15th November 2019, 06:50 | #17741 | Link | |
Grumpy Old Man.
I can't DE to work at all, since last update, consider yourself lucky that it only take 2 minutes.
15th November 2019, 08:22 | #17742 | Link | |
15th November 2019, 13:27 | #17743 | Link | |
Replace your files except *.ini open RipBot and run your jobs
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
15th November 2019, 13:32 | #17744 | Link | |
Grumpy Old Man.
I have actually thought of doing that....I have tried that a few months ago, when there was a weird problem. Thanks for the tip
15th November 2019, 13:35 | #17745 | Link | |
Grumpy Old Man.
I know you probably won't reply to this, but there are some things I want to say, like it or not. You're obviously a pretty intelligent person, I have been trying to figure out for years now, whether you're some young smart-arse, or a grumpy old man (I think the former), I doubt that an older person would post a reply/comment like that....but then what would I know, I'm just a grumpy old man. All I was trying to do was help you diagnose a major problem with your "free" software, that other people were commenting on, I sent you a video capture (of which you asked someone else to provide) of the strange behaviour, on my setup, and all you could do was rub it in my face, by posting screenshots of it working on your setup, with NO explanation !!! I also asked several times for an explanation on what you had changed in the auto update that ruined everything, and you simply didn't....you asked me to get specific app's to check things that I have no idea about what I'm doing, or what I'm looking for. You seem to expect everyone out there to have the same level of expertise as you...well, we don't !!! I gave you as much info as I could, but you simply didn't want to explain anything, all you did was say, "It just work's". It has to be something to do with the changes you added for server control. Are you going to help the others that are starting to comment on the same error's, are you going to ignore them, and tell them, "I'm done with you" ??? You can't stop me from using this software, I know some day, in hopefully the not too distant future, you WILL fix it, I WILL get the update's, and I'll be happy. I WILL keep perusing this forum, and if I feel the need, I WILL post a comment. Like I just did....
15th November 2019, 16:53 | #17746 | Link |
ByteShare
I've mentioned it before a while back. It isn't that you're asking for help. It is how you're asking for help (in my opinion). This is free software, so you can only expect limited support--if any. Unless the issue you're having is experienced by everyone it is possible to not get support, which has happened to me as well, but often it is something on my end that I eventually figure out.
15th November 2019, 17:08 | #17747 | Link | ||
ByteShare
(would be easier to tell if the point versions changed with each update) Quote:
--I could be wrong about the above, but that is how I understood it.-- I'm not sure who is switching their decoder all of the time but personally I would prefer if only the selected default decoder is run when adding a job to not waste CPU/electricity/time--adds up over time |
15th November 2019, 21:24 | #17748 | Link | |
That solved my problem with LSMash some time ago
15th November 2019, 23:31 | #17749 | Link |
Sry for the late response, but i got a really busy day. @byteshare i also use only Windows Defender, i already had an exception for the Temp Directory but not for the Ripbot Directory. I also excluded the Ripbot folder but it changed nothing. After Going back to Version 1.24 from the first post here DE Mode was working again but as soon as i allow Ripbot updating itself to 1.25 DE Mode is broken again. There is absolutely no TCP communcation between Encoding Server and Client.
16th November 2019, 00:22 | #17750 | Link | |
Grumpy Old Man.
I'm so happy that you've got the same problem I have....I have tried to supply as much info I can to the dev, and he's not responded well, in fact if you go back a couple of posts, you'll see what he said to me. Because it works for him, he doesn't see a problem. BTW, posting attachments on this forum isn't a very good idea, takes way too long for them to be approved.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 16th November 2019 at 00:24. |
16th November 2019, 01:32 | #17751 | Link | |
Grumpy Old Man.
No changes to core... Nice subtle hint there too, btw (doesn't work tho)
16th November 2019, 02:17 | #17752 | Link |
Grumpy Old Man.
Yes, I have now tried it, and unfortunately, it didn't worked
16th November 2019, 02:24 | #17753 | Link | |
ByteShare
Also, Pauly Dunne already mentioned better to link to an image from an image hosting site such as Imgur. So, I'll try to think of something but sorry I'm out of ideas at the moment. If there was a way to control which version you're on at least then you could roll back to a specific version that worked for you. I keep backups for this reason. |
16th November 2019, 04:38 | #17754 | Link |
speaking of version control. is there a way to get to a previous version? i noticed the main page only gives you up to v24, but there's been countless updates since v24. i just need the version prior to Nov 3rd.
16th November 2019, 05:18 | #17755 | Link | |
Grumpy Old Man.
Na, you're plum outta luck on that one, 'cause I'm sure you know, if you were to download v1.24 off the 1st page, and then do an update, you'd be right back with the problem build. So you'll be after core build 22-10-18, the last one that DE works with ? However, having said that, I might be able to help you with your problem.. PM me...
16th November 2019, 06:57 | #17756 | Link |
Grumpy Old Man.
I may have stumbled across something here...
In my quest to try and figure what might be the problem with DE not working for several of us, I have been swapping & changing different versions of EncodingClient.exe & EncodingServer.exe, using RB build (22-10-19), I know I'm no wiz when it comes to this, but I'm thinking that it might be the Encoding Client that has a problem, as from what I can see, it's looking for the wrong ports.
Have a look at the 2 screenshots, and decipher it for yourself.. using newest server, with older client. https://www.mediafire.com/view/42ijl...ports.jpg/file compared to this...what it should look like.. https://www.mediafire.com/view/6bt2a...works.jpg/file I'd guess that it's not desirable to mix and match, but you've gotta try a few things...trial & error, and I could be completely off the mark, here.
16th November 2019, 08:11 | #17757 | Link | |
ByteShare
also, what is happening on the "Main" window of the Encoding Server? If you can make a really good step-by-step of the things you've tried and the issues, maybe, someone would be able to figure it out. Not saying I'll figure it out, but you never know...sometimes I'm even right twice in a day (broken clock). Last edited by byteshare; 16th November 2019 at 08:20. |
16th November 2019, 08:44 | #17758 | Link | |
Grumpy Old Man.
yes I know I probably should have written it down step by step, I also would think that mixing up different versions and build stuff probably isn't a good idea, but I was just a bit puzzled about incorrect looking port numbers, etc. Maybe I'll do it again, and this time I'll document it. edit:- or maybe I won't, with more comments on a problem, surely it will be addressed soon.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 16th November 2019 at 09:52. |
16th November 2019, 09:01 | #17759 | Link |
I am not quite sure concerning the Firewall exceptions, will check it later the day. But Windows Defender has exceptions for both, Ripbot and Ripbot Temp Folder. Do i have to add exceptions to my Router Firewall as Well or only in NY machine? I mean at the moment the Client does not reach the Encoding Server running in the same machine. Another thing i realized but i do not know If it ist Important. With Version 1.24 in thhe Overview Window the Encoding Server ist named after my machine's Networkname and with Version 1.25 it ist still named "Server 1". Is it possible that the Main Problem ist that the Client is not able to detect the Encoding Server? And yes, since Yesterday in the evening i cannot create Jobs anymore, Ripbot stops with the Message that a DLL from LSmash is Missing.
