8th March 2015, 18:22 | #1961 | Link |
I just recorded another clip from this and another game with the same codec and same options and then opened it just fine (with your version of the plugin, ffms2_r940c64-avs_vsp). But that particular clip I cannot.
It works just fine elsewhere. It is not damaged. There is nothing special about it. You can open. Why I can't? |
10th March 2015, 10:51 | #1963 | Link | |
15th March 2015, 07:27 | #1964 | Link |
Possibly ffms2 misses to release a file handle, I use the avifile API, after releasing and cleaning everything the process still locks the source, I tried other source filters and it happens only with ffms2.
16th March 2015, 19:50 | #1965 | Link |
With latest C plugin build when I open 2-3 movies seeking around in StaxRip's preview memory grow up quickly causing a out of memory exception at 1,5 GB.
With the 2.20 release memory stays always below 850 MB. Specs of test file: http://pastebin.com/MxqcTkRh Last edited by stax76; 16th March 2015 at 19:56. |
17th March 2015, 03:02 | #1966 | Link |
This has been a mysterious leak for a while. It came up regarding MeGUI a year ago, and I could reproduce it in VirtualDub:
http://forum.doom9.org/showthread.ph...11#post1674911 But I wasn't able to find where it was doing it in the C interface part of FFMS2. |
27th March 2015, 00:16 | #1969 | Link |
FFMS2 C-plugin r944+69
Optimized for Pentium-III and SSE. ffmpeg version r70952 git-db4234c Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) Code:
libavutil 54. 20.100 / 54. 20.100 libavcodec 56. 29.100 / 56. 29.100 libavformat 56. 26.101 / 56. 26.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 configuration: --prefix=/home/qyot27/win32_build --cross-prefix=i686-w64-mingw32- --enable-gpl --enable-version3 --disable-w32threads --enable-avresample --disable-encoders --disable-decoder=utvideo --enable-libutvideo --disable-decoder=dca --enable-libdcadec --disable-muxers --disable-doc --disable-debug --disable-devices --cpu=pentium3 --extra-cflags='-mfpmath=sse -march=pentium3 -msse -mtune=pentium3 -DPTW32_STATIC_LIB' --target-os=mingw32 --arch=x86 EDIT 2015-05-05: Newer build available here. Last edited by qyot27; 6th May 2015 at 01:22. |
27th March 2015, 12:14 | #1970 | Link | |
Finally a decent replace for the rather poor ffdca !! Note : currently no support for 192 kHz sample rates , just up to 92 kHz ! see : https://github.com/foo86/dcadec Last edited by Pat357; 27th March 2015 at 12:19. |
28th March 2015, 00:53 | #1971 | Link | |
I have a question about the license:
28th March 2015, 01:06 | #1972 | Link | |
Software Developer
Now, if you combine your own code with someone else's code, then the combined work needs to be distributed under a compatible license, of course. So, if the authors of FFMS2 decide to release their own code under the MIT license, they are of course free to do so! But as soon as a binary is created, which unavoidably contains some FFmpeg code too, then the whole thing must be distributed under the LGPL or GPL - depending on what FFmpeg feature are enabled. That's because FFmpeg is released under the LGPL - and partly under the GPL. And the GPL/LGPL is more restrictive than the MIT license. You can combine MIT'ed code with GPL'ed or LGPL'ed code, but the combined work has to be distributed under GPL/LGPL then. Unless I'm missing anything here, this should be fine
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 28th March 2015 at 01:19. |
28th March 2015, 01:11 | #1973 | Link | ||
28th March 2015, 05:27 | #1975 | Link | |
Is this to be used with Avisynth 2.58? Many thanks and best regards. |
28th March 2015, 21:10 | #1980 | Link |
Make a bug report with a sample on the tracker. Best chance to get someone to look at it.
https://github.com/FFMS/ffms2/issues |
