6th July 2020, 15:06 | #21 | Link |
July 06 2020 update to version 2.5.0.
Added: Video scan type detection (interlaced or progressive) Modified: FFmpeg folder path. Bugs corrected. At the first start you have to specify ffmpeg.exe location path. Last edited by ProWo; 7th July 2020 at 21:32. |
10th August 2020, 17:15 | #27 | Link |
The audio section should offer
FLAC Opus OGG There is no sense to put WAV in an encoding, with existence of FLAC. So I recommend to add these 3 further major codecs. Offer also more video encoders, especially NVEnc encoding. |
10th August 2020, 20:28 | #28 | Link |
Hello ProWo,
if you are looking for a website for your project I would like to suggest github, if open source would be an option. It could make sense to bundle all dependencies, it's easier for people to get started and ensures that the ffmpeg built has all features you are using enabled.
11th August 2020, 08:51 | #29 | Link |
My project is meant to be a simple GUI, not a competition to Handbrake or others, so that even inexperienced users can get along with it and have the most necessary tools available. Wav as output has the purpose to allow various manipulations with all audio editors.
11th August 2020, 08:54 | #30 | Link | |
thanks for your input, I'll think about it. |
12th August 2020, 18:36 | #31 | Link |
Crashes directly on specifying sourcefile: "No given filename" on Process()
************** Ausnahmetext ************** System.InvalidOperationException: Der Prozess kann nicht gestartet werden, da ein Dateiname nicht angegeben wurde. bei System.Diagnostics.Process.Start() |
13th August 2020, 14:42 | #32 | Link | |
Try the latest beta. |
13th August 2020, 16:10 | #33 | Link |
On both, beta and stable ... x86 and x64
Very courious behaving: It starts only if I use it from inside the "download" folder, but not from any another drive (with full permissions). But after a message that the stream must be copied because of a missing framerate (mkv) the UI is freezing ... and copying of these video is never completed ... |
13th August 2020, 16:20 | #34 | Link | |
user=your user name on windows Then restart clever FFmpeg-GUI. If you use the 64 bit version you must also use 64 bit ffmpeg. |
13th August 2020, 18:59 | #35 | Link |
Thank you for answering.
I respected verions of x86 and x64, that should not be a problem here. Deleted folders in AppData. Worked for one time, until this coying ... btw: ffmpeg has no problems with this file started manually by cmd. Now clever_FFmpeg_GUI wont work again. So I deleted again folder in AppData. But on restarting clever_FFmpeg_GUI it even does not ask again for some location of ffmpeg.exe, and again this exception on loading a sourcefile appears. Folder with executable of clever_FFmpeg_GUI does not contain any ffmpeg.exe. Lets see if others have same problems ... |
13th August 2020, 20:13 | #36 | Link | |
https://ffmpeg.zeranoe.com/builds/ Extract the file wherever you want. It will create a folder with a name like ffmpeg-20200812-bb59bdb-win64-static, with a bin subfolder; in this bin subfolder are the three files clever FFmpeg-GUI needs. Delete the folder C:\Users\xxx\AppData\Local\clever_FFmpeg-GUI (where xxx=your user name on windows) again. The first time you start clever FFmpeg-GUI, navigate to the above bin folder in the folder browser. That's it. Now everything should work fine. |
14th August 2020, 10:09 | #37 | Link |
All this I did before ...
- Dowmloaded static build from Zeroane - Extracted them to e:\ffmpeg-20200812-4ed6bca-win64-static - Removed "clever_FFmpeg_GUI" from "C:\Users\XXXXX\AppData\Local" - Extracted actual clever_FFmpeg_GUI-beta to "e:\clever_ffmpeg_gui_newest_beta" Started "E:\clever_ffmpeg_gui_newest_beta\x64\clever FFmpeg GUI.exe" And again ... no question for a location to the bin-folder of ffmpeg. Opening a sourcefile results in exception again -> "No filename specified". This is the only file in appData: "user.config": Code:
<?xml version="1.0" encoding="utf-8"?> <configuration> <configSections> <sectionGroup name="userSettings" type="System.Configuration.UserSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" > <section name="clever_FFmpeg_GUI.My.MySettings" type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowExeDefinition="MachineToLocalUser" requirePermission="false" /> </sectionGroup> </configSections> <userSettings> <clever_FFmpeg_GUI.My.MySettings> <setting name="spos_x" serializeAs="String"> <value>175</value> </setting> <setting name="spos_y" serializeAs="String"> <value>209</value> </setting> </clever_FFmpeg_GUI.My.MySettings> </userSettings> </configuration> Where is path to ffmpeg saved? I dont see it in that user.config. And its not asked again ... so it must be saved somewhere ... Should the be an file for Application Settings too? I dont see anyone. |
14th August 2020, 11:01 | #38 | Link | |
(This file should have been in the C:\Users\XXXXX\AppData\Local\clever_FFmpeg_GUI folder). Last edited by ProWo; 15th August 2020 at 07:16. |
18th August 2020, 14:32 | #39 | Link |
August 18 2020 update to version 2.5.7.
Improved: Deinterlacing (Yadif: frame/frame, field/frame, interlaced marked frames only). Improved. Error handling. Added: Encode interlaced video as interlaced. Fixed: minor bugs. |
20th August 2020, 10:24 | #40 | Link | |
As I said before: - Removed "clever_FFmpeg_GUI" from "C:\Users\XXXXX\AppData\Local" There is no folder of clever_FFmpeg_GUI anymore in my appdata, but it still does not ask for a new path on restart. You should take a look at my posted user.config. You dont see "ffmpegPath" in there, you dont get questions about that? Ive had a quick look into your sourcecode (as good as decompiling works), its definied to be in there, so there seems something going wrong. Some entries are missing in my user.config, every time its created. Thats why I asked where you store path to ffmpeg ... |
