27th October 2018, 16:43 | #16261 | Link | |
ByteShare
It happens on the getting info step after indexing. My work around now is I do one file that had failed to get it to fail, then I can do another file that had issues during the batch. Basically it seems to fail > work > fail > work ...etc. Other than that, there isn't a real pattern I can see. I can even do the same file more than once and repeat the fail > work > fail > work ... pattern. Error when doing it via the Add: Code:
I don't know what 'YV12' means. (C:\Temp\RipBot264temp\job240\getinfo.avs, line 8) Last edited by byteshare; 27th October 2018 at 16:50. |
27th October 2018, 18:34 | #16262 | Link |
post content of C:\Temp\RipBot264temp\job240\getinfo.avs
27th October 2018, 23:36 | #16263 | Link |
I don't know what 'YUV420P10' means.
(C:\Temp\RipBot264temp\job14\getinfo.avs, line 8) trying convert my UHD BD set to NAS... the rest is OK. MKV created with makemkv. second try and it worked. Code:
185954 23.976025 0 0 0 3840 1600 YUV420P10 LoadPlugin("C:\Program Files\RipBot264DE\Tools\AviSynth plugins\ffms\ffms_latest\x64\ffms2.dll") FFVideoSource("D:\movie.mkv",cachefile = "C:\Temp\RipBot264temp\job14\movie.mkv.ffindex") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","Framecount") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","Framerate") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","AudioRate") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","AudioChannels") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","AudioLength") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","Width") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","Height") WriteFile("C:\Temp\RipBot264temp\job14\info.txt","PixelType") Trim(0,-1)
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD Last edited by jlpsvk; 28th October 2018 at 00:01. |
28th October 2018, 15:14 | #16264 | Link |
ByteShare
Different job, but same error:
49416 23.976025 0 0 0 696 390 YV12 LoadPlugin("C:\RipBot\Tools\AviSynth plugins\ffms\x64\ffms2.dll") FFVideoSource("C:\ReEncode\Angel.Cop.OVA.02.[DVD][Hi10][480p][FLAC].[8C96EEE1].[Koten.Gars].mkv",cachefile = "C:\Temp\RipBot264temp\job243\Angel.Cop.OVA.02.[DVD][Hi10][480p][FLAC].[8C96EEE1].[Koten.Gars].mkv.ffindex") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","Framecount") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","Framerate") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","AudioRate") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","AudioChannels") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","AudioLength") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","Width") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","Height") WriteFile("C:\Temp\RipBot264temp\job243\info.txt","PixelType") Trim(0,-1) |
29th October 2018, 04:24 | #16266 | Link | |
ByteShare
You can do this after you add them and if you click > Shift+Click again you can select a range and move that run up and down. |
30th October 2018, 23:38 | #16267 | Link |
ByteShare
I noticed RipBot can't read Japanese: "特典映像(アニメまつり).mkv" turns into "????(??????).mkv"
I don't remember this being an issue, but I don't usually leave my files in Japanese for compatibility. For now the easy work around is to just rename the files for encoding and then name them back to the original name. I think I did something wrong, but after opening and closing RipBot 3 times (was there two updates?), With current update not seeing the issues with the "I don't know what 'YV12' means." Thank you. Last edited by byteshare; 31st October 2018 at 04:43. |
2nd November 2018, 10:39 | #16269 | Link |
I have an issue and I'm not sure if it relates to Ripbot or not. I have been converting files the last few days to have all 7 seasons of The Game of Thrones on my PC. I have noticed that several files will say "cannot render the file" when I try to play them. So I re-rip them and most the time they are fine. I've now gone back and checked the files and again, many have this error, even after a re-rip and check that it played right afterward. I don't know what is going on that keeps corrupting my files, but it's getting very annoying.
2nd November 2018, 13:39 | #16270 | Link |
...memory issues, corrupted HDD/SSD , Overheating CPU and so on ...
2nd November 2018, 16:35 | #16271 | Link |
ByteShare
http://msystem.waw.pl/x265/
Stable HEVC now at 2.9+4-471726d |
3rd November 2018, 17:59 | #16272 | Link |
Hi there!
I am currently testing RipBot for HDR encodes to a mkv container. I am somehow missing the option to encode the audio tracks (DTS TrueHD and so on) to FLAC lossless audio - I only have the option Opus, AAC und AC3 - is there really no FLAC support? |
3rd November 2018, 20:05 | #16276 | Link |
ByteShare
Waiting for file...
While adding files to the queue via the batch option I'm having an issue with the file stalling out or something (not 100% what is happening).
The batch queue seems to get stuck saying: "Waiting for file... [xxxxx.mkv]" I can abort and then start it again, and it seems to work but then gets stuck again later. Seems to happen no matter what AVISynth settings I'm using either with custom script or without. I haven't tried changing my HEVC settings though. I'm using a local SSD for the source files and TEMP folder. I have "skip demuxing process" on as well. I'm not sure how to gather more information on this. This isn't a major deal since I just have to abort and start the queue again. |
3rd November 2018, 20:52 | #16277 | Link | |
I gotta check that, I always though there is difference |
3rd November 2018, 23:41 | #16278 | Link |
oops. Seems like I did get that wrong when I read up on encoding audio tracks recently. Prior I always just stream copied the audio.
But the last encodes I converted it to flac as - now after extracting a DTS track of 770mb and converting it to flac of 2500mb it seems that's a nonsense idea .....crap :-) |
4th November 2018, 04:25 | #16279 | Link | |
ByteShare
