26th June 2015, 17:45 | #1241 | Link | |
Software Developer
LameXP v4.12 Alpha-8
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th July 2015 at 21:34. |
5th July 2015, 03:12 | #1242 | Link |
Files get renamed even though the rename-output-files option is not checked
On my system (Win 7 64-bit) the output filenames do not retain the same name as the input filenames even though I have left the rename-output-files option unchecked. In particular, my input filenames often have more than one space character in a row to improve formatting when large aggregates of files are listed by other software, and LameXp renames them by squeezing all such cases down to a single space only. Is there any way to get the program to preserve the filename? Other than that (and it is a nit), what a great program, and thanks. The parallel processing of encoding (4-way for me) is a boon.
5th July 2015, 09:37 | #1243 | Link | |
Life's clearer in 4K UHD
Can you give us some before and after examples? Cheers
5th July 2015, 13:19 | #1244 | Link |
Software Developer
File name strings generally are simplified(), in order to removed typographical "mistakes", such as multiple space characters in a row.
6th July 2015, 04:31 | #1245 | Link | |
I'd prefer it if the names were untouched. However, as a workaround, I wrote AutoHotkey scripts that I call before and after compression. The before script turns all blanks into @s (a character that never appears in my titles); the after script turns all @s into blanks. The result has the form I want, but I just have to remember to invoke the scripts. |
10th July 2015, 21:32 | #1246 | Link | |
Software Developer
You can try this test build: https://www.sendspace.com/file/fnjqaj
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th July 2015 at 21:58. |
10th July 2015, 21:35 | #1247 | Link | |
Software Developer
LameXP v4.12 Beta-1
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 15th August 2015 at 17:23. |
17th July 2015, 16:55 | #1248 | Link |
SourceForge website mystery.
http://sourceforge.net/projects/lame...hots%20(BETA)/ Today I find recent history wiped out: Looking for the latest version? Download LameXP.2014-06-23.Release-Static.Build-1558.exe Home / Snapshots (BETA) Name Modified Size Downloads / Week Status Parent folder Totals: 182 Items 2015-03-28 2015-03-28 Back to the present today 7.18.2015. Last edited by lethedoom; 18th July 2015 at 15:25. Reason: facts evolved |
19th July 2015, 09:32 | #1249 | Link |
Software Developer
SourceForge file release system can be a bit funky at times...
See also: http://sourceforge.net/blog/sourcefo...e-restoration/
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th July 2015 at 12:14. |
20th July 2015, 18:18 | #1250 | Link |
This is a new one: -
Is it anything I may have done? Currently running Windows 10 Pro (64-bit) Build: 10240
20th July 2015, 18:47 | #1251 | Link |
Software Developer
You mean those warnings about "failed to open registry key"?
I recently moved some more registry-related stuff to the MUtilities library, in order to eliminate more redundant code in LameXP/MediaInfoXP. Quite possible that the new code is more pedantic, while the old code just failed silently. Anyway, I assume those warnings originate from the Shell Integration code. Probably nothing to worry about. But I will need to look into this in detail...
25th July 2015, 09:13 | #1252 | Link | |
Software Developer
LameXP v4.12 Beta-2
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 15th August 2015 at 17:21. |
26th July 2015, 14:54 | #1253 | Link | |
Software Developer
Please try with this Test build, which should resolve all issues listed above: https://www.sendspace.com/file/rn18m7 BTW: If you find any "misplaced" registry entries (created by the effected versions of LameXP), which would be in the form of HKEY_CURRENT_USER\.foo, you should simply delete them manually!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 26th July 2015 at 17:11. |
26th July 2015, 17:04 | #1254 | Link |
Nice one... It appears "all is good": -
9th August 2015, 17:30 | #1255 | Link |
Software Developer
Here is a Test build created with VS2015:
http://sourceforge.net/projects/lame...29/2015-08-11/ (Only "shared" build for now, because I haven't gotten around to build "static" Qt with VS2015 yet. Pre-Win10 users may need to install the Redist package)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 15th August 2015 at 17:55. |
15th August 2015, 17:23 | #1256 | Link | |
Software Developer
LameXP v4.12 Beta-3
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th August 2015 at 22:11. |
24th August 2015, 22:11 | #1257 | Link | |
Software Developer
LameXP v4.12 Beta-4
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 29th August 2015 at 16:31. |
25th August 2015, 09:32 | #1258 | Link |
Thanks,
The new version is booting-up fine using Win10 (build 10525)
29th August 2015, 16:32 | #1259 | Link | |
Software Developer
LameXP v4.12 Beta-6
http://sourceforge.net/projects/lame...29/2015-08-29/ Quote:
30th August 2015, 14:42 | #1260 | Link | |
Software Developer
https://www.sendspace.com/file/it57wv
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
