11th December 2024, 22:13 | #32081 | Link | |
If you look at this link you'll see that your card has more capability than mine (like AV1 encoding). I would guess it is faster too. Last edited by jdobbs; 11th December 2024 at 22:21. |
12th December 2024, 05:43 | #32082 | Link | |
Give the software a run and see what you think of the results. |
16th December 2024, 03:21 | #32085 | Link |
That's interesting... Although I don't have the right GPU to do it, it seems odd that whatever you are using to do the mechanics of encoding, I don't understand why whether the GPU does it or the CPU, aren't the math and computations exactly the same? Why are there different results...? Just curious...
16th December 2024, 10:55 | #32086 | Link |
For a project I had to convert a music video clip from PAL to NTSC. I used GPUENCC with INTEL GPU. The resulting video was fine but the audio was out of sync and kept getting further out of sync. Then I changed GPUENCC to reencoding with NVIDIA GPU and the audio in the result was completely in sync but the video was somewhat stammering or stuttering. The length of the original file was 3:32 minutes. The INTEL GPU changed that to 3:41 minutes while the NVIDIA GPU kept the 3:32 intact.
---------------------- [12.16.24] GPU Reencoder v0.01.17 ---------------------- [10.36.20]Start Job [1 of 1] - Reencoding "6. David Gilmour with Romany Gilmour - Yes, I Have Ghosts (Official Music Video).mp4" -- Using INTEL GPU for Video Encode -- Collecting input file information... -- Input : AVC, 1920x1080, 25fps -- Vid: H264 (AVC), No Resize, 23.976 fps, CQ 18 -- Aud: Intact (Keep Original), no reencode -- Remuxing output with MKVMERGE [10.36.56]Job Completed [1 of 1] ---------------------- [12.16.24] GPU Reencoder v0.01.17 ---------------------- [10.49.52]Start Job [1 of 1] - Reencoding "6. David Gilmour with Romany Gilmour - Yes, I Have Ghosts (Official Music Video).mp4" -- Using NVIDIA GPU for Video Encode -- Collecting input file information... -- Input : AVC, 1920x1080, 25fps -- Vid: H264 (AVC), No Resize, 23.976 fps, CQ 18 -- Aud: Intact (Keep Original), no reencode -- Remuxing output with MKVMERGE [10.50.21]Job Completed [1 of 1] Last edited by musiclover; 16th December 2024 at 14:12. |
17th December 2024, 05:45 | #32088 | Link | |
Special SeeD
Try something like Ghostbusters (the original one), even at BD50 bitrate the output created by NVEnc looks denoised and has this pulsating effect, the one encoded with x265 is superior in every way. |
17th December 2024, 05:50 | #32089 | Link | |
17th December 2024, 18:05 | #32090 | Link | |
18th December 2024, 17:07 | #32091 | Link | |
UPDATE I found an other way to get it done. Using BD_RB with the hidden option IMPORT_PAL_TO_FILM=1. It gave an excellent result. And BD_RB did the stretching for me. Last edited by musiclover; 18th December 2024 at 17:59. |
26th December 2024, 18:04 | #32092 | Link |
Hello!
I have tried the last 3 versions & the current beta version, with & without the add-ons, different versions of AVISynth, and using different encoders, but I still get the error message - PredictAndEncode() 00006 2803 Thank you for any assistance!!! --- DS |
26th December 2024, 18:23 | #32093 | Link | |
26th December 2024, 18:55 | #32094 | Link | |
--- DS Last edited by DeathStalker77; 26th December 2024 at 19:08. |
26th December 2024, 21:46 | #32095 | Link | |
26th December 2024, 22:07 | #32096 | Link | |
UPDATE: DoH! It was a bad file in the mix :-( --- DS Last edited by DeathStalker77; 27th December 2024 at 00:50. |
29th December 2024, 20:02 | #32097 | Link |
Sorry if I missed it, but is it expected that GPUENCC/NVEncC removes DV/DoVi profile 7.6 (dvhe.07.06) when re-encoding video? Thankfully it does at least leave the HDR10 there.
Input file (ripped from disc using MakeMKV): Code:
Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 45 min Bit rate : 65.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.328 Stream size : 75.1 GiB (90%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Original source medium : Blu-ray Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 45 min Bit rate : 38.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.191 Stream size : 43.9 GiB (84%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Code:
"D:\BD-RBV06212\tools\nvenc\nvencc.exe" --avhw -i "C:\ReEncode\Transformers Age of Extinction\Transformers Age of Extinction {edition-4K Disc}.mkv" --codec h265 --preset default --profile main10 --output-depth 10 --chromaloc auto --colorprim auto --transfer auto --colormatrix auto --master-display copy --max-cll copy --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 21 --aq --aq-temporal --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --lookahead 24 --no-b-adapt --gop-len 24 --audio-copy 1 --audio-copy 2 --audio-copy 3 --audio-copy 4 --audio-copy 5 --sub-copy 1,2,3 --chapter-copy -o "C:\REENCODE\WORKING\Transformers Age of Extinction {edition-4K Disc}.mkv" Code:
---------------------- [12/29/24] GPU Reencoder v0.01.17 ---------------------- [12:24:01]Start Job [1 of 1] - Reencoding "Transformers Age of Extinction {edition-4K Disc}.mkv" -- Using NVIDIA GPU for Video Encode -- Collecting input file information... -- Input : HEVC, 3840x2160, 23.976fps -- Vid: H265 (HEVC), No Resize, Keep fps, CQ 21 -- Aud: Intact (Keep Original), no reencode -- Remuxing output with MKVMERGE [13:15:12]Job Completed [1 of 1] |
4th January 2025, 12:05 | #32099 | Link |
Forcing no encoding
I want BDRB to read in a disc and not re-encode any of the videos it will end up keeping. The following is in the config:
FORCE_NOENCODE=1 FORCE-ENCODE=0 |
