Old 18th May 2020, 19:49   #1841  |  Link
44vince44
Originally Posted by jlw_4049 View Post
wooow! I didn't know there was another staxrip thread haha. So should we take all discussions about staxrip over there then?
Well it's better to discuss things here, and report bugs there...
44vince44 is offline
Old 18th May 2020, 21:04   #1842  |  Link
jlw_4049
I will take my discussion over there from now on. Thanks sir!
Sent from my Pixel 3a using Tapatalk
I mean this thread is Ravens and the other is the official staxrip thread.
But yes I know what you mean
jlw_4049 is offline
Old 18th May 2020, 21:52   #1843  |  Link
Patman
Patman's Avatar
Originally Posted by 44vince44 View Post
@Patman, I see you have now separate builds for AVX and AVX2. Didn't the "regular" builds check for available instruction sets on your hardware and use them ?
Hi vince,
the regular builds check for available instructions and use them. It was a request
Tools for StaxRip | x264 - x265
Patman is offline
Old 19th May 2020, 00:40   #1844  |  Link
Arkana
@Arkana
Which GPU is in use?
I'm using Windows server. Seems like no dedicated GPU at all
Arkana is offline
Old 19th May 2020, 07:27   #1845  |  Link
44vince44
Originally Posted by Patman View Post
Hi vince,
Thanks Patman, so please confirm, if my processor is AVX2, If I use the regular M build GCC11, and the "AVX2" M build GCC11, the performance and result is the same ? Please confirm !
And again thanks for everything.
(BTW I'm new here, but the same Vince at github)
Old 19th May 2020, 07:35   #1846  |  Link
JKyle
App Digger
JKyle's Avatar
@Patman
It seems like your build of FFmpeg, ffmpeg-N-97806-g883c48190f-g1ead7ed5bf-gcc10.1.7z has a problem with a text file input that's encoded in UTF-8, CR/LF(Windows).
In order to concatenate two wmv files into one mkv, I made the following txt file named mylist.txt (UTF-8, CR/LF):
file 'test 1.wmv'
file 'test 2.wmv'
Then I ran the following command to join those two wmv files:
(Windows 10 x64 2004)
ffmpeg -hide_banner -f concat -safe 0 -i mylist.txt -c copy -y 'test.mkv'
But your FFmpeg binary yields this error message:
[concat @ 00000147d0463300] Impossible to open 'mtest 1.wmv'
mylist.txt: No such file or directory
On the other hand, Zeranoe's build (4.2.2 static) runs OK.
I can't figure out why there's an unnecessary letter m in the filename in the error message.
My guess is that maybe it's related to the text encoding method your ffmpeg binary employs when it takes the text input file.
Any idea?
JKyle is offline
Old 19th May 2020, 08:52   #1847  |  Link
stax76
stax76's Avatar
@Patman
JKyle uses CP 949 if I remember right.
I'm using Windows server. Seems like no dedicated GPU at all.
KNLMeansCL uses OpenCL which your system probably don't support due to lack of GPU driver.
stax76 is offline
Old 19th May 2020, 10:00   #1848  |  Link
Arkana
@Patman
any suggestion for denoise filter on windows server?
Arkana is offline
Old 19th May 2020, 13:36   #1849  |  Link
SaboraPie
Hi!! a bug opening in Video Comparison:
---------------------------- System Environment ----------------------------
StaxRip : 2.1.1.4
Windows : Windows 10 Pro 1809
Language : Spanish (Spain, International Sort)
CPU : Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
GPU : NVIDIA GeForce GTX 670
Resolution : 1920 x 1200
DPI : 96
-------------------------------- Exception --------------------------------
System.OverflowException: La operación aritmética ha provocado un desbordamiento.
en StaxRip.VideoComparisonForm.VideoTab.Draw() en D:\Projekte\VB\staxrip\Forms\VideoComparisonForm.vb:línea 342
en StaxRip.VideoComparisonForm.VideoTab.OnPaint(PaintEventArgs e) en D:\Projekte\VB\staxrip\Forms\VideoComparisonForm.vb:línea 409
en System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
en System.Windows.Forms.Control.WmPaint(Message& m)
en System.Windows.Forms.Control.WndProc(Message& m)
en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
SaboraPie is offline
Old 19th May 2020, 15:39   #1850  |  Link
44vince44
did you try DFTTEST it's one of the most popular denoisers.
Old 19th May 2020, 15:49   #1851  |  Link
Khun_Doug
It depends on the type of noise you want to remove. Is this an SD or HD source? Old movie that has been digitized? B&W or color?
Take a look at SMDegrain and mClean.
Khun_Doug is offline
Old 19th May 2020, 16:02   #1852  |  Link
JKyle
App Digger
JKyle's Avatar
@Patman
Thanks for remembering, but after talking with you about mpv/mpv.net failing to read a non-single-byte language named avs file on a non-UTF8 codepage system, I changed the codepage to UTF8.
PS D:\Work\temp\test> Get-Culture; Get-UICulture; Get-WinSystemLocale; Get-WinDefaultInputMethodOverride; [Text.Encoding]::Default | select EncodingName,CodePage
LCID             Name             DisplayName
1033             en-US            English (United States)
1042             ko-KR            Korean (Korea)
InputMethodTip : 0412:{A028AE76-01B1-46C2-99C4-ACD9858AE02F}{B5FE1F02-D5F2-4445-9C03-C568F23C99A1}
Description    : Korean (Korea) - Microsoft IME
EncodingName : Unicode (UTF-8)
CodePage     : 65001
JKyle is offline
Old 20th May 2020, 15:34   #1853  |  Link
Patman
Patman's Avatar
Originally Posted by JKyle View Post
@Patman
Any idea?
Please download the new version, an error occurred while compiling
Patman is offline
Old 20th May 2020, 15:53   #1854  |  Link
Arkana
thanks, will give it a try
for video like this
https://images2.imgbox.com/1e/69/3sZtnC03_o.jpg
Arkana is offline
Old 20th May 2020, 17:36   #1855  |  Link
JKyle
App Digger
JKyle's Avatar
You mean ffmpeg-N-97833-gc94550eb31-gb707abf091-gcc10.1.0.7z, right?
Unfortunately, ffmpeg.exe does not return anything this time.
For example, even the simplest command in the unarchived folder
.\ffmpeg.exe -version
returns nothing.
JKyle is offline
Old 20th May 2020, 18:28   #1856  |  Link
Patman
Patman's Avatar
returns nothing.
ffmpeg-N-97833-gc94550eb31-gb707abf091-gcc10.1.0.7z is correct, but it's strange that your command gave no feedback... i got following feedback with the downloaded version
C:\Windows\system32>C:\Users\PATRIC~1\AppData\Local\Temp\Rar$DRa1344.14723\ffmpeg.exe -version
ffmpeg version N-97833-gc94550eb31-gb707abf091+3 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 10.1.0 (Rev2, Built by MSYS2 project)
configuration:  --cc='ccache gcc' --cxx='ccache g++' --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-libsvthevc --enable-openal --enable-vapoursynth --enable-opencl --enable-opengl --enable-openssl --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --enable-nonfree
libavutil      56. 46.100 / 56. 46.100
libavcodec     58. 84.100 / 58. 84.100
libavformat    58. 43.100 / 58. 43.100
libavdevice    58.  9.103 / 58.  9.103
libavfilter     7. 81.100 /  7. 81.100
libswscale      5.  6.101 /  5.  6.101
libswresample   3.  6.100 /  3.  6.100
libpostproc    55.  6.100 / 55.  6.100
Patman is offline
Old 20th May 2020, 18:35   #1857  |  Link
stax76
stax76's Avatar
I find the topic text encoding difficult but interesting and important. Regarding this avisynth issue I found something few days ago that is somehow related.
stax76 is offline
Old 20th May 2020, 19:49   #1858  |  Link
JKyle
App Digger
JKyle's Avatar
Well, it's pretty weird.
I re-downloaded the file, but I still get the same result: no return.
Maybe we need someone else's help about this.
Can anyone join us and test it please?
The file is here.
JKyle is offline
Old 20th May 2020, 21:30   #1859  |  Link
44vince44
The file is here.
Just tested ffmpeg.exe -version, i get the error:
The code execution cannot proceed because libbrotlidec.dll was not found. Reinstalling the program may fix this problem.
Old 20th May 2020, 21:47   #1860  |  Link
JKyle
App Digger
JKyle's Avatar
Well, AFAIK, libbrotlidec.dll is a Brotli compression library included in mingw64 / MSYS2. (Here.)
I guess there was something wrong in the course of making ffmpeg static. (Not sure though.)
If I do more guesswork, I think it's related to MSYS2 and GCC 10.1.0.
JKyle is offline
