Old 19th September 2008, 18:25   #21  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by bratao View Post
You said that ou have encoded a video.
Please post some screenshots of video to us. And the Bitrate used.
source:
x264 rev979 (default settings @ 1152kbps) :
dirac 1.0 (default settings @1152kbps) :
Old 19th September 2008, 22:38   #22  |  Link
DigitAl56K
Congratulations to the Dirac Project on the 1.0 release
DigitAl56K is offline   Reply With Quote
Old 19th September 2008, 22:43   #23  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by Kurtnoise13 View Post
Its rather unfair to use x264 on the default settings (which are awful)--let alone what you appear to be doing, which is encoding progressive content as interlaced
Old 19th September 2008, 22:53   #24  |  Link
bratao
Kurtnoise13,
Thanks a lot !!!
But the two samples looks too washed for this bitrate.
BTW, the Dirac is the base encoder, so this is highly unoptimized, is like compare x264 to JM Reference H.264/AVC encoder.
bratao is offline   Reply With Quote
Old 20th September 2008, 01:36   #25  |  Link
cacepi
Just as bad up as down.
Originally Posted by Anatasia View Post
Also there's a plugin for Quicktime QuickTime plugin based on Schroedinger
It's Mac only (which doesn't bother me) and the encoding options the GUI exposes are very skeletal at the moment (which does bother me). x264Encoder it is not, but it's a start.
If anyone wants a build (remember, Mac only) PM me.
cacepi is offline   Reply With Quote
Old 20th September 2008, 05:35   #26  |  Link
Kurtnoise
Kurtnoise's Avatar
I know and you're completely right... but it was intentional. My goal was to see what the codecs can produce with default settings, not to find the best trade off.
The first thing when I test an audio or a video codec is to check what it produces with its default settings. Maybe it's not the correct way. In this case, I'm deeply sorry. I know that x264 can give much more better than this. Maybe you have an explanation why I got such poor result at this bitrate ?
To be honest, I got decent results around 2500kbps for my eyes for this scene. Besides, I've better results with some other sources. Don't get me wrong here... I never used and I won't use default settings for x264.
All in all, it seems that dirac doesn't respect target bitrate for 2 passes encoding. And I got some strange chroma shift with Big Buck Bunny as source (maybe it's the decoder fault)...
Old 20th September 2008, 06:08   #27  |  Link
Dark Shikari
x264 developer
Interlaced mode isn't default.
Old 20th September 2008, 06:35   #28  |  Link
Kurtnoise
Kurtnoise's Avatar
allright, I found the culprit. It's CoreAVC...shit.
I updated the picture.
Old 20th September 2008, 08:15   #29  |  Link
paehl
The Windows binary version here
http://www.paehl.com/open_source/?Co...ools:DIRAC_1.0
paehl is offline   Reply With Quote
Old 20th September 2008, 10:51   #30  |  Link
CruNcher
CruNcher's Avatar
thx paehl
it doesn't look bad for the start
It is about Time
Old 20th September 2008, 13:04   #31  |  Link
Leeloo Minaļ
Thanks for these first binaries, but i have two questions :
- what are the good extension and container for Dirac videos ?
- is there any chance to get a VFW codec for use with VirtualDub ?
I also am unable to register DirectShow splitters (official and Schroedinger version) : all .AX libraries i tried up to now, codecs or others, always registered without updating PATHs or doing some black magic...
Leeloo Minaļ is offline   Reply With Quote
Old 20th September 2008, 15:10   #32  |  Link
Anatasia
That's why I've asked about a compiled Schrodinger DS filter.I think it can encode to dirac format in Virtualdub.The easiest way that I've known to encode it is using OggConvert which use OGV format.
Anatasia is offline   Reply With Quote
Old 20th September 2008, 15:29   #33  |  Link
Kurtnoise
Kurtnoise's Avatar
for raw streams : drc
for containers : OGG, TS, AVI
nope...
I've made installers :
>> http://kurtnoise.free.fr/index.php?d...racDec-1.0.exe
>> http://kurtnoise.free.fr/index.php?d...nger-1.0.5.exe
Old 20th September 2008, 15:30   #34  |  Link
Kurtnoise
Kurtnoise's Avatar
No such tool exists afaik...
Old 20th September 2008, 17:03   #35  |  Link
littleD
littleD's Avatar
What's wrong with my system. Why me?
Tried previous dsh filters and also newest dirac.ax from sf cannot register manually. Tried even installers that kurtnoise13 was kind to provide. Still nothing. Using haali media splitter, bbb100.ts (dirac) do not play. Internal splitter in MPC HC do not make it better..
littleD is offline   Reply With Quote
Old 20th September 2008, 19:00   #36  |  Link
Kurtnoise
Kurtnoise's Avatar
only VLC and FFplay/Mplayer are able to play ts files containing dirac streams for the moment on windows...
what kind of error did you have during registration ?
Old 20th September 2008, 20:11   #37  |  Link
RadicalEd
Dirac 1.0 Hits Slashdot
http://tech.slashdot.org/article.pl?.../09/20/1726252
Originally Posted by dylan_-
According to their website, 'Dirac is an advanced royalty-free video compression format designed for a wide range of uses, from delivering low-resolution web content to broadcasting HD and beyond, to near-lossless studio editing.' Now a stable version of the dirac-research codebase, Dirac 1.0.0, has been released. The BBC have already successfully used the new codec during the Beijing Olympics and are looking to push it to more general use throughout the organisation. The latest version of VLC (the recently released 0.9.2) has support for Dirac using the Schroedinger library.
The story's relatively new, so get in there and throw in your opinions, Slashdotters!
RadicalEd is offline   Reply With Quote
Old 20th September 2008, 20:32   #38  |  Link
cacepi
A few asked, so here it is: SchroQT.component.zip (filesend.net)
It's Universal, but as I no long have my G5 I can't test on PPC. Built from Schroedinger 1.0.5, liboil 0.3.15 and latest git SchroQT.
Old 20th September 2008, 20:56   #39  |  Link
littleD
littleD's Avatar
Looks like dirac splitter finally install with no problem thx to the installers kurtnoise13 provided.
That was because i was trying register without diracdecoder.dll (?) i didnt compile (even didnt know how ). That was missing module error.
..only VLC and FFplay/Mplayer are able to play ts files containing dirac streams for the moment on windows...
Heh, so what are those DSH filters for, then?
Old 20th September 2008, 22:00   #40  |  Link
CruNcher
CruNcher's Avatar
source:
Kurtnoise13 are those both CBR encodes ? else it wouldn't be fair (just comparing RC's here) everyone should be aware Dirac has no ABR/VBR yet it's only plain CBR
It is about Time
dirac, schroedinger, slashdot, vlc
