Old 26th May 2019, 22:34   #6301  |  Link
Megalith
Originally Posted by Aleksoid1978 View Post
Do you test on latest SVN version - https://yadi.sk/d/hlf1lfC8mKU58/!_last ?
Try change "Device buffer".
No improvement. I think it's a quirk with my DAC.
That said, I noticed another peculiarity with WASAPI Exclusive. In that mode, certain passages of loud bass sound distorted. No such issue in WASAPI Shared.
It's obvious in the Ready Player One, when King Kong slams his hands against the road during the race where the main character drives backward to get the key.
Megalith is offline   Reply With Quote
Old 27th May 2019, 01:13   #6302  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Megalith
Try this build using WASAPI Exclusive - https://yadi.sk/d/GiM3josEiFOlMA
It's create log on Desktop. Upload it for me after playback and close MPC-BE.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 27th May 2019, 05:41   #6303  |  Link
Aleksoid1978
Originally Posted by mood View Post
Thanks, but does not help,
Try this - start MPC-BE, show playlist and delete "Explorer". - it's don't help ?
Old 28th May 2019, 03:42   #6304  |  Link
kb968
Hi, just to let you no, what a awsome player... I was using potplayer but its becoming very bloated, then I found this one..
Congratulations..
Keep on keeping on..
Cheers.
kb968 is offline   Reply With Quote
Old 28th May 2019, 07:44   #6305  |  Link
mood
No, not help
I have uncheck "remember last playlist" and uncheck "remember historic..." in the settings
mood is offline   Reply With Quote
Old 31st May 2019, 20:57   #6306  |  Link
Shark007
Shark007's Avatar
thanks for keeping up with this player.
Its been the only player I use since you forked from the HC branch.
could someone have a look at a new issue?
subtitle download works (for me) in version 4557 but seems to be broken in 4558.
EDIT: it may be be just me. I tested on a different machine just now and 4558 was fine there.
Shark007 is offline   Reply With Quote
Old 31st May 2019, 21:50   #6307  |  Link
yonta
I just found a weird bug.
You play a video in mpc-be and pause it. Now if you open Windows startmenu and start dragging a shortcut, mpc-be is unpaused?
yonta is offline   Reply With Quote
Old 1st June 2019, 15:39   #6308  |  Link
Ezhihua
I can also reproduce this bug
Bless My Homeland Forever.
Ezhihua is offline   Reply With Quote
Old 1st June 2019, 15:49   #6309  |  Link
stax76
Registered Lurker
I could reproduce it only once in Win 10.
stax76 is online now   Reply With Quote
Old 1st June 2019, 16:41   #6310  |  Link
Ezhihua
I uploaded a video that recorded the bug
https://share.weiyun.com/5KGc6b0
Old 1st June 2019, 18:50   #6311  |  Link
stax76
Registered Lurker
I believe you but I cannot reproduce it. My start menu looks different, I have this big tiles in my start menu and tab like sidebar where I can switch between big tiles and all programs.
Old 2nd June 2019, 03:18   #6312  |  Link
v0lt
@Ezhihua
I can not download anything from share.weiyun.com.
Old 5th June 2019, 10:54   #6313  |  Link
stefanelli73
Hi, I wanted to know how to raise the subtitles inside the black bar of a movie contained in a BDMV folder, with MKV no problem with the internal subtitles of mpc-be using OVERRIDE PLACEMENT, while with BDMV it doesn't work.
stefanelli73 is offline   Reply With Quote
Old 5th June 2019, 12:32   #6314  |  Link
Aleksoid1978
stefanelli73 - Blu-Ray subtitles is PGS, it's bitmap format and render "as is". Can't change position in options. But you can "move" subtitles via key Ctrl+Shift+"Arrows".
Old 5th June 2019, 13:07   #6315  |  Link
stefanelli73
Thanks ALEKSOID for the reply, very kind.
Old 5th June 2019, 13:39   #6316  |  Link
clsid
Disable "Global Media Keys" in MPC-BE options. Win10 send play/pause event in some situations like when notifications appear.
Old 5th June 2019, 22:47   #6317  |  Link
yonta
That fixed the problem! Thanks.
Old 7th June 2019, 14:52   #6318  |  Link
stefanelli73
I tried, it doesn't work, with ctrl + shift + arrows it gives me the vsync
Old 7th June 2019, 20:57   #6319  |  Link
SirMaster
Does anyone know if there is some sort of API or mechanism that I can use to hook into MPC-BE's events like play, pause, stop?
For instance I want to run a script that turns off my room lighting when playback in mpc-be starts, and turns on room lighting when playback is paused or stopped.
Any ideas of how I could do this?
SirMaster is offline   Reply With Quote
Old 7th June 2019, 22:13   #6320  |  Link
stax76
Registered Lurker
Not supported by mpc, players I'm aware of are:
Lua: vlc, mpv(.net)
JavaScript: mpv(.net)
AngelScript: PotPlayer
COM Automation: JRiver
C Python: Kodi
IronPython: mpv.net
dotnet add-ons: mpv.net
PowerShell: mpv.net
CS-Script: mpv.net
