Old 12th April 2015, 11:46   #1741  |  Link
aufkrawall
this is just my guess why this maybe isn't hardware related.
http://abload.de/img/directcomputegtugt.png
at least i remembered correctly.
edit: yeah i totally forgot. some people can't reach 24 FPS so they can't use dx9 <-> openCL for any realtime program. i call this a bug and i'm talking about GPU like r7 or r9 series.
Could you please relink that benchmark?
Old 12th April 2015, 11:59   #1742  |  Link
doesn't work with nvidia.
if i remember correctly someone has written a version for nvidia(was it cyberbeing? sorry i can't remember) but yeah this is the original version from madshi from his server for AMD GPUs (works fine for intel).
i use it with every new AMD driver version just to see nothing has changed...
Old 12th April 2015, 12:15   #1743  |  Link
aufkrawall
Thanks. Since I'm with NV, I hope that the author of the compatible version will read this or maybe someone else still has it.
Old 12th April 2015, 12:46   #1744  |  Link
Zachs
Suptitle, MediaPlayer.NET
It's a synthetic benchmark, so don't read too much into the result.
Old 12th April 2015, 13:50   #1745  |  Link
and it's a copy benchmark the really important part is the processing that's done on the frame later at openCL.
but numbers like 37 fps slow some real problem...
Old 12th April 2015, 13:53   #1746  |  Link
Zachs
I meant the Nvidia benchmark.
Old 12th April 2015, 13:58   #1747  |  Link
aufkrawall
With your benchmark 11, I'm getting 1278fps (GTX 980). Seems to be CPU limited. Cuda wrapper overhead?
Old 12th April 2015, 14:01   #1748  |  Link
Zachs
I think it's gpu memory bandwidth limited.
Old 12th April 2015, 14:16   #1749  |  Link
just run it with gpu-z.
Old 12th April 2015, 14:24   #1750  |  Link
aufkrawall
I get lower fps when I have Process Hacker opened, which consumes CPU power. But probably it could also be due to its way of GPU polling?
It's definitely bandwidth limited. When I OC VRAM from 3.6 to 4.0Ghz, I get an increase to 1380fps.
Old 12th April 2015, 19:36   #1751  |  Link
patul
I get 164 fps for v11, AMD A6-5400K APU (HD 7540D). Haven't test on my laptop yet.
patul is offline   Reply With Quote
Old 13th April 2015, 04:02   #1752  |  Link
Zachs
Hi guys,
Thanks for all the help so far. I'd appreciate it if I could get you guys to run version 12 of the test app to see if it still runs and report back the new frame rate.
Thanks again!
Cheers.
Old 13th April 2015, 04:48   #1753  |  Link
Anima123
Test version 12 on Optimus (Intel HD 4600 + nVidia 880M), 249 fps, with previous version 9, the fps was 366.
Anima123 is offline   Reply With Quote
Old 13th April 2015, 05:37   #1754  |  Link
cyberbeing
Broadband Junkie
if i remember correctly someone has written a version for nvidia(was it cyberbeing? sorry i can't remember).
At the time, all I did compile a build with DirectCompute-only so I could see the results on my NVIDIA card. I never attempted to fix the OpenCL tests. It doesn't appear I ever shared the DirectCompute-only build back then, so here it is if anyone wanted it: https://www.mediafire.com/?u6x778w7odoaqdi
It is somewhat reassuring to see that NVIDIA has made some improvements to DirectCompute performance improvements since then though. A nice +65% increase (172fps->285fps) in DirectCompute Error Diffusion performance with 350.05 compared to the 321.10 driver I initially tested one year ago. Still quite poor compared to AMD cards though, considering even madshi's HD7770 could break 300fps in that DirectCompute test.
Old 13th April 2015, 05:44   #1755  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
Originally Posted by Zachs View Post
Hi guys,
Thanks again!
Cheers.
Version 12 gives 400-404 on my Optimus system.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
Old 13th April 2015, 07:41   #1756  |  Link
Zach, you need to clear your inbox.
750 Ti 440 FPS build 12, we've dropped some performance.
Old 13th April 2015, 08:45   #1757  |  Link
burfadel
187.039 fps this time, AMD R9-280X.
Old 13th April 2015, 09:45   #1758  |  Link
aufkrawall
Gives me a performance gain with GTX 980, 1343fps.
Old 13th April 2015, 11:36   #1759  |  Link
Zachs
On my GTX 560, it's gone up from 640 to 716fps. On the Intel, it's gone up from 315fps to 370fps.
Old 13th April 2015, 11:55   #1760  |  Link
*cough* 540 *cough*
direct3d, mpdn, nnedi3, opencl, reclock
