Old 25th May 2020, 18:47   #6901  |  Link
jlw_4049
Originally Posted by Zathor View Post
Please create a SF bug report incl. your log file. I would like to follow-up as this does work for me (and if the redist is missing it should copy it).
I can re-create it via megui and outside of megui with MP4Box. Same error on this version.
Here is the log with out the fix I did.
https://pastebin.com/KHaiZ5ZU
Sent from my SM-G986U1 using Tapatalk
Old 26th May 2020, 14:27   #6902  |  Link
leon
It seems 64bit version of "msvcr100.dll" is needed:
https://www.microsoft.com/en-us/down....aspx?id=14632
"redist-5-64" wasn't downloaded at all in my case.
leon is offline   Reply With Quote
Old 28th May 2020, 18:37   #6903  |  Link
Glarioo
2919 [Main]                 improved error handling when copying the redist files
2918 [Profile Selector]     fixed new profile not available immediately. Bug #953
2917 [L-SMASH Indexer]      always show source and cachefile (if available)
2916 [FFmpeg AAC Encoder]   fixed quality mode using the wrong number format (regression of 2904)
2915 [L-SMASH Indexer]      added support for recent versions
                            enabled VC-1 decoding support
                            enabled custom index file locations
2914 [Audio Encoder]        improved error handling
Thank you, Zathor.
Old 31st May 2020, 19:28   #6904  |  Link
Gser
Originally Posted by magnetite View Post
Avisynth+ 3.6.0 is out. MeGUI crashes when it's installed.
Can confirm that it crashes and I have set MeGUI to use the system Avisynth version and cannot get into MeGUI to change it.
Gser is offline   Reply With Quote
Old 17th June 2020, 03:32   #6905  |  Link
kedautinh12
FFMPEG released 4.3
Old 20th June 2020, 22:07   #6906  |  Link
locotus
After last update 2924, when opening an audio through audio enconding
section, start the job at the moment of hitting Queue and get loose aborting.
locotus is offline   Reply With Quote
Old 5th July 2020, 14:09   #6907  |  Link
kedautinh12
New D2VSource, can megui's author replaced dgindex with it??
Edit:
Link https://github.com/Asd-g/MPEG2DecPlus
Old 6th July 2020, 18:03   #6908  |  Link
leon
Updated MP4Box 1.0 is missing a dll:
Old 6th July 2020, 20:28   #6909  |  Link
jlw_4049
Yes it is. Happened to me as well
Old 7th July 2020, 12:25   #6910  |  Link
wthreex
Same here:
[Error] [7/7/2020 3:53:56 PM] Process exits with error: 0xC0000135 STATUS_DLL_NOT_FOUND (-1073741515)
wthreex is offline   Reply With Quote
Old 7th July 2020, 17:19   #6911  |  Link
tebasuna51
tebasuna51's Avatar
Seems the MPbox package is incomplete, until a new version in MeGUI server you can download MP4Box 1.0.0 Windows 64-bit from https://www.videohelp.com/software/MP4Box, if your SO is 64 bits (if not the Download MP4Box 1.0.0 Windows version)
and extract some dll's to the ...\Megui\tools\mp4box or/and ...\Megui64\tools\mp4box
I can do the mux with at least these dll's:
avcodec-58.dll
avdevice-58.dll
avfilter-7.dll
avformat-58.dll
avutil-56.dll
OpenSVCDecoder.dll
postproc-55.dll
swresample-3.dll
swscale-5.dll
Old 10th July 2020, 09:45   #6912  |  Link
wthreex
Please add ability to use regex in replacement panel :
Old 14th July 2020, 12:43   #6913  |  Link
Script generator for audio upmix using SuperEQ:
AviSynth+ does not implicitly convert any other sample format to float samples, so a ConvertAudioToFloat() should be added after opening the audio source and before using SuperEQ calls.
Old 15th July 2020, 14:15   #6914  |  Link
Seems the MPbox package is incomplete...
I tried to build MP4Box in MABS. That worked, in general ... and then I discovered a mess: The help output is sent partially to stdout as well as stderr. Would not be surprised if there is more nonsense under the pressure of releasing a v1.0.0
MP4Box - GPAC version 1.0.0-rev115-g502bae149-ab-suite
(c) 2000-2020 Telecom Paris distributed under LGPL v2.1+ - http://gpac.io
GPAC Configuration: --prefix=/local64 --disable-shared --enable-static --static-mp4box
Features: GPAC_CONFIG_WIN32 GPAC_64_BITS GPAC_MINIMAL_ODF GPAC_HAS_QJS  GPAC_DISABLE_3D
MP4Box 1.0.0-rev115-g502bae149-ab-suite
Old 31st July 2020, 08:02   #6915  |  Link
kalehrl
Can somebody update tools in MeGUI?
There are new x264, x265, lsmash, mkvmerge, qaac, ffmpeg...
kalehrl is offline   Reply With Quote
Old 11th August 2020, 14:07   #6916  |  Link
Zetti
MediaInfo v20.08 is released.
Old 11th August 2020, 20:13   #6917  |  Link
Morku
And AvisynthWrapper for AviSynth 3.6.1.0 to make cutting video possible without getting a black frame.
MeGUI deserve much more love
Morku is offline   Reply With Quote
Old 19th August 2020, 01:17   #6918  |  Link
kedautinh12
https://forum.doom9.org/showthread.p...17#post1913117
Old 21st August 2020, 20:38   #6919  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Oops, wrong thread
LouieChuckyMerry is offline   Reply With Quote
Old 29th September 2020, 06:28   #6920  |  Link
kedautinh12
MP4Box 1.0.0 rev236
http://www.mediafire.com/file/8ki8dm...GCC102.7z/file
