Old 23rd July 2015, 09:51   #2701  |  Link
Belphemur
MPDN Extensions Dev
Yeah got that earlier today, didn't bother reporting it as they know what's up, figured I'd just wait it out.
Will do.
Sorry for this, it was my doing. I upgraded to the last version of Visual Studio and didn't pay attention that I was using the C# syntax (that isn't supported by MPDN). I commited my changes to correct this. Now the source version available on github works with MPDN.
Belphemur is offline   Reply With Quote
Old 23rd July 2015, 10:36   #2702  |  Link
Yeah, I've been following that I've encountered this a few times already during MPDN's development so no big deal.
I suppose though if the main branch is going to be considered kinda stable (I think that might be the case) it could be worth giving the code a quick test first before submitting for a merge.
Also Garteal got caught out not submitting the regex config fix both you and I gave him a heads up on before 1.10 got released, so it's probably good practice
to make sure the submission is stable. But hey, it's not like it's a drama if it isn't. Everyone seems to be pretty hot on the code here.. quite refreshing really.
Zach is it possible to give the master a version number so the updater doesn't prompt to update the extensions to the latest released possibly earlier code version? Perhaps all commits could add 0.0.1 or 0.0.0.1?
Whatever works..
Old 23rd July 2015, 13:18   #2703  |  Link
Zachs
Suptitle, MediaPlayer.NET
Zach could you make the OSD only display when the player switches to fullscreen after loading a file when 'launch media in fullscreen mode' is active?
I got a nice big OSD flashing up for a moment before it changed to fullscreen.
It only shows the OSD after going to fullscreen mode. In fact, the code to switch to fullscreen comes before the OSD display code...
Old 23rd July 2015, 13:21   #2704  |  Link
Zachs
Whatever works..
You mean when you're using the source code instead of the binaries? If so can you put a request on GitHub to get the update checker to auto disable when the source version is used?
Old 23rd July 2015, 13:46   #2705  |  Link
Zachs
Originally Posted by Volfield View Post
Presentation API: Direct3D 10.1, image quality: render performance (on image quality play fine) , GF GT 320M , Win7x64
EDIT: Problem 2:
image quality: render performance, XySubfilter -> subtitles ok
image quality: image quality, XySubfilter -> black rectangle around subtitles.
The first issue you encountered has now been fixed.
Problem #2 I can't reproduce though...
Old 23rd July 2015, 14:03   #2706  |  Link
Will do. Could be an idea just ignoring the latest binary releases I guess.
There's something funky going on there.. maybe it had reached fullscreen mode at the time it displayed the OSD, the OSD did stretch though on resize.
Old 23rd July 2015, 18:00   #2707  |  Link
aufkrawall
Sinc-Blackman 8 taps w.o. AR seems to be a great chroma scaler.
MPDN S-B:
madVR Jinc3AR:
But enabling AR filter of MPDN is a bad idea for chroma, it becomes blurry by this.
Btw: Bicubic 50 in madVR is pretty much bicubic 100 in MPDN.
Old 23rd July 2015, 18:10   #2708  |  Link
Volfield
Is there any way for me to help you find solution?
P.S. screenshots include
Volfield is offline   Reply With Quote
Old 23rd July 2015, 18:40   #2709  |  Link
aufkrawall
I just discovered that the OpenCL implementation of NNEDI3 looks worse than the other.
OpenCL:
PS5.0:
(look at the doorframe, image is exactly doubled per axis)
Is it supposed to be that way? MPDN OpenCL and madVR OpenCL look the same. btw.
Old 23rd July 2015, 18:59   #2710  |  Link
Anima123
More aliasing in OpenCL version. BTW, does madVR have PS 5.0 implementation of NNEDI3?
Anima123 is offline   Reply With Quote
Old 23rd July 2015, 19:11   #2711  |  Link
aufkrawall
Exactly.
No, but madshi is not against it (however, no etas as usual).
Btw: I'd really love to see options in the MPDN GUI/extensions for defining doubling/quadrupling settings like in madVR.
Old 23rd July 2015, 22:12   #2712  |  Link
madshi
It's always dangerous to base such conclusions on just one image...
Without having looked into the matter, one wild guess would be that the OpenCL implementation might scale X first while PS5.0 might scale Y first, or vica versa. Doing that will change the angle of the lines, which can have a huge impact on the aliasing, especially when using a low neuron count.
You could try rotating the image 90° before scaling, as a double check. Does that make the two variants look identical?
Old 23rd July 2015, 22:51   #2713  |  Link
aufkrawall
lul what
Nice guess, sir!
OpenCL:
PS5.0:
Old 24th July 2015, 00:41   #2714  |  Link
Zachs
The screenshots links are broken but do you get this problem with every file with subtitles or just specific ones?
Old 24th July 2015, 00:51   #2715  |  Link
Zachs
The "Conditional" script was created exactly for such a thing.
You can easily replicate madVR's simple behaviour with it but it's a lot more powerful - e.g. you can double with NNEDI3, then double again with NEDI or Super-xBR (or with NNEDI3 again, with the same or different number of neurons), only when it's required. Or you can have 3 in the chain to give you 8x, or 4 to get 16x etc.
Old 24th July 2015, 01:05   #2716  |  Link
Zachs
lul what
Nice guess, sir!
Yes, it depends on which direction it scales first (and OclNNEDI3 is the opposite of the SM5 version). The second pass will result in lower quality. It may be a good idea then to scale first pass with higher neurons.
Go ahead and create a request on GitHub for separate neuron settings for each pass. Either Shiandow or myself could add the feature when we get to it. Or anyone else who wants to have a play with the render script. It's a very small change so might be a good place to start if you want to learn.
Old 24th July 2015, 01:14   #2717  |  Link
Zachs
BTW, while we're on the subject, has anyone noticed the SM5 NNEDI3 is now around 10% faster with the same neurons vs OpenCL with the recent Nvidia drivers? At least on my Fermi cards, it was neck and neck (with SM5 just a touch faster) when we first implemented it. We haven't updated the NNEDI3 code and the only thing that's changed would've been the drivers. Just wondering if anyone's noticed the speed improvements.
Old 24th July 2015, 04:47   #2718  |  Link
Volfield
http://imgur.com/LQKSGcr,sxEUjSs#0
Every file(ass,str,txt).
Old 24th July 2015, 05:04   #2719  |  Link
Zachs
That's strange. I just can't replicate the problem on any of my systems...
Do you have any render scripts running?
Could you send me your config folder so I could try and see if there's anything else that might be needed to trigger the problem?
Old 24th July 2015, 05:09   #2720  |  Link
Volfield
https://mega.nz/#!pZ0QXbDA!Dg2YFWksp...psmc7y9y3UQHeU
direct3d, mpdn, nnedi3, opencl, reclock
