13th February 2010, 16:27 | #6881 | Link |
@RocKKer;
The audio streams are removed, but the language streams list, per .mpls, are kept in place like the original. It's just the streams list now point only to the audio that is kept. The option, though not necessarily a good one, would be to use a place holder, a small blank audio stream, in place of the removed audio streams, which would mean there would only be silence on the removed audio tracks when selecting them. This would bring about more programming issues. I prefer the method jdobbs has chosen. Besides, he has a little bit more knowledge and experience in this area, so I accept his decision. |
13th February 2010, 16:37 | #6882 | Link | |
Sometimes you may just get a glitch in playback, sometimes it may simply not work at all. Sometimes it may work on one player only to fail on another. Last edited by jdobbs; 13th February 2010 at 16:43. |
13th February 2010, 18:26 | #6883 | Link |
Re did the Encode again with 31.08 re-encoded HD audio and it came out worse then before lol!! Set the Quality to High 2pass Encode and the video has severe artifact blocks and at one point there are rectangle blocks across the screen. The source is flawless, could it be a bad rip? or just my PC. I checked other BD's that are still on my HDD that were same size, Terminator Sarah Connor Chronicles Season 2 BD1 and it has no blocks. I'm thinking is the BD itself.
Any insight would be appreciated. |
13th February 2010, 18:59 | #6884 | Link | |
13th February 2010, 19:12 | #6885 | Link | |
Thanks for explaining jdobbs - I obviously have so much more to learn about BRD! Thanks for your time and patience with a newbie. Last edited by RocKKer; 13th February 2010 at 19:22. |
13th February 2010, 20:13 | #6886 | Link | |
13th February 2010, 20:14 | #6887 | Link | |
Thanks for the info, hope i didn't waste too much time with a bad rip info. I'll know better for next time here is the info about that M2TS From the log, is that a decent bitrate? [00000] AUDIO=100 PGS=11111100000000 M2TS_TARGET=21163575034 RATE=13933 NSIZE=20607105024 FLINK=0 MLINK=0 Last edited by Kakashi Sensei; 13th February 2010 at 20:16. |
13th February 2010, 21:36 | #6889 | Link | |
14th February 2010, 05:38 | #6890 | Link |
[17:59:22] BD Rebuilder v0.31.08 (beta)
- Source: JOHN_Q - Input BD size: 27.84 GB - Approximate total content: [01:56:05.249] - Target BD size: 7.72 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [17:59:23] PHASE ONE, Encoding - [17:59:23] Reencoding: VID_00000 (1 of 1) - [17:59:23] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 166,999 frames - Bitrate: 8,010 Kbs - [17:59:23] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3133) [17:59:24] - Failed video encode, aborted what does the FFDSHOW revision mean? any help would be appreciated, thanks. |
14th February 2010, 06:27 | #6891 | Link |
@nelly09;
I believe it is the version of ffdshow you are using, which looks to be the one on the first page of this thread that jdobbs recommends. But it appears you do not have it configured correctly, thus the " Encode failed " message. Try setting the video decoder for VC-1 to wmv9. This should have been done by BD-RB on the initial run/setup. Have you installed any other codec packs or tried to update ffdshow, than downgraded to the 3133 version? |
14th February 2010, 18:38 | #6893 | Link | |
I would try and uninstall ffdshow, reboot, and reinstall the one on the first page of this thread. Then unzip a new BD-RB, 31.08, and follow the initial install instructions from here. http://forum.doom9.org/showthread.php?t=151633 Remember to right click on "REG_MSCOMCTL.BAT" and run as admin. first, and then, if that does not work, right click on BD-RB.EXE and do the same. Good Luck! |
14th February 2010, 20:28 | #6894 | Link |
Ok just tried 2012. This title has 6 sub tracks. None of which are dedicated to the non english parts, so ive had to do a 1:1, however.....
[02:47:23] BD Rebuilder v0.31.06 (beta) - Source: 2012 - Input BD size: 38.59 GB - Approximate total content: [02:53:02.904] - Target BD size: 23.19 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [02:47:25] PHASE ONE, Encoding - [02:47:25] Extracting A/V streams [VID_00423] - [02:47:26] Reencoding: VID_00423 (1 of 9) - [02:47:33] Extracting A/V streams [VID_00398] - [02:47:40] Reencoding: VID_00398 (2 of 9) - [02:48:05] Extracting A/V streams [VID_00433] - [02:48:13] Reencoding: VID_00433 (3 of 9) - [02:49:03] Extracting A/V streams [VID_00742] - [02:49:16] Reencoding: VID_00742 (4 of 9) - [02:50:46] Extracting A/V streams [VID_00504] - [02:51:05] Reencoding: VID_00504 (5 of 9) - [02:53:14] Extracting A/V streams [VID_00450] - [02:53:33] Reencoding: VID_00450 (6 of 9) - [02:55:54] Extracting A/V streams [VID_00503] - [02:56:16] Reencoding: VID_00503 (7 of 9) - [02:58:55] Extracting A/V streams [VID_00428] - [02:59:20] Reencoding: VID_00428 (8 of 9) - [03:02:42] Extracting A/V streams [VID_00740] - [03:34:50] Reencoding: VID_00740 (9 of 9) - Error in attempt to multiplex: MUX_00740.meta - Can't open file: F:\2012 RECODE\WORKFILES\VID_00740_2.AVS.MKV [18:24:06] - Failed to build structure, aborted ----------------------- [18:58:55] BD Rebuilder v0.31.06 (beta) - Source: 2012 - Input BD size: 38.59 GB - Approximate total content: [02:53:02.904] - Target BD size: 23.19 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [18:59:03] PHASE ONE, Encoding - Error in attempt to multiplex: MUX_00740.meta - Can't open file: F:\2012 RECODE\WORKFILES\VID_00740_2.AVS.MKV [18:59:03] - Failed to build structure, aborted ----------------------- [19:15:56] BD Rebuilder v0.31.06 (beta) - Source: 2012 - Input BD size: 38.59 GB - Approximate total content: [02:53:02.904] - Target BD size: 23.19 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [19:15:57] PHASE ONE, Encoding - Error in attempt to multiplex: MUX_00740.meta - Can't open file: F:\2012 RECODE\WORKFILES\VID_00740_2.AVS.MKV [19:15:57] - Failed to build structure, aborted |
14th February 2010, 22:58 | #6896 | Link | |
15th February 2010, 05:01 | #6897 | Link |
BD-9 and BD-5
Hi everyone, Many thanks goes to Mr. jdobbs for excellent program. I been a huge fan of this BD-RE for about 4 month and about a dozen backed up blu rays with a little or no bugs found on any of my movie only backups in BD-25, BD-9 or BD-5. and yesterday I tried for the first time a full backup to BD-9 everything was fully completed and burned to the disc (verbatim +9) but when I inserted the disc in my Panasonic DMP-BD30 blu ray the player said format was not support it or incompatible> now I did 2 full disc to BD-25 with no problem with only a slight longer delay in chapter or scene selection, but not a problem, perfect copy to the original. The movies in Q's? The couples retreats full copy to BD-25 excellent copy. but the other 3 full copies to BD-9 with errors on my player are: Law abiding citizen, Watchmen, and Cloudy w/chance of meatballs. They were burn with V. 06. I burnt 2 movies with Verbatim DVD and I thought it was bad burnt, I send the rest of the blank DVD to Verbatim corp. received a full 20 cake bundle and tried a full backup with the new batch Verbatim dvd9 and the same results. maybe a full backup is only for BD25? and yes I have all program from the first page installed in my system...and my BD player is up to date with it Ver 2.9 installed..please any input will be greatly appreciated....thanks again. Raul124
here is full movie Code:
----------------------- [23:16:45] BD Rebuilder v0.31.06 (beta) - Source: LAW_ABIDING_CITIZEN - Input BD size: 34.20 GB - Approximate total content: [02:40:30.379] - Target BD size: 7.72 GB - Windows Version: 6.0 [6001] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [23:16:45] PHASE ONE, Encoding - [23:16:45] Extracting A/V streams [VID_00005] - [23:16:47] Reencoding: VID_00005 (1 of 22) - [23:16:47] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 144 frames - [23:16:47] Reencoding: VID_00005, Pass 1 of 1 - [23:16:51] Video Encode complete - [23:16:51] Reencoding audio tracks (if req'd) - [23:16:51] Multiplexing M2TS - [23:16:52] Extracting A/V streams [VID_00026] - [23:16:52] Reencoding: VID_00026 (2 of 22) - [23:16:52] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 120 frames - [23:16:52] Reencoding: VID_00026, Pass 1 of 1 - [23:16:55] Video Encode complete - [23:16:55] Reencoding audio tracks (if req'd) - [23:16:55] Multiplexing M2TS - [23:16:55] Extracting A/V streams [VID_00029] - [23:16:56] Reencoding: VID_00029 (3 of 22) - [23:16:56] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 144 frames - [23:16:56] Reencoding: VID_00029, Pass 1 of 1 - [23:16:59] Video Encode complete - [23:16:59] Reencoding audio tracks (if req'd) - [23:16:59] Multiplexing M2TS - [23:16:59] Extracting A/V streams [VID_00028] - [23:17:00] Reencoding: VID_00028 (4 of 22) - [23:17:00] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 168 frames - [23:17:00] Reencoding: VID_00028, Pass 1 of 1 - [23:17:03] Video Encode complete - [23:17:03] Reencoding audio tracks (if req'd) - [23:17:03] Multiplexing M2TS - [23:17:04] Extracting A/V streams [VID_00006] - [23:17:04] Reencoding: VID_00006 (5 of 22) - [23:17:04] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 240 frames - [23:17:04] Reencoding: VID_00006, Pass 1 of 1 - [23:17:08] Video Encode complete - [23:17:08] Reencoding audio tracks (if req'd) - [23:17:08] Multiplexing M2TS - [23:17:09] Extracting A/V streams [VID_00003] - [23:17:10] Reencoding: VID_00003 (6 of 22) - [23:17:10] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 240 frames - [23:17:10] Reencoding: VID_00003, Pass 1 of 1 - [23:17:14] Video Encode complete - [23:17:14] Reencoding audio tracks (if req'd) - [23:17:14] Multiplexing M2TS - [23:17:15] Extracting A/V streams [VID_00027] - [23:17:16] Reencoding: VID_00027 (7 of 22) - [23:17:16] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 432 frames - [23:17:16] Reencoding: VID_00027, Pass 1 of 1 - [23:17:24] Video Encode complete - [23:17:24] Reencoding audio tracks (if req'd) - [23:17:24] Multiplexing M2TS - [23:17:25] Extracting A/V streams [VID_00052] - [23:17:27] Reencoding: VID_00052 (8 of 22) - [23:17:27] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 1,950 frames - [23:17:27] Reencoding: VID_00052, Pass 1 of 1 - [23:18:17] Video Encode complete - [23:18:17] Reencoding audio tracks (if req'd) - [23:18:18] Multiplexing M2TS - [23:18:19] Extracting A/V streams [VID_00049] - [23:18:21] Reencoding: VID_00049 (9 of 22) - [23:18:21] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 1,965 frames - [23:18:21] Reencoding: VID_00049, Pass 1 of 1 - [23:19:11] Video Encode complete - [23:19:11] Reencoding audio tracks (if req'd) - [23:19:12] Multiplexing M2TS - [23:19:13] Extracting A/V streams [VID_00048] - [23:19:15] Reencoding: VID_00048 (10 of 22) - [23:19:15] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 2,295 frames - [23:19:16] Reencoding: VID_00048, Pass 1 of 1 - [23:20:18] Video Encode complete - [23:20:18] Reencoding audio tracks (if req'd) - [23:20:18] Multiplexing M2TS - [23:20:20] Extracting A/V streams [VID_00051] - [23:20:22] Reencoding: VID_00051 (11 of 22) - [23:20:22] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 2,389 frames - [23:20:22] Reencoding: VID_00051, Pass 1 of 1 - [23:21:24] Video Encode complete - [23:21:24] Reencoding audio tracks (if req'd) - [23:21:25] Multiplexing M2TS - [23:21:26] Extracting A/V streams [VID_00047] - [23:21:29] Reencoding: VID_00047 (12 of 22) - [23:21:29] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 2,571 frames - [23:21:29] Reencoding: VID_00047, Pass 1 of 1 - [23:22:33] Video Encode complete - [23:22:33] Reencoding audio tracks (if req'd) - [23:22:34] Multiplexing M2TS - [23:22:35] Extracting A/V streams [VID_00000] - [23:22:38] Reencoding: VID_00000 (13 of 22) - [23:22:38] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 1,439 frames - [23:22:38] Reencoding: VID_00000, Pass 1 of 1 - [23:23:05] Video Encode complete - [23:23:05] Reencoding audio tracks (if req'd) - [23:23:05] Multiplexing M2TS - [23:23:10] Extracting A/V streams [VID_00050] - [23:23:13] Reencoding: VID_00050 (14 of 22) - [23:23:13] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 2,951 frames - [23:23:13] Reencoding: VID_00050, Pass 1 of 1 - [23:24:31] Video Encode complete - [23:24:31] Reencoding audio tracks (if req'd) - [23:24:32] Multiplexing M2TS - [23:24:33] Extracting A/V streams [VID_00057] - [23:24:37] Reencoding: VID_00057 (15 of 22) - [23:24:37] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 3,208 frames - [23:24:37] Reencoding: VID_00057, Pass 1 of 1 - [23:26:08] Video Encode complete - [23:26:08] Reencoding audio tracks (if req'd) - [23:26:08] Multiplexing M2TS - [23:26:10] Extracting A/V streams [VID_00056] - [23:26:14] Reencoding: VID_00056 (16 of 22) - [23:26:14] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 2,884 frames - [23:26:14] Reencoding: VID_00056, Pass 1 of 1 - [23:27:11] Video Encode complete - [23:27:11] Reencoding audio tracks (if req'd) - [23:27:14] Multiplexing M2TS - [23:27:15] Extracting A/V streams [VID_00055] - [23:27:20] Reencoding: VID_00055 (17 of 22) - [23:27:20] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,432 frames - [23:27:20] Reencoding: VID_00055, Pass 1 of 1 - [23:28:23] Video Encode complete - [23:28:23] Reencoding audio tracks (if req'd) - [23:28:26] Multiplexing M2TS - [23:28:27] Extracting A/V streams [VID_00054] - [23:28:32] Reencoding: VID_00054 (18 of 22) - [23:28:32] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,648 frames - [23:28:32] Reencoding: VID_00054, Pass 1 of 1 - [23:29:40] Video Encode complete - [23:29:40] Reencoding audio tracks (if req'd) - [23:29:43] Multiplexing M2TS - [23:29:45] Extracting A/V streams [VID_00053] - [23:29:51] Reencoding: VID_00053 (19 of 22) - [23:29:51] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23.976fps, 3,504 frames - [23:29:51] Reencoding: VID_00053, Pass 1 of 1 - [23:30:56] Video Encode complete - [23:30:56] Reencoding audio tracks (if req'd) - [23:30:57] Multiplexing M2TS - [23:30:59] Extracting A/V streams [VID_00045] - [23:31:11] Reencoding: VID_00045 (20 of 22) - [23:31:11] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 11,250 frames - [23:31:11] Reencoding: VID_00045, Pass 1 of 1 - [23:36:08] Video Encode complete - [23:36:08] Reencoding audio tracks (if req'd) - [23:36:10] Multiplexing M2TS - [23:36:13] Extracting A/V streams [VID_00046] - [23:36:40] Reencoding: VID_00046 (21 of 22) - [23:36:40] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29.970fps, 27,180 frames - [23:36:40] Reencoding: VID_00046, Pass 1 of 1 - [23:49:02] Video Encode complete - [23:49:02] Reencoding audio tracks (if req'd) - [23:49:08] Multiplexing M2TS - [23:49:35] Extracting A/V streams [VID_00001] - [23:55:28] Reencoding: VID_00001 (22 of 22) - [23:55:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 169,896 frames - Bitrate: 5,822 Kbs - [23:55:28] Reencoding: VID_00001, Pass 1 of 2 - [02:03:46] Reencoding: VID_00001, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3133) - FFDSHOW: VC-1 not set to wmv9 [03:17:43] - Failed video encode, aborted ----------------------- [08:02:39] BD Rebuilder v0.31.06 (beta) - Source: LAW_ABIDING_CITIZEN - Input BD size: 34.20 GB - Approximate total content: [02:40:30.379] - Target BD size: 7.72 GB - Windows Version: 6.0 [6001] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [08:02:45] PHASE ONE, Encoding - [08:02:45] Reencoding: VID_00001 (22 of 22) - [08:02:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 169,896 frames - Bitrate: 5,822 Kbs - [08:02:45] Reencoding: VID_00001, Pass 2 of 2 - [12:07:24] Video Encode complete - [12:07:24] Reencoding audio tracks (if req'd) - [12:09:09] Multiplexing M2TS [12:12:33]PHASE ONE complete [12:12:33]PHASE TWO - Rebuild Started - [12:12:33] Rebuilding BD file Structure [12:12:34] - Encode and Rebuild complete [12:12:34] BURNING BD structure to disc - Burn-to-disc completed successfully [13:13:09]JOB: LAW_ABIDING_CITIZEN finished. Last edited by jdobbs; 15th February 2010 at 14:03. |
15th February 2010, 11:58 | #6898 | Link |
I am running windows 7 64, I installed the components on the first page. I cannot get BD rebuilder to encode the whole movie. No matter what movie I try, the results are the same. The audio is fine, but not video. I get no errors at all, and have tried every setting I can.
[22:03:11] BD Rebuilder v0.31.08 (beta) - Source: IROBOT_US - Input BD size: 38.27 GB - Approximate total content: [04:24:14.613] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:03:11] PHASE ONE, Encoding - [22:03:11] Extracting A/V streams [VID_00001] - [22:08:57] Reencoding: VID_00001 (1 of 26) - [22:08:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 165,033 frames - Bitrate: 13,387 Kbs - [22:08:57] Reencoding: VID_00001, Pass 1 of 2 - [22:08:57] Reencoding: VID_00001, Pass 2 of 2 - [22:34:33] Video Encode complete - [22:34:33] Reencoding audio tracks (if req'd) - [22:34:33] Multiplexing M2TS [22:37:47]PHASE ONE aborted by user request ----------------------- [22:39:13] BD Rebuilder v0.31.08 (beta) - Source: IROBOT_US - Input BD size: 38.27 GB - Approximate total content: [04:24:14.613] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:39:24] PHASE ONE, Encoding - [22:39:24] Extracting A/V streams [VID_00001] - [22:45:08] Reencoding: VID_00001 (1 of 26) - [22:45:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 165,033 frames - Bitrate: 13,387 Kbs - [22:45:08] Reencoding: VID_00001, Pass 1 of 2 [22:47:47]PHASE ONE aborted by user request ----------------------- [22:48:04] BD Rebuilder v0.31.08 (beta) - Source: IROBOT_US - Input BD size: 38.27 GB - Approximate total content: [04:24:14.613] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [22:48:05] PHASE ONE, Encoding - [22:48:05] Reencoding: VID_00001 (1 of 26) - [22:48:05] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 165,033 frames - Bitrate: 13,387 Kbs - [22:48:05] Reencoding: VID_00001, Pass 1 of 2 - [23:51:14] Reencoding: VID_00001, Pass 2 of 2 - [01:58:57] Video Encode complete - [01:58:57] Reencoding audio tracks (if req'd) - [01:58:57] Multiplexing M2TS - [02:04:03] Extracting A/V streams [VID_00002] - [02:04:04] Reencoding: VID_00002 (2 of 26) - [02:04:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 24 frames - Bitrate: 500 Kbs - [02:04:04] Reencoding: VID_00002, Pass 1 of 2 - [02:04:05] Reencoding: VID_00002, Pass 2 of 2 - [02:04:06] Video Encode complete - [02:04:06] Reencoding audio tracks (if req'd) - [02:04:06] Multiplexing M2TS - [02:04:06] Extracting A/V streams [VID_00005] - [02:04:07] Reencoding: VID_00005 (3 of 26) - [02:04:07] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 1,554 frames - Bitrate: 5,685 Kbs - [02:04:07] Reencoding: VID_00005, Pass 1 of 2 - [02:04:23] Reencoding: VID_00005, Pass 2 of 2 - [02:05:04] Video Encode complete - [02:05:04] Reencoding audio tracks (if req'd) - [02:05:04] Multiplexing M2TS - [02:05:05] Extracting A/V streams [VID_00006] - [02:05:12] Reencoding: VID_00006 (4 of 26) - [02:05:12] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 16,588 frames - Bitrate: 5,585 Kbs - [02:05:13] Reencoding: VID_00006, Pass 1 of 2 - [02:07:57] Reencoding: VID_00006, Pass 2 of 2 - [02:16:27] Video Encode complete - [02:16:27] Reencoding audio tracks (if req'd) - [02:16:27] Multiplexing M2TS - [02:16:32] Extracting A/V streams [VID_00007] - [02:16:45] Reencoding: VID_00007 (5 of 26) - [02:16:45] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 26,964 frames - Bitrate: 5,620 Kbs - [02:16:45] Reencoding: VID_00007, Pass 1 of 2 - [02:21:05] Reencoding: VID_00007, Pass 2 of 2 - [02:34:57] Video Encode complete - [02:34:57] Reencoding audio tracks (if req'd) - [02:34:57] Multiplexing M2TS - [02:35:05] Extracting A/V streams [VID_00008] - [02:35:10] Reencoding: VID_00008 (6 of 26) - [02:35:10] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 9,880 frames - Bitrate: 5,441 Kbs - [02:35:10] Reencoding: VID_00008, Pass 1 of 2 - [02:36:45] Reencoding: VID_00008, Pass 2 of 2 - [02:42:44] Video Encode complete - [02:42:44] Reencoding audio tracks (if req'd) - [02:42:44] Multiplexing M2TS - [02:42:47] Extracting A/V streams [VID_00009] - [02:42:53] Reencoding: VID_00009 (7 of 26) - [02:42:53] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 12,136 frames - Bitrate: 5,608 Kbs - [02:42:53] Reencoding: VID_00009, Pass 1 of 2 - [02:44:48] Reencoding: VID_00009, Pass 2 of 2 - [02:51:08] Video Encode complete - [02:51:08] Reencoding audio tracks (if req'd) - [02:51:08] Multiplexing M2TS - [02:51:12] Extracting A/V streams [VID_00010] - [02:51:15] Reencoding: VID_00010 (8 of 26) - [02:51:15] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 6,323 frames - Bitrate: 5,484 Kbs - [02:51:15] Reencoding: VID_00010, Pass 1 of 2 - [02:52:16] Reencoding: VID_00010, Pass 2 of 2 - [02:55:22] Video Encode complete - [02:55:22] Reencoding audio tracks (if req'd) - [02:55:22] Multiplexing M2TS - [02:55:25] Extracting A/V streams [VID_00011] - [02:55:31] Reencoding: VID_00011 (9 of 26) - [02:55:31] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 12,880 frames - Bitrate: 5,344 Kbs - [02:55:31] Reencoding: VID_00011, Pass 1 of 2 - [02:57:36] Reencoding: VID_00011, Pass 2 of 2 - [03:04:05] Video Encode complete - [03:04:05] Reencoding audio tracks (if req'd) - [03:04:05] Multiplexing M2TS - [03:04:09] Extracting A/V streams [VID_00012] - [03:04:20] Reencoding: VID_00012 (10 of 26) - [03:04:20] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 23,710 frames - Bitrate: 5,469 Kbs - [03:04:20] Reencoding: VID_00012, Pass 1 of 2 - [03:08:09] Reencoding: VID_00012, Pass 2 of 2 - [03:14:57] Video Encode complete - [03:14:57] Reencoding audio tracks (if req'd) - [03:14:57] Multiplexing M2TS - [03:15:02] Extracting A/V streams [VID_00013] - [03:15:11] Reencoding: VID_00013 (11 of 26) - [03:15:11] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 19,240 frames - Bitrate: 5,624 Kbs - [03:15:11] Reencoding: VID_00013, Pass 1 of 2 - [03:18:11] Reencoding: VID_00013, Pass 2 of 2 - [03:25:03] Video Encode complete - [03:25:03] Reencoding audio tracks (if req'd) - [03:25:03] Multiplexing M2TS - [03:25:08] Extracting A/V streams [VID_00014] - [03:25:12] Reencoding: VID_00014 (12 of 26) - [03:25:12] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 8,372 frames - Bitrate: 5,577 Kbs - [03:25:12] Reencoding: VID_00014, Pass 1 of 2 - [03:26:35] Reencoding: VID_00014, Pass 2 of 2 - [03:31:18] Video Encode complete - [03:31:18] Reencoding audio tracks (if req'd) - [03:31:18] Multiplexing M2TS - [03:31:21] Extracting A/V streams [VID_00015] - [03:31:21] Reencoding: VID_00015 (13 of 26) - [03:31:21] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 30 frames - Bitrate: 500 Kbs - [03:31:21] Reencoding: VID_00015, Pass 1 of 2 - [03:31:22] Reencoding: VID_00015, Pass 2 of 2 - [03:31:22] Video Encode complete - [03:31:22] Reencoding audio tracks (if req'd) - [03:31:22] Multiplexing M2TS - [03:31:23] Extracting A/V streams [VID_00016] - [03:31:24] Reencoding: VID_00016 (14 of 26) - [03:31:24] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 1,950 frames - Bitrate: 5,650 Kbs - [03:31:24] Reencoding: VID_00016, Pass 1 of 2 - [03:31:44] Reencoding: VID_00016, Pass 2 of 2 - [03:32:32] Video Encode complete - [03:32:32] Reencoding audio tracks (if req'd) - [03:32:32] Multiplexing M2TS - [03:32:34] Extracting A/V streams [VID_00017] - [03:32:39] Reencoding: VID_00017 (15 of 26) - [03:32:39] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 9,655 frames - Bitrate: 6,029 Kbs - [03:32:39] Reencoding: VID_00017, Pass 1 of 2 - [03:34:14] Reencoding: VID_00017, Pass 2 of 2 - [03:38:25] Video Encode complete - [03:38:25] Reencoding audio tracks (if req'd) - [03:38:25] Multiplexing M2TS - [03:38:28] Extracting A/V streams [VID_00018] - [03:38:33] Reencoding: VID_00018 (16 of 26) - [03:38:33] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 11,000 frames - Bitrate: 5,207 Kbs - [03:38:34] Reencoding: VID_00018, Pass 1 of 2 - [03:40:16] Reencoding: VID_00018, Pass 2 of 2 - [03:44:56] Video Encode complete - [03:44:56] Reencoding audio tracks (if req'd) - [03:44:56] Multiplexing M2TS - [03:45:00] Extracting A/V streams [VID_00019] - [03:45:03] Reencoding: VID_00019 (17 of 26) - [03:45:03] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 5,550 frames - Bitrate: 5,751 Kbs - [03:45:03] Reencoding: VID_00019, Pass 1 of 2 - [03:45:57] Reencoding: VID_00019, Pass 2 of 2 - [03:48:23] Video Encode complete - [03:48:23] Reencoding audio tracks (if req'd) - [03:48:23] Multiplexing M2TS - [03:48:25] Extracting A/V streams [VID_00020] - [03:48:31] Reencoding: VID_00020 (18 of 26) - [03:48:31] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 10,465 frames - Bitrate: 5,684 Kbs - [03:48:31] Reencoding: VID_00020, Pass 1 of 2 - [03:49:55] Reencoding: VID_00020, Pass 2 of 2 - [03:55:01] Video Encode complete - [03:55:01] Reencoding audio tracks (if req'd) - [03:55:01] Multiplexing M2TS - [03:55:04] Extracting A/V streams [VID_00021] - [03:55:06] Reencoding: VID_00021 (19 of 26) - [03:55:06] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 1,650 frames - Bitrate: 5,694 Kbs - [03:55:06] Reencoding: VID_00021, Pass 1 of 2 - [03:55:23] Reencoding: VID_00021, Pass 2 of 2 - [03:56:06] Video Encode complete - [03:56:06] Reencoding audio tracks (if req'd) - [03:56:06] Multiplexing M2TS - [03:56:07] Extracting A/V streams [VID_00022] - [03:56:35] Reencoding: VID_00022 (20 of 26) - [03:56:35] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 61,865 frames - Bitrate: 5,453 Kbs - [03:56:35] Reencoding: VID_00022, Pass 1 of 2 - [04:06:17] Reencoding: VID_00022, Pass 2 of 2 - [04:20:06] Video Encode complete - [04:20:06] Reencoding audio tracks (if req'd) - [04:20:06] Multiplexing M2TS - [04:20:17] Extracting A/V streams [VID_00023] - [04:20:18] Reencoding: VID_00023 (21 of 26) - [04:20:18] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 1,135 frames - Bitrate: 2,918 Kbs - [04:20:18] Reencoding: VID_00023, Pass 1 of 2 - [04:20:25] Reencoding: VID_00023, Pass 2 of 2 - [04:20:46] Video Encode complete - [04:20:46] Reencoding audio tracks (if req'd) - [04:20:46] Multiplexing M2TS - [04:20:47] Extracting A/V streams [VID_00024] - [04:20:49] Reencoding: VID_00024 (22 of 26) - [04:20:49] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 3,205 frames - Bitrate: 5,489 Kbs - [04:20:49] Reencoding: VID_00024, Pass 1 of 2 - [04:21:16] Reencoding: VID_00024, Pass 2 of 2 - [04:22:34] Video Encode complete - [04:22:34] Reencoding audio tracks (if req'd) - [04:22:34] Multiplexing M2TS - [04:22:36] Extracting A/V streams [VID_00025] - [04:22:40] Reencoding: VID_00025 (23 of 26) - [04:22:40] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 7,340 frames - Bitrate: 5,468 Kbs - [04:22:40] Reencoding: VID_00025, Pass 1 of 2 - [04:23:44] Reencoding: VID_00025, Pass 2 of 2 - [04:26:23] Video Encode complete - [04:26:23] Reencoding audio tracks (if req'd) - [04:26:23] Multiplexing M2TS - [04:26:26] Extracting A/V streams [VID_00026] - [04:26:29] Reencoding: VID_00026 (24 of 26) - [04:26:29] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 5,116 frames - Bitrate: 6,099 Kbs - [04:26:29] Reencoding: VID_00026, Pass 1 of 2 - [04:27:15] Reencoding: VID_00026, Pass 2 of 2 - [04:29:22] Video Encode complete - [04:29:22] Reencoding audio tracks (if req'd) - [04:29:22] Multiplexing M2TS - [04:29:24] Extracting A/V streams [VID_00027] - [04:29:24] Reencoding: VID_00027 (25 of 26) - [04:29:24] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 30 frames - Bitrate: 500 Kbs - [04:29:24] Reencoding: VID_00027, Pass 1 of 2 - [04:29:25] Reencoding: VID_00027, Pass 2 of 2 - [04:29:25] Video Encode complete - [04:29:25] Reencoding audio tracks (if req'd) - [04:29:25] Multiplexing M2TS - [04:29:25] Extracting A/V streams [VID_00028] - [04:29:32] Reencoding: VID_00028 (26 of 26) - [04:29:32] Collecting video information - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 12,204 frames - Bitrate: 5,696 Kbs - [04:29:32] Reencoding: VID_00028, Pass 1 of 2 - [04:31:18] Reencoding: VID_00028, Pass 2 of 2 - [04:35:37] Video Encode complete - [04:35:37] Reencoding audio tracks (if req'd) - [04:35:37] Multiplexing M2TS [04:35:41]PHASE ONE complete [04:35:41]PHASE TWO - Rebuild Started - [04:35:41] Rebuilding BD file Structure [04:35:48] - Encode and Rebuild complete - WORKFILES folder removed. [04:35:48]JOB: IROBOT_US finished. Last edited by jdobbs; 15th February 2010 at 14:04. |
15th February 2010, 14:08 | #6899 | Link |
@Raul124
Not all players are compatible with full backups to BD-5/9, in fact the list of those that do is pretty small. You may want to check this thread. Movie-Only backups (AVCHD) to BD-5/9 will work on most players. @hvacr.tech What version of AVISYNTH are you using? Make sure it is the one from the first post of this thread. Last edited by jdobbs; 15th February 2010 at 14:16. |
15th February 2010, 15:39 | #6900 | Link | |
