Old 11th May 2020, 10:10   #1761  |  Link
almanteka
any way to change the job % progress bar color from gray? example picture below
almanteka is offline
Old 11th May 2020, 10:38   #1762  |  Link
stax76
stax76's Avatar
It was already changed two times because of conflicts with user theme colors, too much risk changing it again.
stax76 is offline
Old 11th May 2020, 16:50   #1763  |  Link
almanteka
never experience the versions with a colored bar, maybe 'cause i was stocked with v1.6.0.3, the last with the option of "demux and index before creating jobs". still using it with updated apps for creating batch jobs that needs adjustments only and using the latest stable for that adjustments and encoding since i can't find a way to batch demux and index the files before creating the jobs with newer versions. i thought the progress bar color was related with the user theme colors or somewhere in the options to select the color myself. too hard to see when the monitor is at distance or at an angle, and i'm using a 27" monitor! thanks for your reply!
Old 11th May 2020, 18:55   #1764  |  Link
Atlantis
never mind
Atlantis is offline
Old 11th May 2020, 19:24   #1765  |  Link
stax76
stax76's Avatar
Sorry I missed your post, I do my best to maintain staxrip, it's not complete fun because I gave up encoding years ago and lost interest in encoding. A lot of tools updating, not so much programming, not really convinced of the help platform rest/sphinx etc. mpv(.net) is much more exciting and that's what I was working on in recent days. If I don't reply and say that I examined or bookmarked a request then it might get lost, reporting an issue on the tracker is more work but has the advantage that nothing gets lost, the chance to get help from me and also various other staxrip users is higher on the tracker. About your request, I confirm it's a bug and I've bookmarked it, hopefully it's not difficult to fix.
edit:
Actually I had it bookmarked, did just not post that I did so.
edit2:
not easy but fixed
stax76 is offline
Old 12th May 2020, 02:05   #1766  |  Link
stax76
stax76's Avatar
Originally Posted by jlw_4049 View Post
Wanted to report a bug.
https://i.imgur.com/qa77ORW.png
Sometimes when I'm going through settings the window will get to large to see all the way to the top. There is no way to resize the window or drag it and move it around.
Is there a way to reproduce it?
stax76 is offline
Old 12th May 2020, 09:08   #1767  |  Link
jlw_4049
Yes I'll provide steps tomorrow when I get on my server.
Short version is it happens when I switch back and forth from 2 pass to quality encoding.
It mainly happens when the command line window has a lot of commands. The top just goes up into the top of the screen and I can't pull it down.
I'll try to explain exact steps tomorrow.
Sent from my Pixel 3a using Tapatalk
jlw_4049 is offline
Old 12th May 2020, 18:35   #1768  |  Link
tormento
Acid fr0g
tormento's Avatar
Is there a way to import a AVS script without having it modified by StaxRip?
Sometimes I need it only as a interface for encoder, nothing else.
@turment on Telegram
tormento is offline
Old 12th May 2020, 18:52   #1769  |  Link
stax76
stax76's Avatar
StaxRip should not modify the original file and it should support all scripts without exception, try 2.1.1.2 Beta.
stax76 is offline
Old 12th May 2020, 19:16   #1770  |  Link
tormento
Acid fr0g
tormento's Avatar
I just tried, that’s why I am asking you.
It creates a sort of import script, loading KNLMeansCL too from local tools dir.
tormento is offline
Old 12th May 2020, 19:24   #1771  |  Link
stax76
stax76's Avatar
You mean it added more lines than the import line, like LoadPlugin calls? If so then I can fix it, it's harmless.
stax76 is offline
Old 12th May 2020, 19:31   #1772  |  Link
tormento
Acid fr0g
tormento's Avatar
My script is:
PHP Code:
SetFilterMTMode("DEFAULT_MT_MODE"2)
LoadPlugin("D:\eseguibili\media\DGDecNV_x64\DGDecodeNV.dll")
DGSource("E:\in\1_45 Star trek 3 — Alla ricerca di Spock\spock.dgi",ct=128,cb=136,cl=0,cr=0)
SMDegrain (tr=4thSAD=500refinemotion=falsen16=truemode=0contrasharp=falsePreFilter=4truemotion=trueplane=4chroma=true)
Prefetch(6
I open it with right click and it generates the following in a spock_temp dir inside the original avs script:
spock.avs
PHP Code:
LoadPlugin("D:\eseguibili\media\StaxRip_x64\Apps\Plugins\Dual\KNLMeansCL\KNLMeansCL.dll")
Import("D:\eseguibili\media\StaxRip_x64\Apps\Plugins\AVS\SMDegrain\SMDegrain.avsi")
Import("E:\in\1_45 Star trek 3 — Alla ricerca di Spock\spock.avs"
spock_source.avs
PHP Code:
and if I right click preview code, I get
PHP Code:
Bit useless and confusing IMHO, as I want to load my avsi and my plugins (the original KNLMeansCL is not compatible with AviSynth+ 3.0, as example).
I'd like, if possible, to have a way to transparently import a script with no fuss, bell or whistles.
tormento is offline
Old 12th May 2020, 20:00   #1773  |  Link
stax76
stax76's Avatar
I've uploaded a hotfix to the onedrive and dropbox folder.
stax76 is offline
Old 12th May 2020, 20:29   #1774  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks, will try asap.
tormento is offline
Old 13th May 2020, 01:43   #1775  |  Link
Atlantis
Don't know if post #1765 was to me but just to clarify, my never mind post was about my own post. I had posted an incorrect answer to an earlier post, I edited my post to remove it.
I would never expect to receive replies to all my posts. Thank you.
Atlantis is offline
Old 13th May 2020, 09:23   #1776  |  Link
tormento
Acid fr0g
tormento's Avatar
Ok, trying now.
My 2 cents:
  1. Why to import a script instead of using that's ready?
  2. Is there a way to save the encoding preferences instead of having to set every time a new file is opened?
  3. please add switches in x264 config to add --keyint xxx and --opencl
  4. why when you start jobs you can't interact with StaxRip GUI anymore? You perhaps want to add more jobs to be executed later.
tormento is offline
Old 13th May 2020, 11:30   #1777  |  Link
stax76
stax76's Avatar
staxrip needs control over the script to implement an integrated workflow, most tools use the avisynth API by using import:
https://github.com/staxrip/staxrip/b...Server.cpp#L75
This is also true for megui.
https://staxrip.readthedocs.io/features.html
https://staxrip.readthedocs.io/faq.h...ttings-persist
stax76 is offline
Old 13th May 2020, 12:47   #1778  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for answering 1) and 2). I don't understand if you aswered 3) and 4) too.
tormento is offline
Old 13th May 2020, 13:15   #1779  |  Link
stax76
stax76's Avatar
At the bottom of the x264 dialog there is search field and drop-down.
The Search dropdown field at the dialog bottom left lists options and can be used to quickly find options, it searches command line switches, labels and dropdowns. Multiple matches can be cycled by pressing enter.
It lists and finds --keyint and --opencl
The design isn't perfect, it was always like this and it's too difficult to fix but you can start another instance and add jobs I think, even running instances will see the new jobs I think.
stax76 is offline
Old 13th May 2020, 17:15   #1780  |  Link
Atlantis
I do this all the time. You can run another instance of staxrip and work on another job. You can either create a new project or open an existing project
Atlantis is offline
