12th March 2017, 15:23 | #21622 | Link | |
Like fitness-trailer-8000.mkv hollywood-makeover-8000.mkv KAZU_(SUBTITLES)_4K23.98p_HEVC_10Mbits.mkv SHANE_ONEIL 4K24p_HEVC_10Mbits.mkv Writing application : DivXMKVMux 4.0.10.1893 Writing library : libDivXMediaFormat 4.0.0.0578 Writing application : DivXMKVMux 4.0.10.2513 Writing library : libDivXMediaFormat 4.0.0.0578
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 12th March 2017 at 15:27. |
12th March 2017, 15:42 | #21624 | Link | |
it looks like though some used it for Production and those broken streams are circulating now or some strange de/muxing operation created those non interoperable files now
Seeking though works somewhat here just takes ages also because the 4 cores are under practical full load and even the MadVR overhead seems already to much Runs a bit better without MadVR overhead but it's at the Edge of the Cores with some Latency issues here and there though not using latest lav decoder not sure if any improvements where done on the CPU decoding part it seems partly still underutilized. Though threading efficiency is problematic in this lav decoder and 99% is at such a critical edge there are no words for it how critical without efficient threading . That tractor scene kills it for some seconds pretty much at its motion peak (which most probably is also the complexity peak of the whole encode) And that is also pretty much DivX Profile target here Wonder if i can lower the complexity with Nvidias Encoder in Realtime without hurting it much, especially in those high motion scenes they are anyway semi perceptible overall already PS: Either i imagine things or some frames look very familiar from somwhere. Hmm That Cowboy, Rollercoster and Skateboard scene trigger something.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 12th March 2017 at 21:15. |
13th March 2017, 14:00 | #21625 | Link | |
The reason this was not working was it requires hdmi cable rather than optical cable to passthrough. It works fine over HDMI. Probably because of the bitrate requirements. Sorry to bother. |
14th March 2017, 09:01 | #21626 | Link |
I do remember that S/P-DIF or TOS-Link were limited to bitrates of 48 kHz stereo (1536 kbps). No chance to use it for 6-channel PCM. Some HD audio formats may surpass this as well.
14th March 2017, 18:15 | #21628 | Link |
LAV now requires AviSynth 2.6, and 2.5 is no longer supported, and I cannot comment on AVS+. If it doesn't match AVS 2.6 behavior/features, then its not supported.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 14th March 2017 at 18:20. |
14th March 2017, 23:02 | #21630 | Link |
LAV just uses ffmpeg, so if it doesn't work then it doesn't work. There is no AVS specific code in LAV itself.
Feel free to test with ffmpeg itself to see if it works there.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 15th March 2017 at 00:01. |
15th March 2017, 05:11 | #21632 | Link |
Hahaha! omg here's the message I got when trying to play my avs script in ffplay (comes with ffmpeg).
AviSynth version is too old. Please upgrade to either AviSynth 2.6 >= RC1 or AviSynth+ >= r1718. So, i went to the Avisynth+ website thinking maybe I didn't click the right thing earlier this week when I upgraded my version... and it still downloads build r1576..... So I checked here on Doom9 and found this post that was updated last July with a fork of the project hosted on github. Newest version there is r2440 There is no installer, but you can use the installer from r2294 and overwrite the files manually after. Will then work with ffmpeg , lav and mpc-hc |
15th March 2017, 08:40 | #21633 | Link |
Do not go to the AviSynth+ website to download (it may still link the "ancient" non-MT release). Instead, check the forum thread for MT releases by pinterf, like Avisynth+ r2440-MT, or his releases on github.
16th March 2017, 02:34 | #21634 | Link |
Is there a way to get the correct HDR infoframe from a file with LAV?
I use MPC-HC + LAV + madVR and a HDFury integral, so I can use HDR passthrough mode with madVR, but I still need the infoframe from the file for the Integral. Last edited by Q-the-STORM; 16th March 2017 at 02:37. |
16th March 2017, 12:56 | #21638 | Link |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
18th March 2017, 02:01 | #21639 | Link |
@nevcairiel
Hi nev, I ran into a tiny problem with recent LAV, the last working revision was 0.68.1-46. Since then, some videos became a stuttery mess, It can only be played normally if I disable DXVA. Here's a short sample... http://mir.cr/6KNZUMGL PS: Pay no attention to the video source |
18th March 2017, 05:52 | #21640 | Link | |
