#21 | Link | |
Next I will add RGB32 support. |
#24 | Link |
Using the latest version in Vapoursynth, when using:
# adjusting color space from YUV420P8 to RGB24 for Softlight clip = core.resize.Bicubic(clip=clip, format=vs.RGB24, matrix_in_s="470bg", range_s="limited") # color adjustment using Softlight clip = core.Argaricolm.Softlight(clip) Code:
# adjusting color space from YUV420P8 to YUV444P8 for Softlight clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P8, matrix_in_s="470bg", range_s="limited") # color adjustment using Softlight clip = core.Argaricolm.Softlight(clip) Doesn't matter whether I use "CUDA 12.3/SoftLight.dll" or "CUDA 11.8/SoftLight.dll". => seems like v1.12 broke RGB24 support for Vapoursynth. Cu Selur Ps.: Do you prefer if I post such stuff here or on github? |
#25 | Link |
"Added RGB32. But only for avisynth (vapoursynth strangely does not support RGB32)."
There is no RGB24 support (so far). And strangely vapoursynth does not support RGB32. That should be faster in memory because of 4 bytes addressing. |
#27 | Link | |
So it's just like I use RGB24 but in RGB32 adressing. In avisynth memory 4th byte is automatically set to FF (255) when 24bit (8*3) content is converted to RGB32. So it's not realy a correct RGB32 support. Maybe I need to change it to RGB24. |
#30 | Link |
Formerly davidh*****
Am I missing something?
colorbars(pixel_type="rgb24", width = 3840, height = 2160).softlight Does it just pass through the original clip if there is a CUDA issue? --- Edit: RGB24 interleaved doesn't work, RGB32/YV12/presumably others does Further edit: doesn't seem to work at all on my desktop computer, just returns unaltered clip... Edit: Having looked at the code there is zero error handling/reporting, even for CUDA failures. You might want to add some! Last edited by wonkey_monkey; 16th March 2024 at 16:27. |
#33 | Link | ||
if (cudaStatus == cudaSuccess) { ... } else { env->ThrowError("SoftLight: CUDA failed"); } Going back in time a little: Quote:
For interleaved RGB input, AVX code was 1.3x faster than CUDA, even with AviSynth+ colourspace conversion overheads. Multithreading might give another 25%-50% boost. Last edited by wonkey_monkey; 16th March 2024 at 23:37. |
#34 | Link |
To sum all samples of the frame at SIMD there are possible several ways:
1. Sum at integer - require unpacks of 8..16 samples to 32bits and use summing of standard SIMD full width * superscalar factor of sum dispatch ports first for all samples of a line. Because it looks 32bit integer can not hold UHD frame samples number * 256..65535 samples values sum without overflow - it is possible to make intermediate division of intermediate sums for each line and accumulate normalized sums of the all lines of a frame. It is more complex to program in compare with float32 processing but maybe visibly faster for SD 8bit and some HD frame sizes. 2. Make unpack and convert to float32 and perform all of 1 in float32 domain. So best performance implementation can have different processing engines inside for different frame sizes. At least 1920x1080 with 8bit still can be processed with integer full frame summing without 32bit accumulator overflow. Also with SIMD word summing programmer anyway have partial sums at the final SIMD word ready to partial normalizing with some more overflow protection (AVX2 SIMD word of 8 32bit integers provides additional +3bits to overflow so total capacity is 32+3=35bits) and without significant precision loss. Method 2 can process any frame sizes in single engine but expected to be slower at non-UHD frame sizes. CPU SIMD is not very slow - but algorithm requires at least 2 full frame passes: first analisys pass of sum and second is correction pass of adjustment so performance will depend on frame size fitting in availavle CPU caches (our lovely Xeon MAX with HBM onboard will be nice performer here). Last edited by DTL; 17th March 2024 at 07:12. |
#35 | Link |
A new release - 1.14.
Also a question for video gurus here: As I see nearly ALL content that is released now on blurays or streamed through streaming services are encoded in limited color range (16-235). The question is why it is so? Old TVs that had such limitations are already all in junk. And new TV's can't determine automatically that source is limited color range. This results that we watch limited color range without convertion to full range. But we should watch limited range converted to full. I understand that streaming services long ago could do this to make streaming smaller in size (limited color range take fewer space). But now, when we have fast internet speeds nearly everywhere it is just ridiculous. And for blurays I don't understand it at all. It looks like some conspiracy to mock on people eyes. Last edited by Argaricolm; 4th May 2024 at 17:29. |
#36 | Link |
" The question is why it is so?"
It is industry standard to keep more quality with limited number of bits (until possible changing to float32 or at least float16 samples values encoding). But 8bit-narrow (limited) works good enough so it is unlikely industry will change to float16/32 any fast. "This results that we watch limited color range without convertion to full range." Physical display converts 16..255 Y code values to 0..PHYmax brightness values. So you not lost 236..255 code values encoded in 8bit narrow range. You can test it with 16..255 Y values test pattern. If display clips 236..255 to PHYmax it is broken and need repair or adjustment. 235 code value only marks position of nominal white - not max PHY white. Display hardware may treat 236..255 range very differently (depending on the processor cost and AI algoriphms included) - either continue to track system transfer function or make HDR-expansion of any type. Last edited by DTL; 4th May 2024 at 17:46. |
#38 | Link | ||
Limited color range is 8 bit 16-235 levels of brightness (220 from 256). When you view it on tv as it is - nothing is converted to full range. You see incorrect colors and contrast. But you have seen it for years now. So you think that it is "normal". Here is example. In limited color range there is no 0 and thats why in frames with a lot of black/dark you dont see black. You see only nearly black. This results in fewer contrast. And incorrect colors (because of contrast). For example you should see red color, but you will see light red. Quote:
For example - that batman 2022 video from above is surely limited color range but it does not have any info inside about limited color range. And I'v checked pixels. You can find values 0-15 inside any limited color range video. Its just they are fewer in numbers than should be. So I don't see any easy way for TV to determine - is video with limited color range or not. |
#39 | Link |
"You can find values 0-15 inside any limited color range video"
It is also correct - footroom in narrow range mapping is to hold filter undershoots to display better sharpness (visible in the PHY range above zero). See https://forum.doom9.org/showthread.p...87#post2000687 |
#40 | Link | |
Because I don't think that is the case. |
