Old 18th August 2019, 15:43   #3261  |  Link
stax76
stax76's Avatar
There has been many names, sites, repos and threads but it's still the same old project.
I recently simplified the first post:
Visit the project page at:
https://github.com/staxrip/staxrip
Old 18th August 2019, 17:26   #3262  |  Link
Patman
Patman's Avatar
Github Revan
Hi Stax,
Revan use these
https://github.com/Revan654/staxrip
Patman is offline   Reply With Quote
Old 18th August 2019, 17:50   #3263  |  Link
stax76
stax76's Avatar
Hi Patman,
Revan's most recent commits were made at https://github.com/staxrip/staxrip, see:
https://github.com/staxrip/staxrip/commits/master
https://github.com/Revan654/staxrip/commits/master
Old 19th August 2019, 10:10   #3264  |  Link
NikosD
Few things were updated:
2.0.2.7
Just a minor issue.
It seems that if you select NVEnc cuda or NVEnc native in "Basic" submemu of nVidia H.265 encoder as decoders, the "VPP" submemu becomes not readable for the last options because it's been added a new field that makes it bigger than VPP window.
For all the other decoders, VPP menu is fine as they don't offer the added option.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 19th August 2019, 12:44   #3265  |  Link
stax76
stax76's Avatar
Originally Posted by NikosD View Post
Just a minor issue.
Thanks, I fixed it by increasing the height of the dialog.
Old 19th August 2019, 16:05   #3266  |  Link
Patman
Patman's Avatar
Oh ya, you're right. Thanks Stax.
Gesendet von meinem HMA-L09 mit Tapatalk
Tools for StaxRip | x264 - x265
Old 19th August 2019, 18:46   #3267  |  Link
stax76
stax76's Avatar
2.0.3 Stable
  • colorspace="YV12" removed from ffms2 defaults because it converts to 8 bit
  • the x264 encoder uses now avs2pipemod64 because the avs input did not support 10 bit
  • DTS-X is now demuxed as dtshd instead of mka
  • update: mkvtoolnix 36.0.0
  • update: avs FluxSmooth 1.4.7
  • update: avsmeter 2.9.5
Old 19th August 2019, 19:11   #3268  |  Link
Zetti
Is there problems with MediaInfo v19.07 since it's not included??
Old 19th August 2019, 19:24   #3269  |  Link
sneaker_ger
FWIW: x264cli's avs input supports 16 bit.
Old 19th August 2019, 20:28   #3270  |  Link
stax76
stax76's Avatar
Just forgotten to update, I added it to the issue tracker.
This is what I got:
x264 --crf 18 --output-depth 10 --output output.h264 input.avs
avs [error]: not supported pixel type: YUV420P10
x264 [error]: could not open input file 'input.avs'
Old 19th August 2019, 21:36   #3271  |  Link
sneaker_ger
16 bit input. I mean e.g.:
ffvideosource("source.mkv") #10 bit source
ConvertBits(16)
Old 19th August 2019, 22:46   #3272  |  Link
stax76
stax76's Avatar
ConvertBits(16)
Good to know. In the next build there is a piping tool option (Automatic, None, vspipe, avs2pipemod, ffmpeg) in the x264 options in the Other tab. What I noticed is that piping with ffmpeg does not work with 10 bit, with 8 bit input it works.
ffmpeg -i movie.avs -f yuv4mpegpipe -loglevel fatal -hide_banner - | x264 --crf 18 --output-depth 10 --demuxer y4m --frames 1553 --output movie.h264 -
y4m [error]: bad sequence header magic
x264 [error]: could not open input file `-'
Old 19th August 2019, 23:04   #3273  |  Link
sneaker_ger
ffmpeg can pipe y4m 10 bit but you need to set -strict -1
Old 19th August 2019, 23:59   #3274  |  Link
stax76
stax76's Avatar
It works, thanks.
Old 20th August 2019, 06:26   #3275  |  Link
NikosD
2.0.3 Stable
For your next update:
All three Hardware Encoders have a slightly newer version than StaxRip:
NVEnc v4.45 (StaxRip v4.44)
QSVEnc v3.24 (StaxRip v3.23)
VCEEnc v4.02 (StaxRip v4.01)
Old 20th August 2019, 15:11   #3276  |  Link
Zetti
FFmpeg v4.2 is also not included.
Old 20th August 2019, 15:58   #3277  |  Link
stax76
stax76's Avatar
It's now on the issue tracker.
I'm waiting for a new Wolfberry build.
Old 20th August 2019, 17:05   #3278  |  Link
Patman
Patman's Avatar
Here is new Wolfberry build
ffmpeg-20190808-af3ddd5-win64-static.7z
And here is Wolfberry's collection:
Monochrome Anomaly (Sig Wolfberry)
Old 20th August 2019, 19:13   #3279  |  Link
stax76
stax76's Avatar
Thanks, I've added it to the issue tracker.
Old 24th August 2019, 06:58   #3280  |  Link
aegisofrime
Hi all,
Can I ask why does StaxRip keep complaining that my Avisynth plugins directory is missing? It is not missing and present in both Staxrip's directory and in my Program Files folder. I have also tried installing the provided installer as suggested, with the same results.
Also, recently all my encodes have been erroring out with the following:
Video encoding using x265 3.1 failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Incorrect function.
I'm encoding with x265, and I have verified that the encoded file is fine actually. This results in me needing to manually mux the .hevc with the audio file which is annoying...
aegisofrime is offline   Reply With Quote
