Old 9th January 2017, 16:00   #14661  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by burt123 View Post
Hi byteshare,
Yeah, on further observation, I have noticed that the problem occurs on other encodes, not just with MDegrain, so I must have a problem somewhere.
Interested in your mention of a manual edit to use MDegrain3....more info on that, please
Yep, I have to agree with your idea about the servers activity at the end of a job....good idea !!!
But I'd still like MORE.....
MDegrain3 Grainy Stuff (Removes extra noise):
#Denoise
Loadplugin("YourPathHere\RipBot264v1.19.5\Tools\AviSynth plugins\mvtools\mvtools2.dll")
LoadPlugin("YourPathHere\RipBot264v1.19.5\Tools\AviSynth plugins\flash3kyuu_deband\flash3kyuu_deband.dll")
super = video.MSuper(pel=2)
bv1 = MAnalyse(super, isb = true, delta = 1, overlap=4)
fv1 = MAnalyse(super, isb = false, delta = 1, overlap=4)
bv2 = MAnalyse(super, isb = true, delta = 2, overlap=4)
fv2 = MAnalyse(super, isb = false, delta = 2, overlap=4)
bv3 = MAnalyse(super, isb = true, delta = 3, overlap=4)
fv3 = MAnalyse(super, isb = false, delta = 3, overlap=4)
video=video.MDegrain3(super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=400).f3kdb
Originally Posted by slalom View Post
You're talking about 3-5 minutes max of idle time. Not worth the trouble
That would depend on your encode settings/FPS, not to mention how many server you have sitting idle to multiply that by. With slow encodes that use MDegrain I can have a 60s clip take 30 or more min. so that means I can have all but 1 server idle for 30 min. just waiting for the job to end and start encoding again.
Old 10th January 2017, 16:01   #14662  |  Link
Shrekage
I have found a bug in encodingclient.exe. I have 1 server at 10.0.0.100. and after the client connects to it and the chunk starts to encode, it changes the address to 10.0.0.116. when the chunk finishes encoding, I get an exception shown in the attached PNG file
it reads "Exception EConvertError in module EncodingClient.exe at 00024122. '116:1000' is not a valid floating point value."
What do you need to debug?
Shrekage is offline   Reply With Quote
Old 10th January 2017, 17:42   #14663  |  Link
We can start with screenshot which does not require admin approval.
Old 10th January 2017, 23:13   #14664  |  Link
Shrekage
how does one do that. I don't find a way to paste screenshot into the forum
Old 11th January 2017, 11:11   #14665  |  Link
Ronski
Upload the picture to somewhere like photo bucket, Google pictures etc and post a link on here
Ronski is offline   Reply With Quote
Old 11th January 2017, 16:01   #14666  |  Link
Shrekage
https://www.amazon.com/photos/share/...N404UZYsxRBe9i
Old 11th January 2017, 19:52   #14667  |  Link
Is there any reason why you connect to server via ip 10.0.0.100 instead of 10.0.0.116? Do you have mutiple network adapters on that remote-pc? Can you run ipconfig /all on that machine?
Old 11th January 2017, 21:24   #14668  |  Link
Shrekage
because 100 is it's IP address...
C:\Users\Administrator>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : W764-XPS2710a
   Primary Dns Suffix  . . . . . . . : xxxx.xxx.com
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : xxxx.xxx.com
Wireless LAN adapter Wireless Network Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Dell Wireless 1703 802.11b|g|n (2.4GHz)
   Physical Address. . . . . . . . . : C0-18-85-4E-73-0D
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 12-18-85-4E-73-0D
Wireless LAN adapter Local Area Connection* 3:
   Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
   Physical Address. . . . . . . . . : 52-18-85-4E-73-0D
Ethernet adapter Local Area Connection:
   Description . . . . . . . . . . . : Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
   Physical Address. . . . . . . . . : 00-21-70-68-72-04
   IPv6 Address. . . . . . . . . . . : 2605:6000:101b::xxxx(Preferred)
   Temporary IPv6 Address. . . . . . : 2605:6000:101b::xxxx(Preferred)
   Link-local IPv6 Address . . . . . : fe80::4d00:fe8:5695:94d3%4(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.0.0.100(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Wednesday, January 11, 2017 9:12:53 AM
   Lease Expires . . . . . . . . . . : Thursday, January 12, 2017 9:12:52 AM
   Default Gateway . . . . . . . . . : fe80::26a4:3cff:fe05:1577%4
                                       10.0.0.1
   DHCP Server . . . . . . . . . . . : 10.0.0.1
   DHCPv6 IAID . . . . . . . . . . . : 285221232
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-BE-6A-33-00-21-70-68-72-04
   DNS Servers . . . . . . . . . . . : 10.0.0.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : C0-18-85-4E-73-0E
Tunnel adapter isatap.{4C726AEE-FBEA-496D-9D9C-08B3B23B63C4}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76::xxxx(Preferred)
   Link-local IPv6 Address . . . . . : fe80::3822:3e33:bdbb:7422%11(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 469762048
   NetBIOS over Tcpip. . . . . . . . : Disabled
Old 11th January 2017, 21:38   #14669  |  Link
Shrekage
10.0.0.116 is assigned to a samsung device on my network, not the 10.0.0.100 PC
Old 11th January 2017, 21:43   #14670  |  Link
byteshare
ByteShare
byteshare's Avatar
Segment Length
What is the shortest segment length you can get away with without losing compression and/or quality for CRF? For 2pass? Right now the default is 60s.
I mostly use CRF but sometimes I use 2pass.
In order to reduce some of my server idle time I was hoping to reduce the segment size.
Old 12th January 2017, 13:57   #14671  |  Link
@Shrekage
                                       10.0.0.1
Is this connection on top of this list?
Old 12th January 2017, 17:11   #14672  |  Link
Shrekage
Yes
https://www.amazon.com/photos/share/...JmsyC1oD0vp7r1
Old 12th January 2017, 19:43   #14673  |  Link
Run this http://www.mediafire.com/file/8kyq2b...y/DetectIP.exe on that remote-PC and show me what ip it detects.
Old 12th January 2017, 20:10   #14674  |  Link
Shrekage
10.0.0.100
https://www.amazon.com/photos/share/...WS3KHqqEI1SElG
Old 12th January 2017, 20:23   #14675  |  Link
Ok so new code works better.
Old 14th January 2017, 17:59   #14676  |  Link
@Shrekage
This should solve your problems with wrong ip
http://www.mediafire.com/file/9ioix3..._and_server.7z
Old 16th January 2017, 08:00   #14677  |  Link
Tazlord
Has anyone else noticed issues with multi-playlist titles not showing the correct playlist in the "Select Streams" "Playlist" drop-down? So far I've run into 2 titles that have the multi-playlist protection where the correct playlist wouldn't show up in the drop-down. I verified the correct playlist on both titles using the Process Monitor method and also verified the playlist via BDInfo. However, when trying to select the proper playlist in RipBot, the correct one is nowhere to be found. I figure since the BD Structure is established from the eac3to executable, I'm going to assume it's probably a problem with that application. I just wanted to see if anyone else is having this same problem?
Atak, in case you're monitoring this. I've attached a link to the BD structure of one of the titles so you can see for yourself. The correct playlist for this title is 541 but it doesn't show up in eac3to's output.
job8.zip https://file.io/EI44gj
Titles Tested:
Deep Water Horizon - 541.mpls
Nerve - 456.mpls
Tazlord is offline   Reply With Quote
Old 16th January 2017, 19:33   #14678  |  Link
dracore
Will x265 encoding with gpu be supported at all, i have a gtx 1060 and was just wondering if this feature could be added ... thank you
dracore is offline   Reply With Quote
Old 17th January 2017, 09:39   #14679  |  Link
smuperman
Hi @ Atak_Snajpera
Is it possible to add some AAC Profiles besides constant quality or better to enter the (VBR) Quality Settings freely?
The "quality=0.X" Setting.
smuperman is offline   Reply With Quote
Old 19th January 2017, 16:07   #14680  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by smuperman View Post
Hi @ Atak_Snajpera
The wait for more sound options could be a long one. I'd recommend if you're not already using a 3rd party app to process the sound and then mux it back in yourself.
