3rd January 2014, 10:19 | #3781 | Link | |
- tools/avs - tools/avs/plugin and in tools/x264 but still the same problem. If I put msvcr120.dll in C:\Windows\SysWOW64 all is working fine and without error. P.S: My OS isn't W7 or XP, but Windows Web Server 2008 R2 Service Pack 1 64 bit |
3rd January 2014, 11:35 | #3782 | Link |
Odd. I'm using XP so I checked the system32 folder. I don't have msvcr120.dll in there. Lsmash works fine as long as MeGUI isn't configured to use a specific output folder (ie lsmash can use the input source folder).
3rd January 2014, 12:46 | #3784 | Link | |
In my case, my Megui is configured to use a specific folder! But...... if I CHECK the option in Settings (Main Configuration) "Always use the included Avisynth" then there is no need to copy any dll in system32 or SysWOW64 !!! Last edited by TSoft; 3rd January 2014 at 14:03. |
3rd January 2014, 12:55 | #3785 | Link | |
There's a text file included in the zip file explaining exactly what to look out for. Cheers. PS I forgot to mention.... when indexing with Ismash, it changes the frame rate to match the duration. So due to one duplicate/missing frame in the 30 second sample, the output frame rate changed from 25fps to 24.972fps. Without fpsnum and fpsden added to the script to duplicate the "repeated" frame, ffmsindex does the same thing. Last edited by hello_hello; 3rd January 2014 at 13:22. |
3rd January 2014, 13:43 | #3786 | Link | |
I assume there's no danger in manually copying msvcr120.dll to the system32 folder? The something else I was checking..... When is a CPlugin not a CPlugin? At the moment while running the portable version of AVISynth+, MeGUI uses LoadCPlugin to load ffms2.dll, but when I try to open the script with a different program (and therefore via Avisynth 2.5.8), Avisynth complains about it not being a C plugin. Would it be safe to assume it's not actually a C plugin, it's just that Avisynth+ isn't as whiney as Avisynth, because it'll load ffms.dll as either a standard or a C plugin (I'm referring to ffms 2.19). Last edited by hello_hello; 3rd January 2014 at 13:49. |
3rd January 2014, 14:30 | #3787 | Link |
Test build available: http://megui.org/test/MeGUI.zip
The build number is still 2449 but these changes are included: Code:
xxxx [LSMASH Indexer] show time/file progress during indexing added possibility to set output file/folder blocked indexer if input file is in a read only directory lowered the default priority so that it will be used after FFMS added log information copy the runtimes if required [FFMS Indexer] defaults to LoadPlugin if LoadCPlugin is also possible MeGUI MeGUI\tools\lsmash MeGUI\tools\ffmpeg MeGUI\tools\x264 MeGUI\tools\x264_10b MeGUI\tools\x265 MeGUI\tools\xvid_encraw I am now going to implement this. Last edited by Zathor; 3rd January 2014 at 15:21. |
4th January 2014, 12:55 | #3792 | Link | |
I can't update last MeGUI versions:
4th January 2014, 15:15 | #3794 | Link |
Problem with FFAudioSource is fixed for me, as also is the L-Smash issue. There was also a problem with the 'Add Folder' option for the One Click Encoder; a demux dialogue popped up requiring some kind of input that didn't work, though this is fixed now in the latest version.
Thanks. |
4th January 2014, 19:12 | #3795 | Link |
2454 [Log] show information about .NET 2.0 and 4.0 [Log] removed information about highest .NET build 2453 [Audio Encoder] fixed sometimes choosing the wrong decoder (regression of 2448) 2452 [Audio Encoder] lowered also the priority for the audio decoder [Audio Encoder] default order: NicAudio, BassAudio, FFAudioSource, LWLibavAudioSource, DirectShow 2451 [Chapter Creator] added support for mkv input files [Chapter Creator] added option to specify the minimum title length [Chapter Creator] added option to specify the FPS value [Chapter Creator] improved FPS detection for DVD/Bluray |
4th January 2014, 20:05 | #3796 | Link | |
4th January 2014, 21:54 | #3799 | Link | ||
After I installed .NET 4 but work with MeGUI at last until v2424
5th January 2014, 10:25 | #3800 | Link |
MeGUI uses the registry information to determine the installed .NET version. Please have a look into your registry: http://support.microsoft.com/kb/318785/en-us
Or upload an registry export of HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP Have you ever modified this part of the registry? Maybe you can try to uninstall & install .NET 2.0. The check does work on my XP SP3. The check for .NET 2.0 does not make much sense as the application is running with it. But the check itself must work as otherwise the exe will be replaced with an 4.0 exe and then it will not work when 4.0 is not installed. |
