Old 27th February 2019, 13:06   #4721  |  Link
NVIDIA never cared about OpenCL, and they are certainly not going to start now, especially since OpenCL is basically deprecated in favor of Vulkan Compute Shaders - which support FP16 on NVIDIA.
Honestly, any new code in OpenCL is probably a mistake, and you should look into Vulkan instead, which actually has a pretty wide support base on Windows already.
Old 27th February 2019, 20:20   #4722  |  Link
Shiandow
PS 3.0 it is then.
Shiandow is offline   Reply With Quote
Old 1st March 2019, 10:08   #4723  |  Link
Zachs
Suptitle, MediaPlayer.NET
Finally managed to optimise it enough to run at 13ms to do a 2x upscale of DVD res. 1080p to 4k is out for GTX 970 at 67ms but any recent cards like GTX 1070 should do just fine.
Big thanks to Shiandow for his valuable insights!
Now we just need to port it to MPDN renderscript.
Old 12th March 2019, 14:51   #4724  |  Link
Zachs
Created an extreme quality version for 3x upscale (most likely will require 2080ti and above to do 720p to 4k uspcale).
Normal quality version will run real time without a problem for for 720p to 4k upscale even on my old 970.
Old 12th March 2019, 17:38   #4725  |  Link
foozoor
foozoor's Avatar
No normal quality screen to compare?
foozoor is offline   Reply With Quote
Old 12th March 2019, 22:52   #4726  |  Link
Zachs
Normal quality is not nearly as good but for other images it's not as pronounced as this one. This one has lots of high frequency components.
Old 12th March 2019, 22:56   #4727  |  Link
The first thing that stands out to me with this upscale is the strength of the darkening of the lines creating an almost cartoonish appearance, can that be reigned in a little?
Old 12th March 2019, 22:56   #4728  |  Link
Zachs
That said however, it still fared very well against other state of the art scalers.
Old 12th March 2019, 22:57   #4729  |  Link
Zachs
That's how the original image looks like. You can artificially blur it though but that would drop SSIM significantly vs ground truth.
Old 14th March 2019, 14:17   #4730  |  Link
Zachs
After many rounds of optimisations, 1080p to 2160p only needs 18ms on my GTX 970!
720p to 1440p is 9ms.
3x from 720p to 2160p is 35ms.
Old 14th March 2019, 14:27   #4731  |  Link
Zachs
3x upscale sample (720p to 2160p):
Original: http://s000.tinyupload.com/index.php...58854064098138
3x: http://s000.tinyupload.com/index.php...40499290546766
Old 14th March 2019, 18:09   #4732  |  Link
any ETA when user will get there and on it?
it's easier to find issues with the scaler this way and if proper way to reproduce are given to you you maybe able to improve on it.
Old 14th March 2019, 22:57   #4733  |  Link
Zachs
This will be the baseline model. Any improvements will be looked at after we get this one done.
Old 10th April 2019, 00:59   #4734  |  Link
Anima123
Zachs, how's it going on with incorporating your new scaling into MPDN? I'm asking since it's been a while, and am still looking forward to it.
Anima123 is offline   Reply With Quote
Old 20th April 2019, 22:34   #4735  |  Link
mlauzon
I know it's completely off topic, but that's 55 King St. W. in Toronto...wonder if anyone else from Toronto noticed that.
Michael
mlauzon is offline   Reply With Quote
Old 1st May 2019, 23:28   #4736  |  Link
Zachs
Was too busy with work lately to work on it. Will try to continue when I get some spare time. It just needs to be written as a renderscript.
Old 20th May 2019, 10:35   #4737  |  Link
louiebh
whats the latest version and where can we download it because your personal website is down!
im happy this project isnt folded up yet!
Could i also get help with the Reclock script? mine is basically saying "Audioscript could not initialize" and the in brackets (AMD/Intel OpenCL drivers unavailable)?
louiebh is offline   Reply With Quote
Old 23rd May 2019, 01:04   #4738  |  Link
Zachs
I've hosted it on AWS S3. The latest is on the OP. I've had no time to maintain a website so I've shut it down.
You'll need to read OP to setup OpenCL drivers so you can use audio scripts.
Old 31st May 2019, 15:12   #4739  |  Link
dave_in_gva
Zach,
Can you unpack some of your acronyms above? What is the URL for downloading the latest installer? I'm afraid it is not clear to me what you mean by:
"I've hosted it on AWS S3. The latest is on the OP."
I've been using MPDN for 3+ years and love it. My laptop died and I am setting things up on a new one and have been getting error messages with my original installer.
Thankyou if you can steer me to the latest build.
Best wishes,
Dave M
dave_in_gva is offline   Reply With Quote
Old 31st May 2019, 17:15   #4740  |  Link
https://s3.amazonaws.com/mediaplayer..._Installer.exe
you can find all links and information in the first post also known as a original post (OP).
direct3d, mpdn, nnedi3, opencl, reclock
