7th November 2009, 10:52 | #5901 | Link | |
dings!
I've installed ffdshow and haali on my XP 32 bit. Is there a possibility to tell BD-Rebuilder not to use ffms2.dll for decoding? Thanks MvB |
7th November 2009, 13:36 | #5902 | Link | |
Could you do me a favour and report back? For your Monsters vs. Aliens copy, could you check the "Animator's Corner" PiP extra when the movie is playing and see if you have audio. I'm having a few problem with full backup BD-9. If you've got audio then I'm going to try to recode using your settings. Thanks -Lynx |
7th November 2009, 15:18 | #5903 | Link | |
Monsters vs. Aliens
I did not do as BD9. I did as BD25. Second audio on PIP video works but is seriously out of sync. Never noticed before. jdobbs--Why would the audio of PIP video be out of sync on full backup BD25 shrink of Monsters vs. Aliens? Moviewatcher666 |
7th November 2009, 15:24 | #5904 | Link | |
It came out with the audio synched correctly. Could you post your INI so I can make sure my settings match yours? Also, could you look at MUX_MOVIE_ONLY.META and see if the audio is adjusted for either of the tracks? If it is you should see "timeshift=" in the line associated with the track. Last edited by jdobbs; 7th November 2009 at 16:01. |
7th November 2009, 15:26 | #5905 | Link | |
[Paths] FFMS2= It will see the path as empty, and assume it doesn't exist. But I'm not sure it will help in your case -- because it won't even try to load it until it fails with FFDSHOW. Last edited by jdobbs; 7th November 2009 at 15:31. |
7th November 2009, 16:42 | #5906 | Link | |
Here the .ini (to my best knowledge as it was ...): [Options] #FIXED_CRF=19 QUICK_CRF=26 #TWEAK_PASS_ONE=--me umh --tune film #TWEAK_PASS_TWO=--me umh --tune film #KEEP_MBTREE QUICK_USE_QUALITY=1 SHOW_ENCODER=1 FORCE_ENCODE=0 PROCESS_SECONDARY=1 RESIZE=0 MODE=1 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=deu;ger; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 VERBOSE_STATUS=1 ONEPASS_ENCODING=1 TARGET_SIZE=4369 [Paths] WORKING_PATH=C:\TEMP\BD REBUILDER\ SOURCE_PATH=F:\BD MOVIES\BD NCFM\ The MUX_MOVIE_ONLY.META is here Last edited by Sharc; 7th November 2009 at 16:51. |
7th November 2009, 17:57 | #5907 | Link |
Hello everyone
I am trying to do Full Backup BD25 for Transformer2 and Star Trek generation. Using 31.01(Keep HD udio , high quality 2 pass) the backup was successful but i cant even see the movie on my PowerDVD 9 nor my Panasonic BD player(BD35). When Inserting the BD i can see back screen with the timer counting endlessly no menu no video. what am I doing wrong? |
7th November 2009, 23:07 | #5908 | Link |
Batch Mode Bug with Alternative Movie
I thought I saw a update entry stating this was fixed but I don't think it has based on my recent efforts with 24 Seties 7. Pending the title blanking feature i'm resorting to a Movie Only route, each time i'm going for Alternative Movie choice and selecting each episode in turn, saving to a new processing path and saving as a backup project to run in Batch mode. I tried running these last night in Batch mode but the 2nd, 3rd and 4th disc episodes are just repeats of the first disc episode (ie - the job file does not appear to be saving the specific title I want run each time - it just resorts to the first title each time).
8th November 2009, 06:20 | #5909 | Link | |
I am having the same Sync problem as well, I am doing Amadeus and the audio and video won't sync at all. I never had this problem until the FFMS2.dll start to pop up. As of now I can't back anything until this problem is fix. This is the log: [19:51:25] BD Rebuilder v0.31.01 (beta) - Source: AMADEUS - Input BD size: 31.26 GB - Approximate total content: [03:00:25.689] - Target BD size: 19.53 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:51:25] PHASE ONE, Encoding - [19:51:25] Extracting A/V streams [VID_00000] - [20:40:16] Reencoding: VID_00000 (1 of 1) - Switching to FFMS2.DLL for decoding. [21:06:16]PHASE ONE aborted by user request |
8th November 2009, 13:06 | #5910 | Link | |||
dings!
@skylab1 Quote:
skylab, did you install wmp11 on your system or did you check in ffdshow video encoder whether vc1 decoding is activated? Found out because the demuxing bdrebuilder created a .vc1 file. My mistake, after installing wmp11 it seems to work without calling ffms2. Seems like i overlooked number 8. let's see whether that helps. Encoding will be finished in 11 hours |
8th November 2009, 22:39 | #5912 | Link | |
I have wmp12 installed, comes with win7 ult 64, I disable VC-1 and now it won't even encode. [11:57:47] PHASE ONE, Encoding - [11:57:47] Extracting A/V streams [VID_00000] - [12:46:20] Reencoding: VID_00000 (1 of 1) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [12:49:56] - Failed video encode, aborted ----------------------- [13:30:49] BD Rebuilder v0.31.01 (beta) - Source: AMADEUS - Input BD size: 31.26 GB - Approximate total content: [03:00:25.689] - Target BD size: 19.53 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [13:30:51] PHASE ONE, Encoding - [13:30:51] Reencoding: VID_00000 (1 of 1) - Encode failed. Retrying. When I re-enable the VC-1 in ffdshow, the ffms2 come back. I am at a lost at the point, the last BD I did was superman return and it work fine as always no sync problem. I also try add ffms2= and that didn't work either, I think removing ffms2 out of the program is the best option. |
9th November 2009, 01:22 | #5913 | Link | |
9th November 2009, 03:54 | #5915 | Link | |
9th November 2009, 04:46 | #5916 | Link |
Decoders
Hi There,
I know for VC-1 you must install WMP11 and disable VC-1 in FFDSHOW. I have tested this and it works great. Now for H.264/AVC what codec setting do you use "libavcodec" or "ffmpeg-mt"? Installing the latest FFDSHOW defaults to "ffmpeg-mt", if I am correct. Which one produced the best results for you with the least problems? Thanks. |
9th November 2009, 06:27 | #5917 | Link | |
Thanks for the tip, I'll try that. |
9th November 2009, 06:30 | #5918 | Link | |
9th November 2009, 08:19 | #5919 | Link | |
You can check the "HIDDENOPTS.TXT" listed in the root of the BD-R directory. They are listed there, however, I've noticed that in browsing jdobbs forum postings that not all of them are listed. @jdobbs, For future releases is it possible to have them all listed - cause there seems to be some great switches out there that give this program a lot of flexibility for advanced users? -Lynx Last edited by Lynxs; 9th November 2009 at 08:24. |
9th November 2009, 09:50 | #5920 | Link |
Thanks Skylab1
What I would like to know is what is recommended by jdobbs for encoding H.264/AVC in FFDSHOW and what is preferred by the users? From what I have read in this threat is it seems that Windows 7 / problematic users uses "ffmpeg-mt" but which one (libavcodec / ffmpeg-mt) would produce the best quality? Thanks |
