17th November 2009, 16:31 | #121 | Link | |
Software Developer
It seems DiAVCSetting.exe doesn't register the DiAVC.ax at all. At least it cannot be found by TimeCodec or by GraphStudio. I can register it manually by running regsvr32.exe from an Admin console, but then TimeCodec will freeze at startup. Same goes for GraphStudio, as soon as I insert your filter into the graph. Will have to unregister...
17th November 2009, 16:33 | #122 | Link |
CoreCodec Founder
We just found the same thing out.... it breaks TimeCodec.
Dan "BetaBoy" Marlin Ubiquitous Multimedia Technologies and Developer Tools http://corecodec.com |
17th November 2009, 16:39 | #123 | Link |
Software Developer
Not only TimeCodec. GraphStudio will hang too (with 100% CPU load), as soon as I try to insert DiAVC
Well, it's still "alpha" for a reason. So problems are expected, I guess. Let's wait for the upcoming "Beta" release then.
17th November 2009, 16:45 | #124 | Link |
契約者
Ok I want to elaborate a bit what I said sometimes earlier. For example with this 1080p sample, I'm getting following speeds:
DiAVC: 89.1697 DivX: 82.8047 CoreAVC: 79.9550 About win7... works fine on 32bit system, with manual registering and DiAVCSetting.exe, with timecodec and graphstudio. As for jumping playback, schweinsz, you really should test MPC-HC. It seems not every player affected. For example there is no such effect in KMPlayer. |
17th November 2009, 16:54 | #125 | Link |
Software Developer
I'm on 64-Bit, so maybe that's the reason...
17th November 2009, 17:22 | #128 | Link |
Do you mean that a 32-bit ax or dll can work on a 64-bit win7? On which conditions can the 32bit ax or dll run on a 64bit system? I never tested the DiAVC on 64-bit system. The initialization of the DiAVC use interrupt such as int 02dh or int 3 to prevent user to dubug it. Besides, are there some differences about the system function in kernel32.dll, ntdll.dll or advapi.dll between the 64-bit and the 32-bit windows? I must buy a new computer recently.
17th November 2009, 17:49 | #131 | Link | |
Software Developer
The 64-Bit system folder is "C:\Windows\System32" and the 32-Bit system folder is "C:\Windows\SysWow64". Weird, but that's the way it is. 32-Bit applications (and of course also 32-Bit DLL's) will load the 32-Bit system DLL's and work flawlessly under 64-Bit Windows...
18th November 2009, 00:50 | #132 | Link | |
will the beta version run faster on older hardware such as amd athlonXP? |
18th November 2009, 16:56 | #135 | Link |
The DiAVC require SSE2-enable cpu currently. I am trying to make the DiAVC to be the best H.264 decoder for netbooks or some others that have not a hardware decoder firstly. Perhaps I will code some MMX code to replace the current SSE2 code so that the DiAVC support some old cpu in future.
18th November 2009, 22:15 | #136 | Link | |
19th November 2009, 04:19 | #137 | Link | |
19th November 2009, 16:50 | #139 | Link | |
19th November 2009, 18:46 | #140 | Link |
Software Developer
Well, I think sharing proprietary DLL's from Microsoft Windows, DLL's that aren't explicitly marked as redistributables, would be a rule #6 violation.
Why you can't effort your own copy of 64-Bit Windows? Given that your are working on a commercial project and have "big" plans with it, this should be a relatively small investment
avc, diavc, fastest decoder, h.264, software |
