container, 1920x1080, Intact Audio
  - Decoding/Frame serving: DirectShow [4-way]
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448
[14:45:31] PHASE ONE, Encoding
 - [14:45:31] Processing: VID_00066 (1 of 11)
 - [14:45:31] Extracting A/V streams [VID_00066]
 - [14:50:54] Reencoding video [VID_00066]
   - Rate/Length: 23.976fps, 2,931 frames
   - Bitrate: 14,775 Kbs
 - [14:50:54] Reencoding: VID_00066, Pass 1 of 2
 - [14:51:30] Reencoding: VID_00066, Pass 2 of 2
 - [14:52:06] Video Encode complete
 - [14:52:06] Processing audio tracks
 - [14:52:06] Processing: VID_00405 (2 of 11)
 - [14:52:06] Extracting A/V streams [VID_00405]
 - [14:52:18] Reencoding video [VID_00405]
   - Rate/Length: 23.976fps, 3,219 frames
   - Bitrate: 12,841 Kbs
 - [14:52:18] Reencoding: VID_00405, Pass 1 of 2
 - [14:52:54] Reencoding: VID_00405, Pass 2 of 2
 - [14:53:30] Video Encode complete
 - [14:53:30] Processing: VID_00401 (3 of 11)
 - [14:53:30] Extracting A/V streams [VID_00401]
 - [14:54:25] Reencoding video [VID_00401]
   - Rate/Length: 23.976fps, 18,967 frames
   - Bitrate: 12,764 Kbs
 - [14:54:25] Reencoding: VID_00401, Pass 1 of 2
 - [14:58:09] Reencoding: VID_00401, Pass 2 of 2
 - [15:02:34] Video Encode complete
 - [15:02:34] Processing: VID_00406 (4 of 11)
 - [15:02:34] Extracting A/V streams [VID_00406]
 - [15:02:39] Reencoding video [VID_00406]
   - Rate/Length: 23.976fps, 491 frames
   - Bitrate: 12,722 Kbs
 - [15:02:39] Reencoding: VID_00406, Pass 1 of 2
 - [15:02:46] Reencoding: VID_00406, Pass 2 of 2
 - [15:02:52] Video Encode complete
 - [15:02:52] Processing: VID_00402 (5 of 11)
 - [15:02:52] Extracting A/V streams [VID_00402]
 - [15:03:34] Reencoding video [VID_00402]
   - Rate/Length: 23.976fps, 12,673 frames
   - Bitrate: 12,790 Kbs
 - [15:03:34] Reencoding: VID_00402, Pass 1 of 2
 - [15:06:05] Reencoding: VID_00402, Pass 2 of 2
 - [15:08:59] Video Encode complete
 - [15:08:59] Processing: VID_00407 (6 of 11)
 - [15:08:59] Extracting A/V streams [VID_00407]
 - [15:09:05] Reencoding video [VID_00407]
   - Rate/Length: 23.976fps, 452 frames
   - Bitrate: 12,666 Kbs
 - [15:09:05] Reencoding: VID_00407, Pass 1 of 2
 - [15:09:11] Reencoding: VID_00407, Pass 2 of 2
 - [15:09:17] Video Encode complete
 - [15:09:17] Processing: VID_00403 (7 of 11)
 - [15:09:17] Extracting A/V streams [VID_00403]
 - [15:10:20] Reencoding video [VID_00403]
   - Rate/Length: 23.976fps, 28,247 frames
   - Bitrate: 12,879 Kbs
 - [15:10:20] Reencoding: VID_00403, Pass 1 of 2
 - [15:17:44] Reencoding: VID_00403, Pass 2 of 2
 - [15:24:24] Video Encode complete
 - [15:24:24] Processing: VID_00408 (8 of 11)
 - [15:24:24] Extracting A/V streams [VID_00408]
 - [15:24:30] Reencoding video [VID_00408]
   - Rate/Length: 23.976fps, 1,218 frames
   - Bitrate: 13,099 Kbs
 - [15:24:30] Reencoding: VID_00408, Pass 1 of 2
 - [15:24:45] Reencoding: VID_00408, Pass 2 of 2
 - [15:25:02] Video Encode complete
 - [15:25:02] Processing: VID_00404 (9 of 11)
 - [15:25:02] Extracting A/V streams [VID_00404]
 - [15:26:32] Reencoding video [VID_00404]
   - Rate/Length: 23.976fps, 42,735 frames
   - Bitrate: 12,753 Kbs
 - [15:26:32] Reencoding: VID_00404, Pass 1 of 2
 - [15:37:44] Reencoding: VID_00404, Pass 2 of 2
 - [15:47:38] Video Encode complete
 - [15:47:38] Processing: VID_00409 (10 of 11)
 - [15:47:38] Extracting A/V streams [VID_00409]
 - [15:47:56] Reencoding video [VID_00409]
   - Rate/Length: 23.976fps, 5,107 frames
   - Bitrate: 12,733 Kbs
 - [15:47:56] Reencoding: VID_00409, Pass 1 of 2
 - [15:48:46] Reencoding: VID_00409, Pass 2 of 2
 - [15:49:39] Video Encode complete
 - [15:49:39] Processing: VID_00410 (11 of 11)
 - [15:49:39] Extracting A/V streams [VID_00410]
 - [15:49:45] Reencoding video [VID_00410]
   - Rate/Length: 23.976fps, 601 frames
   - Bitrate: 15,156 Kbs
 - [15:49:45] Reencoding: VID_00410, Pass 1 of 2
 - [15:49:52] Reencoding: VID_00410, Pass 2 of 2
 - [15:50:01] Video Encode complete
[15:50:01]PHASE ONE complete
[15:50:01]PHASE TWO - Rebuild Started
 - [15:50:01] Building ALTERNATE OUTPUT Structure
 - ERROR in attempt to mux (MKVMERGE)
[15:52:52] - Failed to REBUILD
My HDD has 53GB free, so plenty of space where the Working directory is.
Old 25th September 2012, 01:49   #15847  |  Link
RobertM
53GB is NOT plenty. During the rebuilding process there will be more than 1 copy in existence on your HDD; the original, the extract files, the re-encode, and the rebuild. The intermediate steps (extract and re-encode) are usually deleted after the subsequent step, but you do need extra HDD space for the interim processes.
Old 25th September 2012, 03:46   #15848  |  Link
wakko709
[18:58:33] Source: JOHN_CARTER
- Input BD size: 43.91 GB
- Approximate total content: [03:32:33.240]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7600]
[18:58:35] PHASE ONE, Encoding
- [18:58:35] Processing: VID_00252 (1 of 31)
- [18:58:35] Extracting A/V streams [VID_00252]
- Error in attempt to extract audio/subs.
- Can't create output file E:\WORKFILES\00252.track_4113.264
[18:58:40] - Failed to retrieve audio, aborted
plus ive installed all the latest software
wakko709 is offline   Reply With Quote
Old 25th September 2012, 04:19   #15849  |  Link
setarip_old
setarip_old's Avatar
@wakko79
Hi!
You MUST install the SPECIFIC software and software versions that are listed in Post #1 of this thread.
Old 25th September 2012, 04:46   #15850  |  Link
wakko709
@wakko79
Hi! You MUST install the SPECIFIC software and software versions that are listed in Post #1 of this thread.
ive installed the versions recomended!
Old 25th September 2012, 04:48   #15851  |  Link
wakko709
- FFDSHOW: [3882], Ok
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW MPEG2 set incorrectly: [0]
- AnyDVD settings check: Ok.
- BD Rebuilder v0.42.0.3, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 25th September 2012, 06:45   #15852  |  Link
AmigaFuture
Hi. I get the structure of the NT FileSystem (NTFS) and it'll show as 0 or something resembling that if there isn't any "Storage Space" free somewhere in the process. I appreciate your analysis, thank You.
53GB wasn't the start of the amount, that's the left over free space. At the start it was about twice that.
Old 25th September 2012, 10:02   #15853  |  Link
Wizzu
Why in the world would you add that character to a pathname anyway?
This question is entirely irrelevant (a little as if you were asking about the color of one's underwear ) but since you ask I'll reply anyway.
Many power users use such special characters to get a coherent folder structure that doesn't rely on mere alphabetical sorting. They are very useful, for instance, to create visual groups of folders in the explorer.
Anyway, these characters exist, using them is entirely legitimate whatever the reason to do so. They should, as such, be taken in consideration by programmers.
Don't take me wrong: I'm not complaining at all, since rebuilder is free, is very helpful to me and you're definitly doing a great job. Besides, I'm not even sure that the problem doesn't lie with AFTEN rather than with your work.
I simply created a root folder entirely dedicated to BDRB output, really no big deal to break my habits for a free program that does so much right.
I think it's nonetheless important that you are aware of the glitch caused by this. Now what you do with the info is entirely up to you.
Wizzu is offline   Reply With Quote
Old 25th September 2012, 10:30   #15854  |  Link
Groucho2004
It is a valid character for file/path names but remember that its value is outside of the US-ASCII range (00h - 7Fh). So, if you cut and paste something (a command line with notepad for example), the necessary ANSI-OEM conversion does not take place. Aften has no problem with this character by the way.
I also use special characters to get file/folder sorting to my liking but I stick to characters in the ASCII range, like "_", "#", "$", etc.
Groucho's Avisynth Stuff
Old 25th September 2012, 12:08   #15855  |  Link
Wizzu
Thanks for the info.
I had no idea that "§ " was outside the range, unlike "$" and "#"... learning something everyday.
Old 25th September 2012, 14:55   #15856  |  Link
Wizzu
And while at it I just made a second donation.
I'm encouraging all BDRB users to donate BTW.
Old 25th September 2012, 16:41   #15857  |  Link
wakko709
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
i know win 7 isnt set correcily how do i change it?
Old 25th September 2012, 17:10   #15858  |  Link
sytyguy
After the install of FFDSHOW , run "Video Decoder Configuration" for FFDSHOW from the "START/Programs" menu, and make sure MPEG2 decoding is enabled. Do the same using "Audio Decoder Configuration" to ensure "Uncompressed" is set to "All Supported". See if that helps.
BTW, this is on the first page of this thread.
sytyguy is offline   Reply With Quote
Old 25th September 2012, 17:17   #15859  |  Link
Wizzu
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
From the configuration instructions in the first post:
- run "Video Decoder Configuration" for FFDSHOW from the "START/Programs" menu, and make sure MPEG2 decoding is enabled.
- Do the same using "Audio Decoder Configuration" to ensure "Uncompressed" is set to "All Supported".
Did you do that?
*EDIT* Didn't notice that sytyguy beat me to it
Old 25th September 2012, 20:36   #15860  |  Link
Ch3vr0n
on W7 you need to run the bdrb.exe with admin rights the first time (or atleast once) so that it can correctly set the codecs if it doesnt work completely via the instructions in the first post
