27th March 2011, 03:18 | #7041 | Link | ||
Oh, the time entry for the poster sucks. It takes "1:46.028" and turns it into 00:00:28.000. That isn't what I entered. I had to enter "00:01:46.028" for it to take the value and get it right. |
27th March 2011, 03:50 | #7042 | Link |
Creating my own poster images works with menu preview. Interesting that the title menu background image can be JPG or BMP, but the poster image can only be JPG.
Since I have 7 audio tracks, I turned on audio and subtitles. When I do a preview, it lists all of the tracks as being "Other (DD)". Kinda makes sense, because they are all UND. What I need to do is manually change the audio description to describe what they really are, and no, it isn't English for one, Spanish for another. etc., They are way different than that, i,e., special use audio tracks. But, I can't find anyplace in which to manually enter descriptions for each of the tracks and I am beginning to believe that I can't. If that is the case, I'll turn this off and let the user select the audio track via the remote and have a description of the audio tracks on the case artwork (which is what I was going to do anyway). |
27th March 2011, 04:48 | #7043 | Link | |
There is an option that needs to be set before auto-loading will take place. In the lower-right corner of the author tab is the list of what will be auto-loaded, IFF the option is selected. It seems that the default is no auto-loading. |
27th March 2011, 05:31 | #7044 | Link |
Test Run Using PowerDVD10 Failed
Even though I have to change the background image, as I can't find a way to move the slide menu images farther down the display, I thought I would create a test run and use PowerDVD10 to play the BDMV directory in the structure that was created.
No go. The files are there, but clicking on Play results in no play. The Play button just returns to its active, i.e., press me, mode. Has anyone ever gotten PowerDVD10 to play the output from mAVCHD after having it create a Blu-ray disc layout? |
27th March 2011, 07:45 | #7045 | Link |
@MrVideo
Please be good enough to not "step on" my posts specifically directed to "thunderclap" (The first part of your post #7037 in this thread), as there is a purpose to the question I've asked of "thunderclap"... |
27th March 2011, 07:58 | #7046 | Link | |
@MrVideo
27th March 2011, 16:52 | #7047 | Link | |
I don't use PowerDVD, but instead use TMT3. Even though multiAVCHD does not show the menu previews in "real time" exactly as they would appear after creation, I have found that after creation they are what I was hoping and/or expecting! TMT3 allows testing from folders without the need to create an image first, which does help me "view" before burning to disc. |
27th March 2011, 21:30 | #7048 | Link | |
I see the you, or the OP, have not commented about the option I noticed that probably needs to be set for auto-loading of audio files to happen. |
27th March 2011, 21:40 | #7049 | Link | |
That said, I asked because in another directory I had the contents of a third-party's AVCHD disc (not from a camcorder, an authored disc) and PowerDVD10 had no problem reading that folder and displaying the main menu. I do have DVD-RW media and will be doing some testing of the "classic" menu option that is there with some short selections. I was in a rush to get this particular project done today, and did manage to get it done. I coasterized a free piece of media that came with a new BD burner. What I got completed isn't "perfect" as the slide menu has a horrible transition from one title to another in the main menu. The screen goes black before it finally reloads with the newly selected title. But, for now it will work. |
27th March 2011, 21:56 | #7050 | Link | ||
As noted though, I did get the project mostly done. I will be doing some testing with other, smaller files on DVD, so that I can see how that goes. |
28th March 2011, 07:16 | #7052 | Link |
As indicated, I'll be using DVD-RW, as my Blu-ray player will play BD content on a DVD. One doesn't need a full BD disc in order to do testing. Just a few shorter pieces of video/audio material that will fit on a DVD will work out fine.
28th March 2011, 17:45 | #7053 | Link | ||
@MrVideo
Please clarify: First you say Quote:
Bye... |
6th April 2011, 00:48 | #7054 | Link |
@setarip_old
At the time of all the queries, the project I was working on had full length videos that would only fit on a BD. It was impossible to do DVD-RW with the material that I had. Now that it is pretty much done (I might go back a revisit), I can create real short video pieces in which to do testing on a DVD-RW. |
6th April 2011, 04:03 | #7055 | Link |
Quick Question
Just found Adbuvideo video tutorial for this great software! This looks like its custom made for all my needs!
Okay on to my question. I don't use Anydvd, I use dvdfab, and I want to convert a my blu ray movie to a sd dvd, is there a way to use the iso image I create with dvdfab to create the dvd or do I need to re-rip it in standard format? |
6th April 2011, 04:37 | #7056 | Link |
I am not certain about multiAVCHD, but this conversion to DVD will be a movie only, no menus. If you mount the image, then you should be able to direct to the appropriate m2ts or mpls to be converted.
A simple alternative method, with selectable dvd5 or dvd9 output, is BD-RB. |
