Old 14th February 2019, 22:53   #261  |  Link
Revan654
Revan654's Avatar
Originally Posted by fredlkrue View Post
I am trying to update StaxRip but I am getting the following message, any idea how to fix it?:
That looks like old Code, It's all based on how you make a connection with github. That message looks to be from sourceForge connection when StaxRip used 7zip portable.
Things keep changing and it's hard to keep up with them. I never really bothered with the API. I should look into one day.
It will not download any releases from the Pipeline (https://ci.appveyor.com/project/Reva...uild/artifacts) you have to do that manually. I don't think appveyor has an API, The site uses unique keys. You would need to do a bunch of web scrapping to get the key Which Requires cookiedata + another Key to create the key, then use that key to obtain the dl page.
My other Program does it for another site, Code is another 300+ lines and Usage of RestAPI. I really don't want to add more files to required files for StaxRip to run.
Revan654 is offline
Old 15th February 2019, 00:54   #262  |  Link
gonca
My needs are simple
I want to load a Vaporsynth/Avisynth script and use the encoder of my choice. Then I would mux to MKV (video only)
Is there a way to use StaxRip with only x265 and Mkvmerge (no AvsMeter, BDSup2Sub, etc)
gonca is offline
Old 15th February 2019, 03:54   #263  |  Link
fredlkrue
Its not a big deal, I can update it manually, thanks.
P.S. Where do I get all the updated 3rd party apps used by StaxRip?
fredlkrue is offline
Old 16th February 2019, 11:40   #264  |  Link
Magik Mark
Raven
v20013 temp file directory doesn't save in your preferred location
Magik Mark is offline
Old 16th February 2019, 15:24   #265  |  Link
jkilez
Any Code Posted So far should also be added to merge.
Sure thing. A pull request has been created.
jkilez is offline
Old 17th February 2019, 06:00   #266  |  Link
Revan654
Revan654's Avatar
Originally Posted by Magik Mark View Post
Raven
Like I said it's Completely untested. Other then MKVToolNix function nothing was changed.
Revan654 is offline
Old 17th February 2019, 19:25   #267  |  Link
jkilez
Just created another pull request for the temp file glitch.
jkilez is offline
Old 18th February 2019, 14:43   #268  |  Link
jkilez
Revan- The new change that you made only fixes the issue for Windows 10. For other versions, it still does not check if TempDir is already defined. Please, just take a look at the code order in my pull request.
jkilez is offline
Old 18th February 2019, 15:39   #269  |  Link
jkilez
Revan- Thank you for merging in the Xvid fixes. It works much better now.
jkilez is offline
Old 18th February 2019, 19:49   #270  |  Link
Revan654
Revan654's Avatar
Everythingis still WIP. I was half asleep when I wrote it. Elseif Statement just needs to be added.
**Edit**
Re-Wrote it with different form of Try and removed the need to know the OS.
Revan654 is offline
Old 19th February 2019, 12:03   #271  |  Link
Natty
Noob
There definitely is a problem with the "ffmsindex.exe" included in the 2.0 package. The problem apparently does not occur when the indexing time is short, but when indexing takes more than 3-4 minutes, the indexer will actually index the file *twice*, causing StaxRip to hang while it does the second pass. The problem disappears if you replace the FFMS2 files in the 2.0 package with those from the 1.9 package.
you are right. it lags and even fails sometimes.
Natty is offline
Old 19th February 2019, 23:06   #272  |  Link
MrScientist
Hello, thank you for continuing to support this project. When I choose Intel H.264 or Intel H.265, I receive the following message...
"NullReferenceException (2.0.0.0)
Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
at StaxRip.QSVEnc.EncoderParams.OnValueChanged(CommandLineParam item)
at StaxRip.BasicVideoEncoder.ImportCommandLine(String commandLine, CommandLineParams params)"
I have Intel 8700K with UHD 630 graphics and current graphics drivers.
Thank you.
MrScientist is offline
Old 20th February 2019, 22:37   #273  |  Link
Revan654
Revan654's Avatar
Thank you.
Your using Old Build which has Been tweaked in the Pipeline builds and make sure QS is Enabled.
On Skylake if your using GPU like Nvidia. QS would not enable unless you tweak the setting in your Bios. Not sure if intel/ Motherboards have changed this Since Skylake release.
Revan654 is offline
Old 20th February 2019, 22:50   #274  |  Link
Revan654
Revan654's Avatar
ffindex does use LAVF demuxer, Without that or some other demuxer ffindex will struggle. It's why I try to compile a static version of ffindex with some resource already contained inside.
I guess i'm the only one with ffindex working correctly.
When using MP4 L-Smash Should be used, Other Formats DG or ffms should be used.
honestly, I would upgrade to DGDecNV and pay the tiny amount of money. Since it's well worth the price.
Only common format that it does not support are Apple formats(Not yet atlease Based on Dec Release) & VP9(Using Webm).
Link: http://rationalqm.us/dgdecnv/dgdecnv.html
Revan654 is offline
Old 21st February 2019, 10:24   #275  |  Link
RainyDog
Hi Revan, save as PNG from the preview window is broken in the latest pipeline build.
Save as JPG works fine though.
RainyDog is offline
Old 21st February 2019, 17:56   #276  |  Link
Revan654
Revan654's Avatar
Works perfectly fine at my end. Nothing has been altered with preview window.
Revan654 is offline
Old 22nd February 2019, 00:48   #277  |  Link
Natty
Noob
is it possible to get option to view bitrate used in preview window?
Natty is offline
Old 22nd February 2019, 04:02   #278  |  Link
videoh
Useful n00b
You're my hero, Revan654. You know that. You know it's true.
videoh is offline
Old 23rd February 2019, 22:11   #279  |  Link
Revan654
Revan654's Avatar
In it's current State, No. It doesn't use MediaInfo or anything like that for displaying those values. It uses Windows resources when building the data.
Not sure of all functions and sub functions of avifil32.dll. Plus can't really find any docs for it, When you try google it you get nothing but How to fix missing dll problems.
Revan654 is offline
Old 24th February 2019, 15:08   #280  |  Link
MrScientist
Thank you for the info. The Pipeline build works.
Just FYI, there were no BIOS settings on either my Kaby Lake or Coffee Lake motherboards to turn on QSV. It's on automatically.
