12th December 2018, 16:19 | #6621 | Link | |
But usually it doesn't make sense to increase this. I recommend leaving it on low priority. |
12th December 2018, 16:21 | #6622 | Link | |
12th December 2018, 16:24 | #6623 | Link |
OK by the looks of things that paid one is DGdecNV.dll which isn't what my script is loading - it's loading MeGUI\tools\dgindex\DGDecode.dll, that's the free bundled one isn't it? the updater lists it as DGIndex 1.58 dating from 2010
12th December 2018, 16:28 | #6624 | Link |
also previewing the generated AVS on the main input page of MeGUI works fine - no green at all. Surely if there was a license problem with the decoder, this would still be the case when previewing the script as it would when running the script
12th December 2018, 17:31 | #6626 | Link |
update: I've restored an old version from a backup, disabled updates, and encoding to x265 no longer produces the green screen. I don't have time today to go through all the component updates to see what's causing the green problem, but I will get to that soon.
x264 still produces the same crash. It's now that I realise that all the encodes I was doing previously in MeGUI (back when "everything used to work") have all been to x265 - it's likely that x264 has never worked. I'd like to figure out why! |
12th December 2018, 20:16 | #6627 | Link | |
I use development updates. Maybe that's the problem. What do you mean by it doesn't make sense? I thought higher priority level utilizes cpu more. |
13th December 2018, 10:40 | #6629 | Link |
Since version 2896, I cannot get two scripts to run together. I've set every Worker option I can find to '3' but if I Queue two scripts and then click Start, all jobs are done one at a time.
It would be great this feature could be returned to the way it was. Might it be that my copy of MeGUI isn't performing correctly with my Windows 10 PC? I've tried the 32 and 64 bit versions but they both produce a settings screen that just isn't right - words missing and a digit box that can't be clicked. It should look like the screen posted by zdzdz above. If anyone can identify my problem, I'd be grateful. Last edited by pooksahib; 13th December 2018 at 13:44. |
14th December 2018, 15:49 | #6631 | Link |
The "default fps" should be the same frame rate as the input video (except for deinterlacing or Inverse Telecine results). Arbitraty frame rate matching usually decreases the quality unnecessarily. And converting VFR content further is not recommendable, anyway. So, why do you believe you need that feature? But check if saving an AviSynth script preset (a template including an FPS conversion) already provides the wanted feature.
You can specify some track attributes explicitly if you use manual multiplexer tools as part of the manual queue management mode. The quicker usage modes (Auto Encode, One Click Encoder) provide less flexibility than the manual mode with queue control. |
14th December 2018, 15:57 | #6632 | Link | |
Sent from my LG-M700 using Tapatalk |
14th December 2018, 19:11 | #6633 | Link | |
If you don't like the result, upload a small sample of your source video for someone else to look at, but don't try arbitrarily changing the frame rate. |
15th December 2018, 14:18 | #6634 | Link | ||||
15th December 2018, 14:48 | #6636 | Link |
Thanks, Zetti. Forgot to mention that one.
I will NOT update for the moment as I need to figure out the changes which have been done in 18.08 already. For the moment MeGUI is still on 18.05 Last edited by Zathor; 15th December 2018 at 15:16. |
15th December 2018, 15:33 | #6637 | Link | |
As requested, here's the log. Hopefully, you can find out why my 'Options' screen is not displayed correctly. Thank you once again. Last edited by pooksahib; 15th December 2018 at 21:28. |
16th December 2018, 07:04 | #6638 | Link | |
If you have 29.976 content that's telecined you should be inverse telecining it, not forcing it to drop frames. |
