29th March 2015, 06:01 | #1981 | Link | |
Thanks qyot27. Two questions: 1. Can this deal with interlaced content? 2. And what about interlaced content that's been encoded as progressive (as reported by mediainfo) in a ts container? Or is there a way to flag these as interlaced without re-encoding? Many thanks and best regards. |
29th March 2015, 07:28 | #1982 | Link |
I don't know, as I've never had to handle interlaced H.264 with FFMS2. Since the latest builds have the Haali splitters removed, its performance should map fairly equally to how it's handled in FFmpeg itself.
29th March 2015, 10:55 | #1984 | Link | |
"New tool to change SAR in H264 bitstream " http://forum.doom9.org/showthread.php?t=152419
30th March 2015, 08:39 | #1986 | Link |
There is quite a difference between PAFF and MBAFF interlacing. It's more than a matter of setting flags. You would confuse a decoder substantially if you patched them wrong.
9th April 2015, 06:49 | #1987 | Link | |
MultiAVCHD was not able to display the menu and video when the r944 files was placed in the Avisynth plugin folder. No issue with the official 2.2 build. What may have caused this? Many thanks and best regards. |
9th April 2015, 12:07 | #1988 | Link | |
You need to do so, because this is a C-plugin and it will not autoload without the FFMS2.avsi file being present in the same directory. Last edited by Pat357; 9th April 2015 at 12:09. |
9th April 2015, 12:12 | #1989 | Link |
AviSynth+ (note the plus) is able to autoload AviSynth C plugins; the original AviSynth 2.x is not, therefore the import script (with additional declared convenience functions).
10th April 2015, 01:49 | #1990 | Link | |
All the three files are placed in the plugin directory. Here's the situation: 1. No files in plugin directory: multiAVCHD OK. 2. Build 2.2 files in plugin directory: OK. 3. Build 944: NOT OK Any idea? |
26th April 2015, 11:31 | #1992 | Link | |
Here is a problem a StaxRip user reported:
------------------------------------------------------------ Source file MediaInfo ------------------------------------------------------------ D:\Spiele\BorderlandsPreSequel 2015-02-05 20-34-18-52_merged.mkv General Unique ID : 242162529886412073948372795964824009988 (0xB62ECE8896C135ED9BB8CA6516F8BD04) Complete name : D:\Spiele\BorderlandsPreSequel 2015-02-05 20-34-18-52_merged.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 6.21 GiB Duration : 1mn 16s Overall bit rate : 701 Mbps Encoded date : UTC 2015-04-26 10:03:44 Writing application : mkvmerge v7.7.0 ('Six Voices') 32bit built on Feb 28 2015 23:23:00 Writing library : libebml v1.3.1 + libmatroska v1.4.2 DURATION : 00:01:16.133000000 NUMBER_OF_FRAMES : 2438 NUMBER_OF_BYTES : 14617600 _STATISTICS_WRITING_APP : mkvmerge v7.7.0 ('Six Voices') 32bit built on Feb 28 2015 23:23:00 _STATISTICS_WRITING_DATE_UTC : 2015-04-26 10:03:44 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Video ID : 1 Format : Fraps Codec ID : V_MS/VFW/FOURCC / FPS1 Duration : 1mn 16s Width : 2 560 pixels Height : 1 600 pixels Display aspect ratio : 16:10 Frame rate mode : Constant Frame rate : 30.000 fps Default : Yes Forced : No Audio ID : 2 Format : PCM Codec ID : A_PCM/INT/LIT Duration : 1mn 16s Bit rate mode : Constant Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Default : Yes Forced : No Quote:
26th April 2015, 15:48 | #1993 | Link |
There is a ffmsindex memory leak with 2.20 64-Bit
General Audio_Codec_List : DTS Audio_Language_List : English Codec/String : Matroska FileSize/String4 : 9.837 GiB Duration/String1 : 2h 8mn 15s 691ms OverallBitRate/String : 11.0 Mbps FrameRate/String : 23.976 fps FrameCount : 184512 StreamSize/String : 200 MiB (2%) Encoded_Date : UTC 2015-04-23 21:59:03 File_Created_Date_Local : 2015-04-24 21:24:08.430 File_Modified_Date_Local : 2015-04-24 08:34:08.485 Encoded_Application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01 Encoded_Library : libebml v1.3.0 + libmatroska v1.4.0 Video ID : 1 Format_Profile : High@L4.1 Codec/String : AVC Duration/String1 : 2h 8mn 15s 696ms BitRate/String : 9 469 Kbps Width/String : 1 920 pixels Height/String : 800 pixels PixelAspectRatio : 1.000 DisplayAspectRatio/String : 2.40:1 FrameRate/String : 23.976 fps FrameCount : 184512 Resolution/String : 8 bits ScanType : Progressive StreamSize/String : 8.29 GiB (84%) Encoded_Library : x264 - core 144 r2525 40bb568 Language/String : English Default : Yes Forced : No Audio ID : 2 Codec/String : DTS Duration/String1 : 2h 8mn 15s 691ms BitRate_Mode : CBR BitRate/String : 1 509 Kbps Channel(s)/String : 6 channels SamplingRate/String : 48.0 KHz Resolution/String : 24 bits Compression_Mode : Lossy Video_Delay : 0 StreamSize/String : 1.35 GiB (14%) Language/String : English Default : Yes Forced : No |
26th April 2015, 19:08 | #1994 | Link |
Professional Code Monkey
I'm posting about it here as well since not everyone reads the VapourSynth thread...
Here's a ffms2 32bit test build from my own development branch. Compiled with latest libav. I need help to test it to see so I didn't break anything for Avisynth users. If you don't test it now you'll be getting buggy Avisynth builds later.
27th April 2015, 10:07 | #1997 | Link |
27th April 2015, 10:34 | #1999 | Link |
When you do what exactly?
27th April 2015, 10:47 | #2000 | Link |
------------------------------------------------------------ Environment ------------------------------------------------------------ StaxRip version : 1.3.0.3 OS : Windows 7 Home Premium Language : German (Germany) CPU : Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz GPU : NVIDIA GeForce GTX 960 LAV Filters : LAV Filters 0.65.0-2 ------------------------------------------------------------ Source file MediaInfo ------------------------------------------------------------ C:\Daten\Temp\test\test.mkv General Unique ID : 179239962812818211157003190095008528769 Complete name : C:\Daten\Temp\test\test.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 65.4 MiB Duration : 2mn 5s Overall bit rate : 4 385 Kbps Encoded date : UTC 2015-04-27 05:46:06 Writing application : mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02 Writing library : libebml v1.3.1 + libmatroska v1.4.2 DURATION : 00:02:05.185000000 NUMBER_OF_FRAMES : 6260 NUMBER_OF_BYTES : 1272797 _STATISTICS_WRITING_APP : mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02 _STATISTICS_WRITING_DATE_UTC : 2015-04-27 05:46:06 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2mn 5s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 146 r2538 121396c Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Audio ID : 2 Format : Opus Codec ID : A_OPUS Duration : 2mn 5s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Default : Yes Forced : No ------------------------------------------------------------ Index with ffmsindex ------------------------------------------------------------ "C:\Daten\Projekte\GitHub\staxrip\bin\Tools\Plugins\ffms2\ffmsindex.exe" "C:\Daten\Temp\test\test.mkv" "C:\Daten\Temp\test\test temp files\test.ffindex" Writing index... done. Start: 11:44:34 End: 11:44:34 Duration: 00:00:00 ------------------------------------------------------------ Error opening source ------------------------------------------------------------ FFVideoSource: No video track found (C:\Daten\Temp\test\test temp files\test_new_Source.avs, line 2) FFVideoSource("C:\Daten\Temp\test\test.mkv", cachefile = "C:\Daten\Temp\test\test temp files\test.ffindex") AssumeFPS(25.000000) |
