14th August 2019, 23:47 | #841 | Link | |
結城有紀
It's as simple as removing lines containing Type=1 or Channel. You can use sed to manipulate the file.
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 14th August 2019 at 23:54. |
15th August 2019, 12:51 | #842 | Link | |
Nevertheless It is still too much for me. (4s extra delay on LAN100). Additionally to your 'hack' I decided to keep that index file in compressed form (LZMA-normal) for encoding server app. So instead of using index file directly now server has to first decompress index file to some temp folder.
17th August 2019, 15:52 | #843 | Link | |
Now only one thing is missing. Compression of index file like in FFMS2 index file. Thank you.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th August 2019 at 16:11. |
17th August 2019, 17:40 | #844 | Link |
@HolyWu
Very exciting improvements. I'm sure it's not only GUI authors that have been waiting for this long time.
17th August 2019, 17:45 | #845 | Link | |
Would it be possible to add a gpu parameter? I saw that there is a supported HW decoders list, so maybe just a cuvid_gpu/qsv_gpu = true/false parameter could be added to avoid nvidia intel gpu detection? It should then set the hevc, h264, mjpeg, etc. decoder accordingly.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 17th August 2019 at 17:47. |
17th August 2019, 18:13 | #846 | Link |
Ok. No problem.
18th August 2019, 04:31 | #848 | Link |
HolyWu, why not use github?
and the changes you made has no public source code?
See My Avisynth Stuff |
18th August 2019, 10:44 | #849 | Link |
Thanks for your builds.
A while ago, i used to make builds using the method described here (with VS 2015 at the time) : https://github.com/BrunoReX/build-sc...MASH/readme.md Unfortunately, one day, the part with VS201x x86 Native Tools Command Prompt suddenly stoped working. Didn't know if it was something in msys2 or VS which has changed. A little question : Your release said r935+31, and your link showes 6 patches, when, i was expected 31. The only source i know is this one : https://github.com/VFR-maniac/L-SMASH-Works/branches Is there another one ?
My github. |
18th August 2019, 13:35 | #850 | Link |
There are also https://github.com/HomeOfAviSynthPlu.../L-SMASH-Works
18th August 2019, 21:19 | #851 | Link | ||
19th August 2019, 02:14 | #852 | Link |
結城有紀
Since Holy released all the patches, I'll (after a vacation unfortunately) try to integrate them into the repo.
Lots of works are piled up on me, so please be patient. (Also there's work to do on f3kdb and minideen etc.) |
19th August 2019, 19:29 | #853 | Link | |
It is annoying that lsmash now always re-indexes file which was just copied. original video=LWLibavVideoSource("original_video.MP4",cachefile="C:\index.lwi") Copy video=LWLibavVideoSource("C:\copy_of_original_video.MP4",cachefile="C:\index.lwi") The same file but with different modification time. For example FFMS2 does not care about "Last modification time". I think it only checks file size.
19th August 2019, 22:42 | #854 | Link |
結城有紀
Atak,
Although I agree there's other ways of doing the check, I don't think Windows file copy actually changes the mtime. If you use cp, you can use --preserve=timestamps. I might want to change it to some quick partial checksum if mtime mismatches. |
19th August 2019, 23:18 | #855 | Link |
The issue is that i AM copying files using my own custom code (streams and no win api). In this case last modification date is different. I think that Simple check for file size is enough.
20th August 2019, 09:31 | #856 | Link |
@HolyWu
Tried to redownload your build from the mediafire link. "Download not available".... Thanks for your efforts! Aaah, I just saw it is working again, maybe a mediafire hiccup ;-) Last edited by Taurus; 20th August 2019 at 09:43. Reason: Working again.. |
20th August 2019, 11:54 | #857 | Link | |
20th August 2019, 16:36 | #858 | Link |
As isaid, i used to make builds using the method described here (with VS 2015 at the time) : https://github.com/BrunoReX/build-sc...MASH/readme.md
I've been able to find out the main issue, it's probably a change in msys2 behavior, which doesn't keep the %PATH% by default. I fixed it, make all the gcc builds, but when compiling the VS project, i have the following error : LINK : fatal error LNK1104: unable to open file 'lsmash.lib' I take any idea or advice.
My github. |
26th August 2019, 02:01 | #859 | Link | |
結城有紀
I second the idea of checksuming, and if you don't bother doing that, I might. |
26th August 2019, 04:46 | #860 | Link |
結城有紀
LSMASHSource-Release_r935+33.zip
Commit Diff I have changed the logic. If size and timestamp match, assume unchanged. If size matches but not timestamp, hash (first 1MiB + last 1MiB) and compare with recorded hash. If file is too small, only first up to 1MiB counts. Hash method is xxhash which is extremely fast. A missing hash record will not force regenerating the index file as long as size and timestamp match. Let me know how that works. I also include an easy-compiling branch and a cmake build script. Get VS 2017 / 2019 and cmake installed, and use the following batch file to build your copy. Code:
@echo off mkdir build\x86 pushd build\x86 cmake -DCMAKE_GENERATOR_PLATFORM=Win32 -D_DIR=x86 ..\..\ popd mkdir build\x64 pushd build\x64 cmake -DCMAKE_GENERATOR_PLATFORM=x64 -D_DIR=x64 ..\..\ popd cmake --build build\x86 --config Release cmake --build build\x64 --config Release |
