Go Back   Doom9's Forum > General > DVD2AVI / DGIndex
Old 20th July 2009, 22:31   #41  |  Link
GZZ
yea - rebooting the cuda server didnt always work, sometimes it still didnt work after restarting it, then you have to wait.
GZZ is offline   Reply With Quote
Old 21st July 2009, 06:23   #42  |  Link
buzzqw
HDConvertToX author
Hi Pals!
don't want to hijacking but i added experimental support to great NV Tools in HDConvertToX
while i am a registered user of NV tools (a well deserved license!), my developing pc cannot use this tools (i use a virtual winxp on Fedora)
anyone is welcome to make some tests
please download the full HDC package and then use http://www.64k.it/andres/data/hdconv...vertToX-DG.exe, then unzip nvtools beta 4 in \applications , BUT put dgdecodenv.dll in \filters folder
also make bug report in HDC thread -> http://forum.doom9.org/showthread.php?t=145577
thanks to all!
and a BIG : thanks: to Neuron2 for these great framework!
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 26th July 2009, 23:04   #43  |  Link
GZZ
Will it be possible for that DGDecode.dll auto start the CUVIDServer.exe when its being access. I sometimes starts a encoding and then it crash because CUVIDServer.exe isnt running. Was just thinking if this could be done automatically ?
Old 28th July 2009, 04:15   #44  |  Link
I'll put it on the to-do list.
Old 2nd August 2009, 00:19   #45  |  Link
SomeJoe
I've been working with NVTools Beta4 and I'm still running into the previously reported problem where after the halfway point in the video, deinterlace=2 is not working correctly.
When using the DGDecodeNV.dll from the NVTools beta 4 off your website (.dll file dated 07/01/2009), blank frames are returned for frames past the halfway point.
I also tried to use DGDecodeNV.dll from the NVTools beta 3 package (.dll file dated 06/29/2009). In this case, frames past the halfway point are returned, but they are returned at 1/2 the proper frame rate and/or audio is out of sync.
I have tried them under NVidia drivers 186.18 as well as the current 190.38 version on NVidia's site, and the result is the same.
My test file is a 48-second MPEG-2 TS file from HDV camcorder footage (154 MB), edited in Avid Media Composer.
Other than this deinterlace=2 issue, the remainder of the beta 4 package appears to be working correctly, including the honoring of pulldown flags from MPEG-2. I have used this on several soft-telecined .m2v files and the resulting encoded stream is in perfect sync with the original audio.
- SomeJoe
SomeJoe is offline   Reply With Quote
Old 2nd August 2009, 00:26   #46  |  Link
Revgen
http://forum.doom9.org/showthread.ph...86#post1310386
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 2nd August 2009, 00:53   #47  |  Link
The fix will be out later tonight. It's already working but I have to do the version numbers and docs and stuff.
Old 2nd August 2009, 01:25   #48  |  Link
NV beta 5
Here is the fix. Please beat on this.
http://neuron2.net/dgavcdecnv/NVbeta5.zip
There are two changes:
1. Now has D3D9-less operation. That should be more robust and perform better on low-end adapters.
2. Fix for the stream truncation by half with DGMPGDecNV and DGSource(...,deinterlace=2).
Old 2nd August 2009, 02:07   #49  |  Link
rack04
Did something change in CUVIDServer.exe with the updated package? I get the following error message:
Previous versions worked fine.
rack04 is offline   Reply With Quote
Old 2nd August 2009, 02:17   #50  |  Link
Yes, it was updated to remove the dependency on D3D.
Please report your OS.
You can continue to use the old one until we resolve this.
Old 2nd August 2009, 02:32   #51  |  Link
rack04
Windows XP SP3. I will continue to use CUVIDServer 1.04.
Old 2nd August 2009, 02:39   #52  |  Link
I have XP SP3 too and have no problem.
Let's see what others report.
What is your graphics adapter?
Old 2nd August 2009, 02:51   #53  |  Link
wangyi6854
Hi, neuron2.
I also got the error with beta5.
My system is windows server 2008 64bit. Graphics card is g8400gs
wangyi6854 is offline   Reply With Quote
Old 2nd August 2009, 02:53   #54  |  Link
Darn. It must be because I applied the Visual Studio service pack.
Investigating...
Old 2nd August 2009, 02:54   #55  |  Link
wangyi6854
Another question:
Why force film option is disabled in beta4? I need it to process vob files.
Old 2nd August 2009, 03:03   #56  |  Link
Try installing this:
http://www.microsoft.com/DOWNLOADS/d...displaylang=en
Force Film is not yet implemented.
Old 2nd August 2009, 03:11   #57  |  Link
wangyi6854
It doesn't solve the problem.
BTW: I've installed vs2008 and windows sdk.
Old 2nd August 2009, 03:12   #58  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
I'm on XP x64 SP2, and also getting errors running the new version,
i already have the msvc++ redistributables/runtimes for 2005, 2008, and 2010 all installed (both x86 and x64 for each release)...
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 2nd August 2009, 04:46   #59  |  Link
Revgen
Good News: deinterlace=2 works now.
Bad News: I get the same error with CUVIDServer using Winxp SP3, 190.38 drivers, and 8400GS card.
I'll try the VC Redrist package later and see if it works.
Moe: Why?
Old 2nd August 2009, 06:31   #60  |  Link
Revgen
Just tried the package. CUVIDServer still doesn't work. Using the old version instead.
Moe: Why?
