#21 | Link | |
too much lurking
Fantastic tool BTW. I'm loving it. Thanks for all of your hard work. |
#22 | Link |
Author of BDSup2Sub
Changing the frame rate is not visible in the main view. However, when you select "Save" in the file menu, an export dialog pops up where you can set the checkbox for "Change frame rate". If this checkbox is active, the source and target frame rate can be edited and the time stamps will be changed accordingly during export.
#23 | Link | |
too much lurking
#24 | Link |
Hey thanks for the program it's definitely useful however I came across some subs that are misaligned that I reported here. If you could take a look at it be much appreciated.
#25 | Link |
Author of BDSup2Sub
How am I supposed to take a look if you didn't post a stream?
Besides, if two different tools which don't share a single line of code, show the same behavior, chances are that the stream is either buggy or uses an undocumented/unknown formatting feature. Anyway, without a stream, nobody can tell for sure. |
#27 | Link |
Here's one of the many streams, most sup's I've converted to 720p with BD-RB has shown the problem so I think it would be a pretty common issue. I just found BDSup2Sub earlier today so this is the first.
I think it is issues with the streams like you say, I've seen many strange displays with SupRip over the past year or so but they seemed to ocr ok so I didn't pay much attention to it. But these strange displays play fine in the retail somehow. Last edited by turbojet; 4th March 2009 at 06:20. |
#28 | Link |
Author of BDSup2Sub
Can you name a frame that you think is misaligned in this SUP?
On the first look, the window (WDS) locations and sizes seem to be valid. BTW: how was this created? It contains DTS info, so it was probably not created with EAC3TO... |
#29 | Link |
Matroska find' ich toll
i converted some BD.sups and i find a timestamp problem in the sub.idx
some subtitles are shown too long... sample is here load the sub/idx in SubtitleCreater an go to subtitle 135 and you will see what i mean. Thats not a mistake of SC because during the playback in MPC the subtitle are shown too long. hubble Last edited by hubblec4; 13th May 2020 at 16:49. |
#30 | Link | |
It was demuxed with tsmuxer I will try eac3to and see if that changes anything. eac3to threw an error s06 Writing the destination file failed. Aborted at file position 2052063232. Last edited by turbojet; 4th March 2009 at 18:35. |
#31 | Link |
Author of BDSup2Sub
@turbojet
Hm, looks like the windows are perfectly centered, but the image is quite a bit smaller than the window in this case (which it usually isn't). Since there is no window in the VobSub format, the image is displayed at the coordinates of the window and thus is shifted left. Problem is that I'm unsure how to handle this case (image smaller than window) in general. Maybe centering is an option, maybe there are flags in the stream that define what to do. I'll have a look. @hubblec4 This is obviously a problem in the original stream (or created by the demuxer). If you go to frame 134 in BDSUP2Read, it shows an end time stamp "00:00:00:000". This is of course a bad thing to start with. Since I wanted to add some time stamp inconsistency checking anyway, I might add some auto fix code as well. |
#32 | Link |
Author of BDSup2Sub
Hope I didn't destroy more than I fixed this time. First post is updated again.
04.03.2009 1.2 -> 1.3
#33 | Link |
Thanks!
1.3 got rid of the misaligned subs, at the least the ones I had remembered on 3 of 3 sup's so far. I'm considering it fixed and not going to try to remember those other ones that were misaligned. I'll let you know if I see it happen in the future. One thing I notice in vista x64 is progress bar is very small screenshot Last edited by turbojet; 5th March 2009 at 06:21. |
#34 | Link |
Hello
Thanks for the new version. A new problem i found. sample The subtitles are doubled and the first sub has no endtime in the timestamp. the problem i found on SupRead to. Only SupRip load and show the file correctly. hubble |
#35 | Link |
Author of BDSup2Sub
Well, again, this is more a problem of the stream.
The section sequence of a typical stream looks like this: PCS(start)/WDS/PDS/ODS/END PCS(end)/WDS/END In your stream it looks like this: PCS(start)/WDS/PDS/ODS/END PCS(start)/WDS/PDS/ODS/END PCS(end)/WDS/END So the whole start sequence including the the palette and RLE compressed bitmap is duplicated, yet with different start times (PTS). IMHO this doesn't make sense since it wastes lots of space. So this is most probably a authoring fault or a problem with the demuxer. Then again, I think I can add a workaround. |
#36 | Link |
Author of BDSup2Sub
Just a small update, mainly for the last two issues reported.
Hubble/turbojet, could you give it a try and report back? 06.03.2009 1.3 -> 1.4
#37 | Link |
I think progress bar looks ok now in vista.
Thanks again |
#39 | Link |
Another problem i have found. please look at my sample
After transcoding the time to show this subtitles is very short. Example. Subtitle 78 here is the original length from SupRip: 78 00:08:47,068 --> 00:08:50,820 -Ich heirate. -Was? Hör auf, ich versteh ihn nicht. but in the new file.sub/idx (open it in SC) 78 00:08:49,070 --> 00:08:50,822 -Ich heirate. -Was? Hör auf, ich versteh ihn nicht. the endtime seems to be correct but the starttime is too late and nobody can read this subtitle in this short time. hubble Last edited by hubblec4; 6th March 2009 at 11:10. |
#40 | Link |
Author of BDSup2Sub
Damnit, how many samples do you actually have
![]() I will have a look this evening. However I assume that this is another case of stream inconsistency that SupRip detects and fixes. I just fear that each workaround added might create new problems. Also with all that stream bug fixing I somehow don't find the time to continue core development. |
