1st August 2010, 00:59 | #8963 | Link | |
Programmer
Why even convert it to AC3? Is it just to keep for backward compatibility so that a older laptop or PC can play the audio? What is the procedure or settings if I always want to keep the English TrueHD or DTS-MA HD Audio but drop all other stuff like LPCM or the additional AC3 core included extra with TrueHD? |
1st August 2010, 01:32 | #8964 | Link |
I implemented that as a result of a request. Not all discs have DTS-MA or TrueHD as a choice, and they wouldn't necessarily have the same audio content as the LPCM. There are also discs that have only LPCM (like some concert discs). But most importantly the concept is to have a choice to "Keep HD, unless it's LPCM", because LPCM is so wasteful. That way you can set it and forget it. By the way, note that it only applies when you have also selected "Keep HD audio for BD-25".
Of course you can drop it if you want just by deselecting the track. To keep only the main audio and drop others -- in the SETUP dialog just say to leep only "English" (for example), and also click "Limit to one track for each Language" -- that way it would only keep the first English track. Last edited by jdobbs; 1st August 2010 at 01:39. |
1st August 2010, 03:22 | #8965 | Link | |
Programmer
1st August 2010, 03:46 | #8966 | Link | |
1st August 2010, 04:27 | #8967 | Link |
Special SeeD
Weird, using version 34.05 produce no secondary video stream if i use the "SECONDARY_USE_QUALITY=1", i get a 0 Kbps .264 file. If i use "SECONDARY_USE_QUALITY=0" everything goes fine. x264 shows a error but the window is closed so fast that I am unable to watch the error text.
Any idea what is happening: Code:
[Options] RESIZE=0 MODE=0 ENCODE_QUALITY=0 PRIORITY_CLASS=1 TARGET_SIZE=24000 VERBOSE_STATUS=1 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all TRELLIS=1 KEEP_INTERLACING=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 DISABLE_FFMS=0 FIXED_CRF=20 SECONDARY_CRF=20 SHOW_ENCODER=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24000 QUICK_EXTRAS=0 CRF_ENCODING=0 TWEAK_PASS_ONE= TWEAK_PASS_TWO= SECONDARY_USE_QUALITY=1 SD_CONVERT=0 B_PYRAMID=1 ONEPASS_ENCODING=2 FULL_AVCHD=0 AUTO_QUALITY=0 DEINTERLACE=0 AC3_192=0 REMOVE_OUTPUT=0 OPEN_GOP=1 USE_FILTERS=0 MOVIE_ONLY_LOOP=0 [Paths] SOURCE_PATH=J:\BLU-RAYS\PRINCESSANDTHEFROG\ WORKING_PATH=D:\TEMP\MOVTEMP\D2VAVS\ Code:
[22:15:44] BD Rebuilder v0.34.05 (beta) - Source: PRINCESSANDTHEFROG - Input BD size: 45.00 GB - Approximate total content: [03:43:39.446] - Target BD size: 23.44 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [22:15:51] PHASE ONE, Encoding - [22:15:51] Extracting A/V streams [VID_00067] - [22:15:56] Reencoding: VID_00067 (1 of 132) - [22:15:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,626 frames - Bitrate: 7,573 Kbs - [22:15:56] Reencoding: VID_00067, Pass 1 of 1 - [22:16:56] Video Encode complete - [22:16:56] Reencoding audio tracks (if req'd) - [22:16:56] Multiplexing M2TS - [22:16:59] Extracting A/V streams [VID_00100] - [22:17:40] Reencoding: VID_00100 (2 of 132) - [22:17:40] Reencoding secondary video [TRK_02] - [22:17:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,088 frames - Bitrate: 12,069 Kbs - [22:17:40] Reencoding: VID_00100, Pass 1 of 1 [22:18:12]PHASE ONE aborted by user request Last edited by SquallMX; 1st August 2010 at 04:30. |
1st August 2010, 07:38 | #8969 | Link | |
Programmer
UPDATE: Ok, I see in cmd window it uses Aften encoder Last edited by jfcarbel; 1st August 2010 at 11:59. |
1st August 2010, 15:36 | #8971 | Link | |
My latest full backup to BD9 with "Use open GOP for Encoding" does not display any more of these type of errors. |
1st August 2010, 16:18 | #8972 | Link | |
Wondering About Audio Sync
1st August 2010, 17:02 | #8973 | Link |
Hi when trying to do Clash of the Titans (2010) i get the following error
[19:42:00] BD Rebuilder v0.34.05 (beta) - Source: CLASH_OF_THE_TITANS - Input BD size: 38.98 GB - Approximate total content: [03:51:38.175] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - Quality: - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [19:42:06] PHASE ONE, Encoding - [19:42:06] Extracting A/V streams [VID_00019] - [19:42:09] Reencoding: VID_00019 (1 of 34) - [19:42:09] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,309 frames - [19:42:09] Reencoding: VID_00019, Pass 1 of 1 - [19:43:09] Video Encode complete - [19:43:09] Reencoding audio tracks (if req'd) - [19:43:09] Multiplexing M2TS - [19:43:12] Extracting A/V streams [VID_00023] - [19:43:16] Reencoding: VID_00023 (2 of 34) - [19:43:16] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,637 frames - [19:43:16] Reencoding: VID_00023, Pass 1 of 1 - [19:44:29] Video Encode complete - [19:44:29] Reencoding audio tracks (if req'd) - [19:44:29] Multiplexing M2TS - [19:44:33] Extracting A/V streams [VID_00018] - [19:44:39] Reencoding: VID_00018 (3 of 34) - [19:44:39] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,243 frames - [19:44:39] Reencoding: VID_00018, Pass 1 of 1 - [19:46:11] Video Encode complete - [19:46:11] Reencoding audio tracks (if req'd) - [19:46:11] Multiplexing M2TS - [19:46:14] Extracting A/V streams [VID_00024] - [19:46:19] Reencoding: VID_00024 (4 of 34) - [19:46:19] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,034 frames - [19:46:19] Reencoding: VID_00024, Pass 1 of 1 - [19:48:06] Video Encode complete - [19:48:06] Reencoding audio tracks (if req'd) - [19:48:06] Multiplexing M2TS - [19:48:10] Extracting A/V streams [VID_00046] - [19:48:17] Reencoding: VID_00046 (5 of 34) - [19:48:17] Reencoding secondary video [TRK_02] - [19:48:32] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,279 frames - [19:48:32] Reencoding: VID_00046, Pass 1 of 1 - [19:50:02] Video Encode complete - [19:50:02] Reencoding audio tracks (if req'd) - [19:50:02] Multiplexing M2TS - [19:50:05] Extracting A/V streams [VID_00016] - [19:50:10] Reencoding: VID_00016 (6 of 34) - [19:50:10] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,354 frames - [19:50:10] Reencoding: VID_00016, Pass 1 of 1 - [19:52:07] Video Encode complete - [19:52:07] Reencoding audio tracks (if req'd) - [19:52:07] Multiplexing M2TS - [19:52:12] Extracting A/V streams [VID_00022] - [19:52:17] Reencoding: VID_00022 (7 of 34) - [19:52:17] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,477 frames - [19:52:17] Reencoding: VID_00022, Pass 1 of 1 - [19:54:19] Video Encode complete - [19:54:19] Reencoding audio tracks (if req'd) - [19:54:19] Multiplexing M2TS - [19:54:24] Extracting A/V streams [VID_00009] - [19:54:29] Reencoding: VID_00009 (8 of 34) - [19:54:29] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,453 frames - [19:54:29] Reencoding: VID_00009, Pass 1 of 1 - [19:56:26] Video Encode complete - [19:56:26] Reencoding audio tracks (if req'd) - [19:56:26] Multiplexing M2TS - [19:56:31] Extracting A/V streams [VID_00036] - [19:56:38] Reencoding: VID_00036 (9 of 34) - [19:56:38] Reencoding secondary video [TRK_02] - [19:56:52] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,279 frames - Bitrate: 8,619 Kbs - [19:56:52] Reencoding: VID_00036, Pass 1 of 2 - [19:58:52] Reencoding: VID_00036, Pass 2 of 2 - [20:03:50] Video Encode complete - [20:03:50] Reencoding audio tracks (if req'd) - [20:03:50] Multiplexing M2TS - [20:03:55] Extracting A/V streams [VID_00017] - [20:04:01] Reencoding: VID_00017 (10 of 34) - [20:04:01] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,642 frames - [20:04:01] Reencoding: VID_00017, Pass 1 of 1 - [20:05:43] Video Encode complete - [20:05:43] Reencoding audio tracks (if req'd) - [20:05:43] Multiplexing M2TS - [20:05:48] Extracting A/V streams [VID_00021] - [20:05:54] Reencoding: VID_00021 (11 of 34) - [20:05:54] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,911 frames - [20:05:54] Reencoding: VID_00021, Pass 1 of 1 - [20:07:54] Video Encode complete - [20:07:54] Reencoding audio tracks (if req'd) - [20:07:54] Multiplexing M2TS - [20:07:59] Extracting A/V streams [VID_00020] - [20:08:07] Reencoding: VID_00020 (12 of 34) - [20:08:07] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,350 frames - [20:08:07] Reencoding: VID_00020, Pass 1 of 1 - [20:10:27] Video Encode complete - [20:10:27] Reencoding audio tracks (if req'd) - [20:10:27] Multiplexing M2TS - [20:10:32] Extracting A/V streams [VID_00038] - [20:10:39] Reencoding: VID_00038 (13 of 34) - [20:10:39] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 7,749 frames - [20:10:39] Reencoding: VID_00038, Pass 1 of 1 - [20:13:21] Video Encode complete - [20:13:21] Reencoding audio tracks (if req'd) - [20:13:21] Multiplexing M2TS - [20:13:25] Extracting A/V streams [VID_00025] - [20:13:36] Reencoding: VID_00025 (14 of 34) - [20:13:36] Reencoding secondary video [TRK_02] - [20:14:02] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,064 frames - Bitrate: 16,329 Kbs - [20:14:02] Reencoding: VID_00025, Pass 1 of 2 - [20:16:52] Reencoding: VID_00025, Pass 2 of 2 - [20:26:19] Video Encode complete - [20:26:19] Reencoding audio tracks (if req'd) - [20:26:19] Multiplexing M2TS - [20:26:26] Extracting A/V streams [VID_00043] - [20:26:37] Reencoding: VID_00043 (15 of 34) - [20:26:37] Reencoding secondary video [TRK_02] - [20:27:03] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,018 frames - [20:27:03] Reencoding: VID_00043, Pass 1 of 1 - [20:29:32] Video Encode complete - [20:29:33] Reencoding audio tracks (if req'd) - [20:29:33] Multiplexing M2TS - [20:29:37] Extracting A/V streams [VID_00033] - [20:29:48] Reencoding: VID_00033 (16 of 34) - [20:29:48] Reencoding secondary video [TRK_02] - [20:30:03] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,981 frames - Bitrate: 18,350 Kbs - [20:30:03] Reencoding: VID_00033, Pass 1 of 2 - [20:32:24] Reencoding: VID_00033, Pass 2 of 2 - [20:40:58] Video Encode complete - [20:40:58] Reencoding audio tracks (if req'd) - [20:40:58] Multiplexing M2TS - [20:41:05] Extracting A/V streams [VID_00040] - [20:41:15] Reencoding: VID_00040 (17 of 34) - [20:41:15] Reencoding secondary video [TRK_02] - [20:41:35] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,112 frames - [20:41:35] Reencoding: VID_00040, Pass 1 of 1 - [20:43:55] Video Encode complete - [20:43:55] Reencoding audio tracks (if req'd) - [20:43:55] Multiplexing M2TS - [20:43:57] Extracting A/V streams [VID_00035] - [20:44:08] Reencoding: VID_00035 (18 of 34) - [20:44:08] Reencoding secondary video [TRK_02] - [20:44:33] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,759 frames - Bitrate: 11,937 Kbs - [20:44:33] Reencoding: VID_00035, Pass 1 of 2 - [20:47:11] Reencoding: VID_00035, Pass 2 of 2 - [20:55:32] Video Encode complete - [20:55:32] Reencoding audio tracks (if req'd) - [20:55:32] Multiplexing M2TS - [20:55:40] Extracting A/V streams [VID_00045] - [20:55:52] Reencoding: VID_00045 (19 of 34) - [20:55:52] Reencoding secondary video [TRK_02] - [20:56:14] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,729 frames - [20:56:14] Reencoding: VID_00045, Pass 1 of 1 - [20:58:41] Video Encode complete - [20:58:41] Reencoding audio tracks (if req'd) - [20:58:41] Multiplexing M2TS - [20:58:46] Extracting A/V streams [VID_00047] - [20:58:56] Reencoding: VID_00047 (20 of 34) - [20:58:56] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 11,416 frames - [20:58:56] Reencoding: VID_00047, Pass 1 of 1 - [21:02:26] Video Encode complete - [21:02:26] Reencoding audio tracks (if req'd) - [21:02:26] Multiplexing M2TS - [21:02:36] Extracting A/V streams [VID_00029] - [21:02:48] Reencoding: VID_00029 (21 of 34) - [21:02:48] Reencoding secondary video [TRK_02] - [21:03:13] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,794 frames - Bitrate: 15,102 Kbs - [21:03:13] Reencoding: VID_00029, Pass 1 of 2 - [21:06:28] Reencoding: VID_00029, Pass 2 of 2 - [21:16:51] Video Encode complete - [21:16:51] Reencoding audio tracks (if req'd) - [21:16:51] Multiplexing M2TS - [21:16:59] Extracting A/V streams [VID_00030] - [21:17:11] Reencoding: VID_00030 (22 of 34) - [21:17:11] Reencoding secondary video [TRK_02] - [21:17:32] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,018 frames - Bitrate: 15,550 Kbs - [21:17:32] Reencoding: VID_00030, Pass 1 of 2 - [21:20:56] Reencoding: VID_00030, Pass 2 of 2 - [21:31:46] Video Encode complete - [21:31:46] Reencoding audio tracks (if req'd) - [21:31:46] Multiplexing M2TS - [21:31:54] Extracting A/V streams [VID_00037] - [21:32:07] Reencoding: VID_00037 (23 of 34) - [21:32:07] Reencoding secondary video [TRK_02] - [21:32:57] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,961 frames - Bitrate: 2,600 Kbs - [21:32:57] Reencoding: VID_00037, Pass 1 of 2 - [21:37:24] Reencoding: VID_00037, Pass 2 of 2 - [21:44:03] Video Encode complete - [21:44:03] Reencoding audio tracks (if req'd) - [21:44:03] Multiplexing M2TS - [21:44:18] Extracting A/V streams [VID_00001] - [21:44:32] Reencoding: VID_00001 (24 of 34) - [21:44:32] Reencoding secondary video [TRK_02] - [21:44:53] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,111 frames - Bitrate: 17,374 Kbs - [21:44:53] Reencoding: VID_00001, Pass 1 of 2 - [21:48:25] Reencoding: VID_00001, Pass 2 of 2 - [22:00:26] Video Encode complete - [22:00:26] Reencoding audio tracks (if req'd) - [22:00:26] Multiplexing M2TS - [22:00:35] Extracting A/V streams [VID_00034] - [22:00:50] Reencoding: VID_00034 (25 of 34) - [22:00:50] Reencoding secondary video [TRK_02] - [22:01:10] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 6,032 frames - Bitrate: 19,096 Kbs - [22:01:10] Reencoding: VID_00034, Pass 1 of 2 - [22:04:37] Reencoding: VID_00034, Pass 2 of 2 - [22:18:27] Video Encode complete - [22:18:27] Reencoding audio tracks (if req'd) - [22:18:27] Multiplexing M2TS - [22:18:37] Extracting A/V streams [VID_00031] - [22:18:54] Reencoding: VID_00031 (26 of 34) - [22:18:54] Reencoding secondary video [TRK_02] - [22:19:39] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 9,129 frames - Bitrate: 15,779 Kbs - [22:19:39] Reencoding: VID_00031, Pass 1 of 2 - [22:24:48] Reencoding: VID_00031, Pass 2 of 2 - [22:41:33] Video Encode complete - [22:41:33] Reencoding audio tracks (if req'd) - [22:41:33] Multiplexing M2TS - [22:41:45] Extracting A/V streams [VID_00041] - [22:42:08] Reencoding: VID_00041 (27 of 34) - [22:42:08] Reencoding secondary video [TRK_02] - [22:42:59] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,937 frames - Bitrate: 12,705 Kbs - [22:42:59] Reencoding: VID_00041, Pass 1 of 2 - [22:50:52] Reencoding: VID_00041, Pass 2 of 2 - [23:15:08] Video Encode complete - [23:15:08] Reencoding audio tracks (if req'd) - [23:15:08] Multiplexing M2TS - [23:15:22] Extracting A/V streams [VID_00048] - [23:15:44] Reencoding: VID_00048 (28 of 34) - [23:15:44] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 26,153 frames - Bitrate: 8,018 Kbs - [23:15:44] Reencoding: VID_00048, Pass 1 of 2 - [23:29:38] Reencoding: VID_00048, Pass 2 of 2 - [00:05:08] Video Encode complete - [00:05:08] Reencoding audio tracks (if req'd) - [00:05:08] Multiplexing M2TS - [00:05:23] Extracting A/V streams [VID_00026] - [00:05:51] Reencoding: VID_00026 (29 of 34) - [00:05:51] Reencoding secondary video [TRK_02] - [00:06:43] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,937 frames - Bitrate: 15,271 Kbs - [00:06:43] Reencoding: VID_00026, Pass 1 of 2 - [00:15:13] Reencoding: VID_00026, Pass 2 of 2 - [00:42:18] Video Encode complete - [00:42:18] Reencoding audio tracks (if req'd) - [00:42:18] Multiplexing M2TS - [00:42:46] Extracting A/V streams [VID_00042] - [00:43:17] Reencoding: VID_00042 (30 of 34) - [00:43:17] Reencoding secondary video [TRK_02] - [00:44:25] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 19,885 frames - Bitrate: 12,680 Kbs - [00:44:25] Reencoding: VID_00042, Pass 1 of 2 - [00:55:00] Reencoding: VID_00042, Pass 2 of 2 - [01:26:52] Video Encode complete - [01:26:52] Reencoding audio tracks (if req'd) - [01:26:52] Multiplexing M2TS - [01:27:13] Extracting A/V streams [VID_00028] - [01:27:49] Reencoding: VID_00028 (31 of 34) - [01:27:49] Reencoding secondary video [TRK_02] - [01:28:54] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 17,937 frames - Bitrate: 16,804 Kbs - [01:28:54] Reencoding: VID_00028, Pass 1 of 2 - [01:38:55] Reencoding: VID_00028, Pass 2 of 2 - [02:12:29] Video Encode complete - [02:12:29] Reencoding audio tracks (if req'd) - [02:12:29] Multiplexing M2TS - [02:12:51] Extracting A/V streams [VID_00044] - [02:13:34] Reencoding: VID_00044 (32 of 34) - [02:13:34] Reencoding secondary video [TRK_02] - [02:15:09] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 27,866 frames - Bitrate: 12,625 Kbs - [02:15:09] Reencoding: VID_00044, Pass 1 of 2 - [02:29:59] Reencoding: VID_00044, Pass 2 of 2 - [03:17:15] Video Encode complete - [03:17:15] Reencoding audio tracks (if req'd) - [03:17:15] Multiplexing M2TS - Error in attempt to multiplex: MUX_00044.meta - Can't open file: D:\2\WORKFILES\00044.track_6656.DTS [03:17:16] - Failed to build structure, aborted - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.5, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok i am now going to try with 34.04 any help appreciated p.s i tried twice same error ripped with anydvdHD 6.6.8.0 Last edited by jdobbs; 1st August 2010 at 18:52. |
1st August 2010, 17:12 | #8974 | Link |
Ok jdobbs, if got a mystery for ya. First "problem" ever. The problem is simple. Disc recoded successfully into an ISO and has a dual feature. The same movie in theatrical and extended version. In both the panasonic BD60 & BD85 at the screen where you have to select wich version, the problem begins. After you select wich one you like to watch, the angles start to loop that show the copyright notice etc, over and over again. However in PowerDVD after i select the version, the movie starts as it should, in BOTH cases. Don't know if it matter but the disc does not contain java.
I've got no idea why the standalone's don't play it but powerdvd 10 does Code:
[20:50:41] BD Rebuilder v0.34.05 (beta) - Source: ALIEN_VS_PREDATOR_F2 - Input BD size: 30,77 GB - Approximate total content: [02:06:39.007] - Target BD size: 22,66 GB - Windows Version: 6.0 [6002] - Quality: - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:50:44] PHASE ONE, Encoding - [20:50:44] Extracting A/V streams [VID_00000] - [20:50:58] Reencoding: VID_00000 (1 of 40) - [20:50:58] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.407 frames - Bitrate: 15.091 Kbs - [20:50:58] Reencoding: VID_00000, Pass 1 of 2 - [20:52:44] Reencoding: VID_00000, Pass 2 of 2 - [20:58:34] Video Encode complete - [20:58:34] Reencoding audio tracks (if req'd) - [20:58:34] Multiplexing M2TS - [20:58:44] Extracting A/V streams [VID_00001] - [20:59:00] Reencoding: VID_00001 (2 of 40) - [20:59:00] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 5.903 frames - Bitrate: 14.690 Kbs - [20:59:00] Reencoding: VID_00001, Pass 1 of 2 - [21:01:56] Reencoding: VID_00001, Pass 2 of 2 - [21:12:01] Video Encode complete - [21:12:01] Reencoding audio tracks (if req'd) - [21:12:01] Multiplexing M2TS - [21:12:20] Extracting A/V streams [VID_00002] - [21:12:32] Reencoding: VID_00002 (3 of 40) - [21:12:32] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.440 frames - Bitrate: 20.510 Kbs - [21:12:32] Reencoding: VID_00002, Pass 1 of 2 - [21:14:03] Reencoding: VID_00002, Pass 2 of 2 - [21:19:26] Video Encode complete - [21:19:26] Reencoding audio tracks (if req'd) - [21:19:26] Multiplexing M2TS - [21:19:36] Extracting A/V streams [VID_00003] - [21:19:41] Reencoding: VID_00003 (4 of 40) - [21:19:41] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.060 frames - Bitrate: 20.160 Kbs - [21:19:41] Reencoding: VID_00003, Pass 1 of 2 - [21:25:31] Reencoding: VID_00003, Pass 2 of 2 - [21:27:42] Video Encode complete - [21:27:42] Reencoding audio tracks (if req'd) - [21:27:42] Multiplexing M2TS - [21:27:47] Extracting A/V streams [VID_00004] - [21:27:53] Reencoding: VID_00004 (5 of 40) - [21:27:53] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.406 frames - Bitrate: 19.633 Kbs - [21:27:53] Reencoding: VID_00004, Pass 1 of 2 - [21:28:47] Reencoding: VID_00004, Pass 2 of 2 - [21:31:41] Video Encode complete - [21:31:41] Reencoding audio tracks (if req'd) - [21:31:41] Multiplexing M2TS - [21:31:46] Extracting A/V streams [VID_00005] - [21:31:57] Reencoding: VID_00005 (6 of 40) - [21:31:57] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.626 frames - Bitrate: 20.025 Kbs - [21:31:57] Reencoding: VID_00005, Pass 1 of 2 - [21:33:32] Reencoding: VID_00005, Pass 2 of 2 - [21:39:27] Video Encode complete - [21:39:27] Reencoding audio tracks (if req'd) - [21:39:27] Multiplexing M2TS - [21:39:36] Extracting A/V streams [VID_00006] - [21:39:40] Reencoding: VID_00006 (7 of 40) - [21:39:40] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 737 frames - Bitrate: 17.350 Kbs - [21:39:40] Reencoding: VID_00006, Pass 1 of 2 - [21:40:07] Reencoding: VID_00006, Pass 2 of 2 - [21:41:34] Video Encode complete - [21:41:34] Reencoding audio tracks (if req'd) - [21:41:34] Multiplexing M2TS - [21:41:38] Extracting A/V streams [VID_00007] - [21:41:45] Reencoding: VID_00007 (8 of 40) - [21:41:45] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.204 frames - Bitrate: 16.227 Kbs - [21:41:45] Reencoding: VID_00007, Pass 1 of 2 - [21:43:02] Reencoding: VID_00007, Pass 2 of 2 - [21:47:14] Video Encode complete - [21:47:14] Reencoding audio tracks (if req'd) - [21:47:14] Multiplexing M2TS - [21:47:22] Extracting A/V streams [VID_00008] - [21:49:31] Reencoding: VID_00008 (9 of 40) - [21:49:31] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 34.491 frames - Bitrate: 20.090 Kbs - [21:49:31] Reencoding: VID_00008, Pass 1 of 2 - [22:08:07] Reencoding: VID_00008, Pass 2 of 2 - [23:24:48] Video Encode complete - [23:24:48] Reencoding audio tracks (if req'd) - [23:24:48] Multiplexing M2TS - [23:28:23] Extracting A/V streams [VID_00011] - [23:28:25] Reencoding: VID_00011 (10 of 40) - [23:28:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 740 frames - Bitrate: 18.027 Kbs - [23:28:25] Reencoding: VID_00011, Pass 1 of 2 - [23:28:52] Reencoding: VID_00011, Pass 2 of 2 - [23:30:31] Video Encode complete - [23:30:31] Reencoding audio tracks (if req'd) - [23:30:31] Multiplexing M2TS - [23:30:35] Extracting A/V streams [VID_00012] - [23:30:38] Reencoding: VID_00012 (11 of 40) - [23:30:38] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 766 frames - Bitrate: 18.202 Kbs - [23:30:38] Reencoding: VID_00012, Pass 1 of 2 - [23:31:04] Reencoding: VID_00012, Pass 2 of 2 - [23:32:45] Video Encode complete - [23:32:45] Reencoding audio tracks (if req'd) - [23:32:45] Multiplexing M2TS - [23:32:47] Extracting A/V streams [VID_00013] - [23:33:04] Reencoding: VID_00013 (12 of 40) - [23:33:04] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.753 frames - Bitrate: 20.743 Kbs - [23:33:04] Reencoding: VID_00013, Pass 1 of 2 - [23:35:10] Reencoding: VID_00013, Pass 2 of 2 - [23:43:47] Video Encode complete - [23:43:47] Reencoding audio tracks (if req'd) - [23:43:47] Multiplexing M2TS - [23:44:14] Extracting A/V streams [VID_00015] - [23:44:25] Reencoding: VID_00015 (13 of 40) - [23:44:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.492 frames - Bitrate: 21.325 Kbs - [23:44:25] Reencoding: VID_00015, Pass 1 of 2 - [23:45:50] Reencoding: VID_00015, Pass 2 of 2 - [23:51:31] Video Encode complete - [23:51:31] Reencoding audio tracks (if req'd) - [23:51:31] Multiplexing M2TS - [23:51:46] Extracting A/V streams [VID_00016] - [23:51:58] Reencoding: VID_00016 (14 of 40) - [23:51:58] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.999 frames - Bitrate: 19.209 Kbs - [23:51:58] Reencoding: VID_00016, Pass 1 of 2 - [23:53:45] Reencoding: VID_00016, Pass 2 of 2 - [00:00:12] Video Encode complete - [00:00:12] Reencoding audio tracks (if req'd) - [00:00:12] Multiplexing M2TS - [00:00:26] Extracting A/V streams [VID_00017] - [00:00:29] Reencoding: VID_00017 (15 of 40) - [00:00:29] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 476 frames - Bitrate: 17.693 Kbs - [00:00:29] Reencoding: VID_00017, Pass 1 of 2 - [00:00:46] Reencoding: VID_00017, Pass 2 of 2 - [00:01:46] Video Encode complete - [00:01:46] Reencoding audio tracks (if req'd) - [00:01:46] Multiplexing M2TS - [00:01:48] Extracting A/V streams [VID_00018] - [00:01:50] Reencoding: VID_00018 (16 of 40) - [00:01:50] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 515 frames - Bitrate: 17.027 Kbs - [00:01:50] Reencoding: VID_00018, Pass 1 of 2 - [00:02:08] Reencoding: VID_00018, Pass 2 of 2 - [00:03:09] Video Encode complete - [00:03:09] Reencoding audio tracks (if req'd) - [00:03:09] Multiplexing M2TS - [00:03:11] Extracting A/V streams [VID_00019] - [00:03:52] Reencoding: VID_00019 (17 of 40) - [00:03:52] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 10.770 frames - Bitrate: 20.284 Kbs - [00:03:52] Reencoding: VID_00019, Pass 1 of 2 - [00:09:38] Reencoding: VID_00019, Pass 2 of 2 - [00:34:43] Video Encode complete - [00:34:43] Reencoding audio tracks (if req'd) - [00:34:43] Multiplexing M2TS - [00:35:42] Extracting A/V streams [VID_00020] - [00:35:46] Reencoding: VID_00020 (18 of 40) - [00:35:46] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 964 frames - Bitrate: 18.869 Kbs - [00:35:46] Reencoding: VID_00020, Pass 1 of 2 - [00:36:16] Reencoding: VID_00020, Pass 2 of 2 - [00:38:22] Video Encode complete - [00:38:22] Reencoding audio tracks (if req'd) - [00:38:22] Multiplexing M2TS - [00:38:26] Extracting A/V streams [VID_00021] - [00:38:31] Reencoding: VID_00021 (19 of 40) - [00:38:31] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.322 frames - Bitrate: 18.045 Kbs - [00:38:31] Reencoding: VID_00021, Pass 1 of 2 - [00:39:11] Reencoding: VID_00021, Pass 2 of 2 - [00:41:57] Video Encode complete - [00:41:57] Reencoding audio tracks (if req'd) - [00:41:57] Multiplexing M2TS - [00:42:01] Extracting A/V streams [VID_00022] - [00:42:16] Reencoding: VID_00022 (20 of 40) - [00:42:16] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.266 frames - Bitrate: 22.077 Kbs - [00:42:16] Reencoding: VID_00022, Pass 1 of 2 - [00:43:55] Reencoding: VID_00022, Pass 2 of 2 - [00:51:20] Video Encode complete - [00:51:20] Reencoding audio tracks (if req'd) - [00:51:20] Multiplexing M2TS - [00:51:34] Extracting A/V streams [VID_00023] - [00:51:46] Reencoding: VID_00023 (21 of 40) - [00:51:46] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.716 frames - Bitrate: 19.398 Kbs - [00:51:46] Reencoding: VID_00023, Pass 1 of 2 - [00:53:08] Reencoding: VID_00023, Pass 2 of 2 - [00:59:00] Video Encode complete - [00:59:00] Reencoding audio tracks (if req'd) - [00:59:00] Multiplexing M2TS - [00:59:10] Extracting A/V streams [VID_00024] - [00:59:25] Reencoding: VID_00024 (22 of 40) - [00:59:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 4.776 frames - Bitrate: 17.405 Kbs - [00:59:25] Reencoding: VID_00024, Pass 1 of 2 - [01:01:50] Reencoding: VID_00024, Pass 2 of 2 - [01:11:48] Video Encode complete - [01:11:48] Reencoding audio tracks (if req'd) - [01:11:48] Multiplexing M2TS - [01:12:04] Extracting A/V streams [VID_00025] - [01:12:25] Reencoding: VID_00025 (23 of 40) - [01:12:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 5.121 frames - Bitrate: 20.534 Kbs - [01:12:25] Reencoding: VID_00025, Pass 1 of 2 - [01:15:06] Reencoding: VID_00025, Pass 2 of 2 - [01:26:56] Video Encode complete - [01:26:56] Reencoding audio tracks (if req'd) - [01:26:56] Multiplexing M2TS - [01:27:17] Extracting A/V streams [VID_00026] - [01:27:23] Reencoding: VID_00026 (24 of 40) - [01:27:23] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.812 frames - Bitrate: 19.931 Kbs - [01:27:24] Reencoding: VID_00026, Pass 1 of 2 - [01:28:27] Reencoding: VID_00026, Pass 2 of 2 - [01:32:36] Video Encode complete - [01:32:36] Reencoding audio tracks (if req'd) - [01:32:36] Multiplexing M2TS - [01:32:43] Extracting A/V streams [VID_00027] - [01:32:51] Reencoding: VID_00027 (25 of 40) - [01:32:51] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.836 frames - Bitrate: 19.684 Kbs - [01:32:51] Reencoding: VID_00027, Pass 1 of 2 - [01:33:55] Reencoding: VID_00027, Pass 2 of 2 - [01:37:53] Video Encode complete - [01:37:53] Reencoding audio tracks (if req'd) - [01:37:53] Multiplexing M2TS - [01:38:01] Extracting A/V streams [VID_00028] - [01:38:25] Reencoding: VID_00028 (26 of 40) - [01:38:25] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 6.364 frames - Bitrate: 21.029 Kbs - [01:38:25] Reencoding: VID_00028, Pass 1 of 2 - [01:41:44] Reencoding: VID_00028, Pass 2 of 2 - [01:56:10] Video Encode complete - [01:56:10] Reencoding audio tracks (if req'd) - [01:56:10] Multiplexing M2TS - [01:56:33] Extracting A/V streams [VID_00029] - [01:56:35] Reencoding: VID_00029 (27 of 40) - [01:56:35] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 386 frames - Bitrate: 19.877 Kbs - [01:56:35] Reencoding: VID_00029, Pass 1 of 2 - [01:56:48] Reencoding: VID_00029, Pass 2 of 2 - [01:57:37] Video Encode complete - [01:57:37] Reencoding audio tracks (if req'd) - [01:57:37] Multiplexing M2TS - [01:57:39] Extracting A/V streams [VID_00030] - [01:57:43] Reencoding: VID_00030 (28 of 40) - [01:57:43] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.078 frames - Bitrate: 15.211 Kbs - [01:57:43] Reencoding: VID_00030, Pass 1 of 2 - [01:58:15] Reencoding: VID_00030, Pass 2 of 2 - [02:00:19] Video Encode complete - [02:00:19] Reencoding audio tracks (if req'd) - [02:00:19] Multiplexing M2TS - [02:00:22] Extracting A/V streams [VID_00031] - [02:00:35] Reencoding: VID_00031 (29 of 40) - [02:00:35] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.407 frames - Bitrate: 20.954 Kbs - [02:00:35] Reencoding: VID_00031, Pass 1 of 2 - [02:02:28] Reencoding: VID_00031, Pass 2 of 2 - [02:10:08] Video Encode complete - [02:10:08] Reencoding audio tracks (if req'd) - [02:10:08] Multiplexing M2TS - [02:10:22] Extracting A/V streams [VID_00032] - [02:10:27] Reencoding: VID_00032 (30 of 40) - [02:10:27] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.451 frames - Bitrate: 18.454 Kbs - [02:10:27] Reencoding: VID_00032, Pass 1 of 2 - [02:11:19] Reencoding: VID_00032, Pass 2 of 2 - [02:14:17] Video Encode complete - [02:14:17] Reencoding audio tracks (if req'd) - [02:14:17] Multiplexing M2TS |
1st August 2010, 17:12 | #8975 | Link |
- [02:14:22] Extracting A/V streams [VID_00033] - [02:14:30] Reencoding: VID_00033 (31 of 40) - [02:14:30] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.292 frames - Bitrate: 18.247 Kbs - [02:14:30] Reencoding: VID_00033, Pass 1 of 2 - [02:15:44] Reencoding: VID_00033, Pass 2 of 2 - [02:20:25] Video Encode complete - [02:20:25] Reencoding audio tracks (if req'd) - [02:20:25] Multiplexing M2TS - [02:20:33] Extracting A/V streams [VID_00034] - [02:21:26] Reencoding: VID_00034 (32 of 40) - [02:21:26] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 15.114 frames - Bitrate: 20.366 Kbs - [02:21:26] Reencoding: VID_00034, Pass 1 of 2 - [02:29:43] Reencoding: VID_00034, Pass 2 of 2 - [03:03:39] Video Encode complete - [03:03:39] Reencoding audio tracks (if req'd) - [03:03:39] Multiplexing M2TS - [03:04:49] Extracting A/V streams [VID_00036] - [03:04:53] Reencoding: VID_00036 (33 of 40) - [03:04:53] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 521 frames - Bitrate: 18.014 Kbs - [03:04:53] Reencoding: VID_00036, Pass 1 of 2 - [03:05:12] Reencoding: VID_00036, Pass 2 of 2 - [03:06:13] Video Encode complete - [03:06:13] Reencoding audio tracks (if req'd) - [03:06:13] Multiplexing M2TS - [03:06:15] Extracting A/V streams [VID_00037] - [03:06:18] Reencoding: VID_00037 (34 of 40) - [03:06:18] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.035 frames - Bitrate: 16.811 Kbs - [03:06:18] Reencoding: VID_00037, Pass 1 of 2 - [03:06:54] Reencoding: VID_00037, Pass 2 of 2 - [03:08:55] Video Encode complete - [03:08:55] Reencoding audio tracks (if req'd) - [03:08:55] Multiplexing M2TS - [03:08:59] Extracting A/V streams [VID_00038] - [03:11:10] Reencoding: VID_00038 (35 of 40) - [03:11:10] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 40.363 frames - Bitrate: 17.636 Kbs - [03:11:10] Reencoding: VID_00038, Pass 1 of 2 - [03:30:10] Reencoding: VID_00038, Pass 2 of 2 - [04:37:33] Video Encode complete - [04:37:33] Reencoding audio tracks (if req'd) - [04:37:33] Multiplexing M2TS - [04:41:09] Extracting A/V streams [VID_00055] - [04:41:17] Reencoding: VID_00055 (36 of 40) - [04:41:17] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.293 frames - Bitrate: 11.446 Kbs - [04:41:17] Reencoding: VID_00055, Pass 1 of 2 - [04:42:58] Reencoding: VID_00055, Pass 2 of 2 - [04:47:57] Video Encode complete - [04:47:57] Reencoding audio tracks (if req'd) - [04:47:57] Multiplexing M2TS - [04:48:09] Extracting A/V streams [VID_00056] - [04:48:17] Reencoding: VID_00056 (37 of 40) - [04:48:17] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.514 frames - Bitrate: 12.842 Kbs - [04:48:17] Reencoding: VID_00056, Pass 1 of 2 - [04:50:11] Reencoding: VID_00056, Pass 2 of 2 - [04:56:47] Video Encode complete - [04:56:47] Reencoding audio tracks (if req'd) - [04:56:47] Multiplexing M2TS - [04:56:59] Extracting A/V streams [VID_00057] - [04:57:06] Reencoding: VID_00057 (38 of 40) - [04:57:06] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.466 frames - Bitrate: 12.141 Kbs - [04:57:06] Reencoding: VID_00057, Pass 1 of 2 - [04:58:57] Reencoding: VID_00057, Pass 2 of 2 - [05:04:30] Video Encode complete - [05:04:31] Reencoding audio tracks (if req'd) - [05:04:31] Multiplexing M2TS - [05:04:40] Extracting A/V streams [VID_00058] - [05:04:43] Reencoding: VID_00058 (39 of 40) - [05:04:43] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.306 frames - Bitrate: 11.594 Kbs - [05:04:43] Reencoding: VID_00058, Pass 1 of 2 - [05:05:21] Reencoding: VID_00058, Pass 2 of 2 - [05:07:25] Video Encode complete - [05:07:25] Reencoding audio tracks (if req'd) - [05:07:25] Multiplexing M2TS - [05:07:28] Extracting A/V streams [VID_00060] - [05:07:29] Reencoding: VID_00060 (40 of 40) - [05:07:29] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 6 frames - Bitrate: 4.039 Kbs - [05:07:29] Reencoding: VID_00060, Pass 1 of 2 - [05:07:30] Reencoding: VID_00060, Pass 2 of 2 - [05:07:30] Video Encode complete - [05:07:30] Reencoding audio tracks (if req'd) - [05:07:30] Multiplexing M2TS [05:07:31]PHASE ONE complete [05:07:31]PHASE TWO - Rebuild Started - [05:07:31] Rebuilding BD file Structure [05:07:35] - Encode and Rebuild complete [05:07:35] Writing BD structure to ISO file - ImgBurn completed successfully - ALIEN_VS_PREDATOR_F2 folder removed. - WORKFILES folder removed. - Computer SHUTDOWN initiated. Code:
- Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.34.0.5, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
1st August 2010, 17:16 | #8976 | Link |
heres the CLASH_OF_THE_TITANS.ini too
[Status] LABEL=CLASH_OF_THE_TITANS VERSION=v0.34.05 (beta) SOURCE_SIZE=41854758379 SOURCE_VIDEO_SIZE=41617680384 TARGET_SIZE=24589107200 REDUCTION=.585136628959316 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=4 COMPLETED=31 REBUILD_COMPLETE=0 [00019] AUDIO=0 PGS=11111111 M2TS_TARGET=147905164 NSIZE=150988800 FLINK=0 MLINK=0 [00023] AUDIO=0 PGS=11111111 M2TS_TARGET=162544327 NSIZE=191975424 FLINK=0 MLINK=0 [00018] AUDIO=0 PGS=11111111 M2TS_TARGET=187134671 NSIZE=222136320 FLINK=0 MLINK=0 [00024] AUDIO=0 PGS=11111111 M2TS_TARGET=223480924 NSIZE=221540352 FLINK=0 MLINK=0 [00046] AUDIO=11110000 PGS=11011111111111000000000000 M2TS_TARGET=237987069 NSIZE=131297280 FLINK=-1 MLINK=0 [00016] AUDIO=0 PGS=11111111 M2TS_TARGET=239148280 NSIZE=274630656 FLINK=0 MLINK=0 [00022] AUDIO=1 PGS=11111111 M2TS_TARGET=244217342 NSIZE=317036544 FLINK=0 MLINK=0 [00009] AUDIO=0 PGS=11111111 M2TS_TARGET=244231722 NSIZE=278833152 FLINK=0 MLINK=0 [00036] AUDIO=11000000 PGS=11011111111111000000000000 M2TS_TARGET=248209819 RATE=8619 NSIZE=239978496 FLINK=-1 MLINK=0 [00017] AUDIO=0 PGS=11111111 M2TS_TARGET=251420123 NSIZE=298524672 FLINK=0 MLINK=0 [00021] AUDIO=1 PGS=11111111 M2TS_TARGET=263476183 NSIZE=367589376 FLINK=0 MLINK=0 [00020] AUDIO=0 PGS=11111111 M2TS_TARGET=283529536 NSIZE=356997120 FLINK=0 MLINK=0 [00038] AUDIO=0 PGS=11111111 M2TS_TARGET=354072185 NSIZE=346073088 FLINK=0 MLINK=0 [00025] AUDIO=01110000 PGS=11011111111111000000000000 M2TS_TARGET=427158742 RATE=16329 NSIZE=415266816 FLINK=-1 MLINK=0 [00043] AUDIO=11100000 PGS=11011111111111000000000000 M2TS_TARGET=431736304 NSIZE=202721280 FLINK=-1 MLINK=0 [00033] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=437629091 RATE=18350 NSIZE=425699328 FLINK=-1 MLINK=0 [00040] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=445291257 NSIZE=92104704 FLINK=-1 MLINK=0 [00035] AUDIO=11100000 PGS=11011111111111000000000000 M2TS_TARGET=483849896 RATE=11938 NSIZE=467957760 FLINK=-1 MLINK=0 [00045] AUDIO=00111110 PGS=11011111111111000000000000 M2TS_TARGET=495805420 NSIZE=197910528 FLINK=-1 MLINK=0 [00047] AUDIO=1 PGS=11111111 M2TS_TARGET=504506324 NSIZE=692238336 FLINK=0 MLINK=0 [00029] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=538409467 RATE=15102 NSIZE=523370496 FLINK=-1 MLINK=0 [00030] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=558639127 RATE=15550 NSIZE=544856064 FLINK=-1 MLINK=0 [00037] AUDIO=11000000 PGS=11011111111111000000000000 M2TS_TARGET=619899563 RATE=2600 NSIZE=598192128 FLINK=0 MLINK=0 [00001] AUDIO=00110000 PGS=11011111111111000000000000 M2TS_TARGET=640834564 RATE=17374 NSIZE=619991040 FLINK=-1 MLINK=0 [00034] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=670510771 RATE=19096 NSIZE=652419072 FLINK=-1 MLINK=0 [00031] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=895438483 RATE=15779 NSIZE=870979584 FLINK=-1 MLINK=0 [00041] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=1123863531 RATE=12705 NSIZE=1096341504 FLINK=-1 MLINK=0 [00048] AUDIO=1 PGS=11111111 M2TS_TARGET=1238566251 RATE=8018 NSIZE=1211633664 FLINK=0 MLINK=0 [00026] AUDIO=00110000 PGS=11011111111111000000000000 M2TS_TARGET=1393021896 RATE=15271 NSIZE=1352312832 FLINK=-1 MLINK=0 [00042] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=1493264310 RATE=12679 NSIZE=1455458304 FLINK=-1 MLINK=0 [00028] AUDIO=01100000 PGS=11011111111111000000000000 M2TS_TARGET=1777591610 RATE=16804 NSIZE=1728479232 FLINK=-1 MLINK=0 [00044] AUDIO=00000111 PGS=11011111111111000000000000 M2TS_TARGET=2127690703 RATE=12625 Last edited by jdobbs; 1st August 2010 at 18:56. |
1st August 2010, 18:51 | #8977 | Link | |
1st August 2010, 18:55 | #8978 | Link |
need a little help, i have changed nothing and now my encodes keep failing. Trying currently on Watchmen. This same message in both version 34.04 and 34.05 i just encoded Brooklyn's Finest a few days ago with no issue. Full backup not movie only
----------------------- [13:44:15] BD Rebuilder v0.34.05 (beta) - Source: WATCHMEN_-_BR - Input BD size: 39.79 GB - Approximate total content: [04:30:56.990] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [13:44:19] PHASE ONE, Encoding - [13:44:19] Extracting A/V streams [VID_00524] - [13:44:19] Reencoding: VID_00524 (1 of 50) - [13:44:19] Reencoding secondary video [TRK_02] - [13:44:20] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 29 frames - Bitrate: 1,488 Kbs - [13:44:20] Reencoding: VID_00524, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.34.05 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [13:47:23] - Failed video encode, aborted |
1st August 2010, 19:04 | #8979 | Link | |
Have you changed the minimum M2TS size to be modified? 29 frames seems small to even be included in the job. I guess it could be multi-part, but I've never seen a 29 frame segment in a multi-part feature. Last edited by jdobbs; 1st August 2010 at 19:08. |
1st August 2010, 19:13 | #8980 | Link |
jdobbs, sorry for harping on about this topic but I'd like to go over the "no encoding required" and space calculation method a bit more. Do you happen to have in your arsenal the US version of Astro Boy? It's the perfect title for finetuning this.
Movie-only playlist (00001.MPLS) contains a single file (00001.M2TS) which has a size of 25 403 062 272 bytes. In addition to video, it contains an English DTS-HD MA track and a Spanish Dolby Digital 640kbps track, as well as English and Spanish subs. Using BD-RB 0.34.05, I set custom output to 24100MB (which actually wouldn't fit on a BD25 which is 25 025 314 816 bytes, i.e. 23866MB - if I calculated correctly) and told BD-RB to do a movie-only backup while keeping HD audio, but dropping Spanish audio and subs. Here's what the .INF says: SOURCE_SIZE=25403062272 SOURCE_VIDEO_SIZE=25403062272 TARGET_SIZE=25270681600 REDUCTION=.994788790792915 Since REDUCTION is less than 1, BD-RB would actually re-encode the video, correct? So, for s**** and giggles I aborted processing and entered a custom output size of 25550MB. INF reported a value higher than 1, and no re-encoding was done. Total output (directories etc. included) came to 24 859 136 164 bytes, i.e. 23707.52MB which fits on a BD25. Now, I'm aware that BD-RB has to estimate certain things and there are overheads etc. to factor in, and the whole shebang is much more complicated than I can fathom. I just wanted to show by this example that there's still some room for improvement, that's all. Last edited by colinhunt; 1st August 2010 at 19:20. |
