Old 20th February 2018, 19:21   #461  |  Link
benwaggoner
Originally Posted by mzso View Post
It seems like to me that HEVC and AVC mostly had patent trolls. Who were only interested in filling their pockets.
DEFINITELY not mostly. Companies that really wanted to contribute to it so they could use the technology most joined the reasonable MPEG-LA pool.
Sent from my iPhone using Tapatalk
Ben Waggoner
My Compression Book
Old 20th February 2018, 22:30   #462  |  Link
IgorC
And we actually have good audio quality perceptually correlated metrics, which makes automated tuning and testing much more feasible and useful.
Audio metrics are no better than any video metrics.
Both have flaws.
Final quality verification tests of absolutely every meaningful audio standard were made by testing ... on humans.
IgorC is offline   Reply With Quote
Old 23rd February 2018, 22:43   #463  |  Link
Clare
Experimental AV1 encoder in Rust: https://github.com/xiph/rav1e
I'll be adding new data to my comparator with a AV1 snapshot from 20180222, next week or so. I've changed the encoder parameters for more speed so I need to recalculate the old snapshots to have comparable data.
Also I added the PIK image format.
I also plan to do an actual video comparaison based on 30 short clips, VMAF metrics, AV1, X264, X265, and VP9. Gonna take a long while as I haven't written a single line of code yet and the encoding itself will be long.
Maybe AV1 will be bitstream freezed then. Latest estimate are: "AOM: Bitstream maybe March, maybe announce at NAB (early April)"
(https://www.nabshow.com/ from April 7th to April 12th)
Clare is offline   Reply With Quote
Old 23rd February 2018, 23:33   #464  |  Link
hajj_3
I hope you do comparisons at many resolutions e.g: 360p, 480p, 576p, 720p, 1080p, 1440p, uhd. A lot of the benchmarks shown so far comparing av1 to x264, x265 and vp9 either just show the overall difference or they show 360p, 720p and 1080p. I am more interested in the improvement of 360p-720p as x265 doesn't have that much improvement over x264 at those resolutions.
Old 24th February 2018, 00:36   #465  |  Link
Clare
I plan to use objective1-fast https://people.xiph.org/~tdaede/sets/objective-1-fast/
It's a mix of 360p, 720p and 1080p. I don't have any 1440p or UHD content and I doubt my computer would be able to process it in a reasonable time. But I plan to release the Python scripts I use on Github so it will be usable on any dataset, like I did for images (https://github.com/WyohKnott/image-comparison-sources).
Or I need to buy a Threadripper… when I have lots of money and no taxes to pay.
Old 24th February 2018, 00:40   #466  |  Link
Clare
objective2-slow https://people.xiph.org/~tdaede/sets/objective-2-slow/ has UHD content. Might be useful.
Old 24th February 2018, 19:05   #467  |  Link
New upload: AOM v0.1.0-8231-gcb4622dee
Old 24th February 2018, 22:01   #468  |  Link
Tommy Carrot
Tommy Carrot's Avatar
Thanks for the comparisons.
The new AV1 blurs even more than the older ones. I know it's primarily a video encoder, so it's not really tuned for still images, but in its current form it's not really doing a good job as an image encoder.
However, PIK is really interesting. It basically behaves like a much more efficient JPEG. It has blocking and ringing artifacts, but preserves much more details than the other encoders. I sure prefer it over the artifactless, but sterile looking and blurry AV1 or HEVC images.
Tommy Carrot is offline   Reply With Quote
Old 26th February 2018, 01:11   #469  |  Link
Clare
I've just stumble onto that on Github: https://aomediacodec.github.io/av1-avif/
AV1 Still Image File Format (AVIF)
Overview
AVIF is a file format wrapping compressed images based on the Alliance for Open Media AV1 intra-frame encoding toolkit. AVIF supports High Dynamic Range (HDR) and wide color gamut (WCG) images as well as standard dynamic range (SDR). Only the intra-frame encoding toolkit is used in AVIF version 1.0. Using the intra-frame encoding mechanism from an existing video codec standard has a precedent in WebP: VP8, and HEIF: HEVC. This document describes at a high level a proposal on the structure of AVIF version 1.0.
The initial version of AVIF seeks to be simple, with just enough structure to allow the distribution of images based on the AV1 intra-frame coding toolset. At its core, AVIF 1.0 will allow for one or more images plus all supporting data needed to correctly reconstruct and display the images to be conveyed in a file. The ability to embed a thumbnail image will also be provided. An image sequence with suggested playback timing may be defined.
Old 26th February 2018, 10:43   #470  |  Link
bstrobl
The part where it says:
An AVIF file should be a simplified and conformant version of an [HEIF] file.
would imply this is basically HEIF with AV1 as still image codec, which is a sensible choice.
Not a big fan of the ringing artefacts in PIK, those bother me quite a lot more.
bstrobl is offline   Reply With Quote
Old 26th February 2018, 12:19   #471  |  Link
mzso
I wonder why they bother with HEIF/ISOBMFF when AV1 is already webm/matroska centric.
Old 28th February 2018, 01:28   #472  |  Link
TD-Linux
If you want to experiment, you can build an encoder with -DCONFIG_DIST_8X8=1 and then specify --tune=cdef-dist or --tune=daala-dist. These will optimize away from blurring and towards ringing.
TD-Linux is offline   Reply With Quote
Old 4th March 2018, 11:09   #473  |  Link
bstrobl
Here is the buglist for the bitstream:
https://bugs.chromium.org/p/aomedia/...mary&cells=ids
Presumably once all of those have been fixed the bitstream can be frozen.
Looks like everyone is working on weekends to get this thing done.
Old 4th March 2018, 14:11   #474  |  Link
hajj_3
not sure, I have been following this list: https://bugs.chromium.org/p/aomedia/...um=100&start=0
It is down to 75 bugs, 2.5 weeks ago it was at 215 bugs so probably another 1-2 weeks or so until it is ratified.
Old 4th March 2018, 17:40   #475  |  Link
Clare
So it was easier to code than I thought, with few changes from the image comparison.
It's up there: https://wyohknott.github.io/video-formats-comparison/
I haven't added AV1 yet, I'm waiting for the bitstream freeze.
Let me know what you think would be good to add. I put most of the graph I thouqgt would be useful. I wish I could addsome examples videos to plŕy side by side but I don't know how to do that.
Old 4th March 2018, 18:47   #476  |  Link
Jamaika
Each Y4M videos is exported to 4:2:0 10 bits Y4M with FFMPEG:
ffmpeg -y -i [input] -pix_fmt yuv420p10le -strict -1 [output]
Video compression
All videos are compressed over a range of qualities for each encoder:
•AV1:
◦between q=12 and q=60, with a step of 4:
aomenc --cpu-used=2 --tile-columns=4 --passes=2 --pass=1 --bit-depth=10 --input-bit-depth=10 --end-usage=q --cq-level=$q --fpf=[output].log -o [output] [input(Y4M_10bits)]
aomenc --cpu-used=2 --tile-columns=4 --passes=2 --pass=2 --bit-depth=10 --input-bit-depth=10 --end-usage=q --cq-level=$q --fpf=[output].log -o [output] [input(Y4M_10bits)]
•VP9:
vpxenc --tile-columns=4 --row-mt=1 --passes=2 --cpu-used=2 --bit-depth=10 --input-bit-depth=10 --profile=2 --end-usage=q --cq-level=$ -o [output] [input(Y4M_10bits)]
•x264:
◦between q=12 and q=40, with a step of 2:
x264 --profile high10 --preset slower --input-depth=10 --output-depth=10 --crf $q -o [output] [input(Y4M_10bits)]
•x265:
x265 --profile main10 --preset slower --input-depth=10 --output-depth=10 --crf $q -o [output] [input(Y4M_10bits)]
My ideas:
ffmpeg.exe -loglevel verbose -i "[input(your_colorspace).raw]" -an -f yuv4mpegpipe -vf scale=1920:1080:in_color_matrix=rgb:in_range=full:out_color_matrix=bt2020_ncl:out_range=full,format=yuv422p10le -strict -1 -
ffmpeg.exe -loglevel verbose -i "[input(your_colorspace).y4m]" -an -f yuv4mpegpipe -vf scale=1920:1080:in_color_matrix=S_gamut3:in_range=full:out_color_matrix=bt2020_ncl:out_range=full,format=yuv422p10le,lutyuv=val:val:val -strict -1 -
aomenc.exe --bit-depth=10 --input-bit-depth=10 --i4?? --codec=av1 --good --threads=? --cpu-used=? --profile=3 --drop-frame=(0 or 100 depends on fps) --end-usage=q --cq-level=48 --target-bitrate=0 --min-q=?(the problem bitrate of the first frame)
--kf-max-dist=GOP --auto-alt-ref=? --frame-boost=? --aq-mode=0 --color-space=bt2020 --verbose --debug --pass=? --passes=? --output="xxx.webm" - (where is range full?)
x264.exe --demuxer y4m --input-csp i4?? --input-depth 10 --input-range pc --output-csp i4?? --threads ? --preset slow --tune grain --crf 28 --fps ??.??? --keyint 60 --nal-hrd none --vbv-bufsize 40000 --vbv-maxrate 40000(use for web or don't use)
--colormatrix bt2020nc --colorprim bt2020 --transfer bt2020-10 --range pc --output "xxx.h264" -
Old 5th March 2018, 07:07   #477  |  Link
o-l-a-v
You are linking to PIKs github page for x265.
"x265: https://github.com/google/pik. The version used is built from GIT revision 3cf3839f82bb177c43449ab10792c184c4485d8b"
o-l-a-v is offline   Reply With Quote
Old 5th March 2018, 12:26   #478  |  Link
Tommy Carrot
Nice.
I think XVC encoder could be interesting to see. I know it's a proprietary codec, but quality-wise, in my experience, it competes quite well with x265 and AV1.
Old 5th March 2018, 16:07   #479  |  Link
clsid
Does anyone have a link to a sample file that was encoded by a recent build?
Old 5th March 2018, 22:33   #480  |  Link
Just for you ... I created a "samples" subdirectory in my AOM MediaFire folder; it contains a WebM clip of "foreman" in PAL CIF resolution, encoded with AOM encoder v0.1.0-8300-g088217b2e (built Feb. 27, I hope that's recent enough) with '--cpu-used 8' (supposed to be a faster preset). Encoding took 3/4 hour on this aged PC with AMD Phenom-II (max. SSE2).
Tomorrow I could try a newer one with faster hardware.
