Old 14th February 2025, 20:57   #21141  |  Link
archiel
Does anyone know if / how to manage a file with HLG video. RIPbot264 is not recognising it as HDR and so in the output (according to mediainfo)
BEFORE
HDR format : Dolby Vision
HDR format : Dolby Vision, Version 1.0, Profile 8.4, dvhe.08.10, BL+RPU, no metadata compression, HLG compatible
HDR_Format_Commercial : HLG
HDR_Format_Version : 1.0
HDR_Format_Profile : dvhe.08
HDR_Format_Level : 10
HDR_Format_Settings : BL+RPU
HDR_Format_Compression : None
HDR_Format_Compatibility : HLG
colour_description_present_Source : Stream
Color range : Full
colour_range_Source : Stream
Color primaries : BT.709
colour_primaries_Source : Stream
Transfer characteristics : PQ / BT.709
AFTER no HDR and
Color range : Limited
Transfer characteristics : BT.709
archiel is offline   Reply With Quote
Old 16th February 2025, 15:57   #21142  |  Link
Ryushin
Ryushin's Avatar
Audio Core Option
Atak, thanks for the update. The EncodingServer option "/avisynth-setmemorymax 16" is much appreciated.
I have a small feature request. When demuxing from discs there is a option to extract the Core from the audio stream. So DTS-HD lossless has an option for DTS 5.1 compressed stream. Same goes for TrueHD.
I'd like an option in the Audio compression settings to include a CORE option above the COPY STREAM setting.
I normally always select the core audio when using MakeMKV to extract the TV episodes, but if I forgot to do that, then I have run a little script like:
for I in *.mkv;do ffmpeg -i $I -bsf:a dca_core -c:a copy $(basename -s .mkv $I).dts;done
Then I manually add the audio stream in the UI and make my changes. It would just be nice to have the Core option in the UI as well. Thanks much.
SMDegrain Lite package for RipBot264: https://cloud.chrisdos.com/s/yiXwKbkMsQoNo6X
Old 16th February 2025, 16:50   #21143  |  Link
Juha
I have issues with distributed encoding. My client PC cannot connect the server PC. It tries to connect, displays "connecting" text for a short while, then the attempt disappers. And then tries soon again (I have automatic reconnect enabled), but no avail.
- I have rebooted both of my PCs
- PCs are on the same network
- PCs can see each other in the "Distributed encoding" tab. They have the correct ip and correct network adapter selected (verified by checking mac address)
- I have allowed them through firewall when it was prompted. Also I can see that both encoding client and server exe files are fully allowed in the firewall settings
- Authentication info (username and password) is correct
Client is Win 11 machine and Server is Win 10 machine, if that matters.
Running 1.27.4, all the updates installed that are provided by updater.
Juha is offline   Reply With Quote
Old 16th February 2025, 17:30   #21144  |  Link
maybe you have to bind encoding server to different ip
Old 16th February 2025, 17:53   #21145  |  Link
rlev11
Atak,
Thanks for the update!!
Just so i am understanding this, we can now set the max memory individually for each server (in my case via command line) which takes control of it out of the script that gets sent to each server from the client. This is perfect for tuning individual servers with different cpu/memory requirements. However I did notice that if I hit edit script when I load up a job, the SetMemoryMax(8192) is still being populated in the #MT section. Will the individual server settings just override what is in the script on the client job??
rlev11 is offline   Reply With Quote
Old 16th February 2025, 21:08   #21146  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by rlev11 View Post
Atak,
If you open up the EncodingClient you will see the new options with the amount of memory being allocated. Very cool. Perfect solution to the problem.
Old 16th February 2025, 21:12   #21147  |  Link
Ryushin
Ryushin's Avatar
Atak, I forgot mention that it wold be great to have the CORE option in the audio profiles. This way I don't have to de-select the DTS-HD audio track in MakeMKV and just let RB handle the audio decision.
Old 18th February 2025, 22:05   #21148  |  Link
squezer
Chinese addvertising or what is this
Hi, Attack,
I noticed strange Chinese text next to window preview for windows 11 taskbar, and in translation it says strange and rude things,
how can I get rid of it, please?
/see attachment screenshot/
squezer is offline   Reply With Quote
Old 19th February 2025, 03:30   #21149  |  Link
frencher
French Love
What is your username in windows? show me TCP communication log when you use user name and password.
[2025-02-19 03:18:27] Client established connection with server.
[2025-02-19 03:18:27] Command "CONNECT" received from client.
[2025-02-19 03:18:27] Connecting with client... (192.168.1.97:1002)
[2025-02-19 03:18:27] Established connection with client. (192.168.1.97:1002)
[2025-02-19 03:18:27] Command "AUTHENTICATE" received from client.
[2025-02-19 03:18:28] Shared folder requires authentication.
[2025-02-19 03:18:28] Authenticating shared folder...
[2025-02-19 03:18:49] L'erreur systŠme 86 s'est produite.
[2025-02-19 03:18:49] Le mot de passe r‚seau sp‚cifi‚ est incorrect.
[2025-02-19 03:18:49] Authentication failed!
1|CLIENT -> SERVER| AUTHENTICATE=net use \\192.168.1.97\Ripbot264temp /user:Anthony MyPassword
2|CLIENT <- SERVER| OK
Or
1|CLIENT -> SERVER| AUTHENTICATE=net use \\192.168.1.97\Ripbot264temp /user:My Name Is Anthony MyPassword
Fix ?
1|CLIENT -> SERVER| AUTHENTICATE=net use \\192.168.1.97\Ripbot264temp /user:"My Name Is Anthony" "MyPassword"
Strange french character problem from CMd.exe ? > éèçàùêë ?
[2025-02-19 03:18:49] Le mot de passe rseau spcifi est incorrect.
And who should be
[2025-02-19 03:18:49] L'erreur système 86 s'est produite.
[2025-02-19 03:18:49] Le mot de passe réseau spécifié est incorrect.
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 19th February 2025, 03:56   #21150  |  Link
Manually execute this command in cmd.exe
Check if you have set proper codepage for non utf8 apps.
https://i.sstatic.net/lAsEt.png
Old 19th February 2025, 05:40   #21151  |  Link
frencher
French Love
Hi Atak,
Does not work
net use \\192.168.1.97\Ripbot264temp /user:My User Name Is Anthony MyPassword
Work
net use \\192.168.1.97\Ripbot264temp /user:"Anthony" "MyPassword"
Or
net use \\192.168.1.97\Ripbot264temp /user:"My User Name Is Anthony" "MyPassword"
It's possible to change network card in Encoding Server ?
I have two on my motherboard and it chooses the wrong one.
Old 19th February 2025, 05:56   #21152  |  Link
TR-7970X
TR-7970X's Avatar
RipBot264 Settings / Distributed Encoding tab / Adapter Description
TR-7970X is offline   Reply With Quote
Old 19th February 2025, 06:04   #21153  |  Link
frencher
French Love
Does not change anything in Encoding Server even if the EncodingClient.ini file is updated
Old 19th February 2025, 06:14   #21154  |  Link
TR-7970X
TR-7970X's Avatar
You'll have to disable one of the NIC's on your board, or change their priority.
https://www.windowscentral.com/how-c...ers-windows-10
Old 19th February 2025, 13:52   #21155  |  Link
EncodingServer.exe /ip xxx.xxx.xxx.xxx
Old 19th February 2025, 13:55   #21156  |  Link
Hi Atak,
Does not work
Work
Or
Does it work if you include quotes directly here?
Old 19th February 2025, 16:14   #21157  |  Link
frencher
French Love
Hello Atak,
Yes this fixes the problem and works for my 4 PCs
Old 19th February 2025, 16:24   #21158  |  Link
frencher
French Love
OK
I deactivated the card which is not used.
Wouldn't it be possible to add the reading of "EncodingClient.ini" to retrieve the IP or choose a ComboBox allowing this choice?
Old 19th February 2025, 20:47   #21159  |  Link
rlev11
OK
So what I do is in my ripbot.ini file I have this line:
Server1CommandLine=/ip 192.168.1.201 /port 1000 /priority normal /restart-if-no-progress /avisynth-prefetch-threads 0 /x264-threads 32 /x265-threads 32 /avisynth-setmemorymax 16
This sets the server to use the proper ip address upon ripbot startup and open the server window on the desktop.
then in my encodingclient.ini I have :
[settings]
ClientIP=192.168.1.201
and then again under server ip address section I have this:
ServerIP1=192.168.1.201:1000
Old 20th February 2025, 14:28   #21160  |  Link
frencher
French Love
[settings]
Thanks for the feedback
