27th May 2017, 01:58 | #4321 | Link | |
2nd June 2017, 01:52 | #4322 | Link |
I want playback to auto switch between both frame rates and resolution but cannot fathom how to do it. I want to play and auto switch 23.976fps @ 1080p and 23.976 fps at 2160p The change display options on playback only support one or the other. MPC-BE does not detect when a UHD video is playing compared to a 1080p video at the same frame rate. In MadVR you can set display switching between resolutions and frame rates but when I do that I have issues. If the display is currently set to 1080p and I play a 2160p video it switches to 2160p but the video displays in the top left quarter of the screen. If the display is currently set to 2160p and I play a 1080p video it only displays half the video on the right hand side of the screen.
Any help to fix this welcome. I am using an AMD RX 480 with latest drivers. Win10 Creators Update and 3 monitor setup (4K TV on my right). |
2nd June 2017, 02:24 | #4323 | Link | |
14th June 2017, 00:14 | #4324 | Link |
Does anyone know why I can't get bitstream audio to work in any 32 bit player? It just kinda died in Windows 10. I tried rolling back to a backup of when it did work but it's still not working. Only the 64 bit versions of MPC-BE and HC and Film & TV output bitstreamed audio. If I set to PCM output the 32 bit players work fine. Windows 10 Creators Update here plus AMD Radeon RX 480 (Yes I tried rolling back the drivers etc).
I wonder if some sneaky update in Win10 broke it. |
14th June 2017, 00:18 | #4325 | Link | |
20th June 2017, 11:55 | #4327 | Link |
@Klaus1189
Updated in r2635. A "stable" release is planned this summer. Perhaps before it will be a "beta" release.
21st June 2017, 03:45 | #4328 | Link |
Update of translation for Chinese traditional/simplified and Dutch
https://www.sendspace.com/file/wp3zof |
21st June 2017, 05:51 | #4330 | Link |
@beter
Thanks. Updated in r2637. It is planned, but now I will advise using madVR.
21st June 2017, 10:54 | #4332 | Link | |
We have not been supporting Windows XP for a year now. And we have not seen working computers with Vista or 7 that do not have SSE2 support. I would say that we just forgot about it. Thanks to the projects MPC-HC and LAV Filters.
23rd June 2017, 07:09 | #4334 | Link |
28th June 2017, 23:31 | #4335 | Link |
I'm all switched over from MPC-HC.
I noticed the option to pause video when BE is minimized. Now I like this option, but instead, what do you think about changing it to pause when BE is not "on top"? Often I'll go straight to maximizing another window. |
29th June 2017, 01:25 | #4336 | Link |
There will not be a such functional.
1st July 2017, 14:53 | #4337 | Link |
Thanks Aleksoid, this is a very useful feature.
Since this commit however, it seems to cause AV Sync issues quite often now. This typically occurs around, pause/resume and step forward/backwards. Seeking backwards or forwards often corrects this and rarely reopening the file may be required. Not sure if anybody else has noticed this?
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
1st July 2017, 15:57 | #4338 | Link | |
Since many years I almost exclusively use my personal/private DirectShow player staxplayer which I recently extended with DirectVobSub support so I can watch the last The Americans and The 100 seasons with original audio and subtitles, shortly I'll remove MPC from staxrip and integrate staxplayer instead. Audio players like MediaMonkey and MusicBee support pretty much anything via extension, staxrip also via event commands and powershell, this was ridiculously easy to implement: https://github.com/stax76/staxrip/bl.../Automation.vb For C++ a SDK can be done with COM+ like MediaMonky 4, with V8 like MediaMonky 5, with Lua like VLC or with Python like Kodi. Modern scripting engines with public API as part of Windows 10 are ChakraCore and PowerShell. Every other year I waste time making such posts, typically player devs don't even bother with a reply, let alone implement a feature request, don't take it hard, lately I received an mail regarding staxrip, content: Shit don’t work and it sucks.
4th July 2017, 20:40 | #4339 | Link |
MPC-BE (Basque update)
Hi MPC-BE Team,
I updated Basque translation for MPC-BE 1.5 You can get it here: Basque Update Please release it. Thanks!! |
5th July 2017, 04:20 | #4340 | Link |
@Azpidatziak
Thank you. Updated in r2689. Fresh night build will be tomorrow.
