2nd July 2021, 17:06 | #61661 | Link |
Do I assume correctly that to avoid "glitches" it's not recommended to set 1 frame to be rendered in advance and not more? Is there anything else to do? I've pretty much solved the custom refresh thing (at least with madVR, in Kodi for some reasons it's avoiding the custom refresh rates in HDR, while accepting them in SDR) and I don't want no stinking glitches in my media viewing! :-D
3rd July 2021, 16:53 | #61666 | Link | |
Thanks in advance! |
3rd July 2021, 19:45 | #61668 | Link |
In Windows Task Manager, Details tab, add the GPU column and sort by its usage and watch it during playback (you can move the colum to the leftmost position and put TM in the lower right corner) to see if another process uses the GPU from time to time.
Maybe also use something like GPU-Z to check if there's not something wrong with clocks/GPU utilization.
4th July 2021, 00:18 | #61669 | Link |
f.lux I don't have installed on the HTPC. But I'll check for the similar function in Windows 10... also good suggestion on checking task manager. I'll try that as well.
Cinema Screen in conjunction with TruMotion Cinematic Movement is satisfactory in my limited experience (I've had the C1 for just a couple of weeks).
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM Last edited by ashlar42; 4th July 2021 at 00:36. |
4th July 2021, 01:01 | #61670 | Link |
4th July 2021, 10:41 | #61672 | Link |
Because I read several months ago that the betas mostly relate to HDR and I wanted to be safe rather than sorry. Now that I have an HDR display and have enabled pass-through HDR, I'm not certain the tone-mapping updates apply to me in any way, and it's possible the betas don't benefit me at all--but I nonetheless 'upgraded' from x.17. If you can enlighten me, I'd be happy to learn from you as I've read your posts for several years and I'm sure you're more informed than I am...
I just haven't paid attention closely enough to know for certain either way as I am only in the market for new equipment when I'm willing to spend the money--an event that only comes after so many years. |
4th July 2021, 13:09 | #61673 | Link |
The betas won't change anything for you if you use passthrough, they're only useful if you use tonemapping.
With recent LGs there is a way to avoid the TV doing any tonemapping and have only madVR do it, but you've got to really know what you're doing (there are threads at AVS Forum for that), if not passthrough is the safest option.
4th July 2021, 23:32 | #61675 | Link |
So, regarding motion... the settings I mentioned work fine for 95-99% of the times. There's "glimpses" of SOE that I catch for a second or so, because I'm currently constantly on the lookout for them. But nothing jarring, nothing that stands out unnaturally, to be honest. I think it's a satisfactory experience. And I was expecting worse.
Upscaling of TV broadcast material is ok. For movie/tv sources I always use madVR and I don't have the time to test by outputting native resolution and having the TV do the upscaling. Moreover, comparing without being able to do a side by side risks being pointless (unless TV upscaling quality is really crap, which I don't imagine to be).
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM |
5th July 2021, 16:51 | #61676 | Link |
I have a couple settings questions, that I'm not sure about. I'm using MadVR for tone mapping.
1. Based on this info, "The colour depth the Epson 5050UB now supports includes 4:4:4 in 8-bit, 4:2:2 in 8/10/12 bit, and 4:2:0 in 8/10/12 bit at 60Hz. In 24Hz it supports both 4:4:4 and 4:2:2 in 8/10/12 bit resolution", should I set the Nvidia Control Panel to 8 bit or 12 bit, and should I use Full or Limited? 2. I have 2 profiles set up. One for SDR, and the other for HDR. The guy who calibrated my Epson, did SDR in BT.709, and HDR in BT.2020. Where it asks how the display was calibrated, should I put BT.709 in the SDR profile, and BT.2020 in the HDR profile? If using BT.2020 for the HDR profile, should I put a checkmark in "report BT.2020 to display"? 3. Should I put a checkmark in "enable gamma processing"? Thanks! Sent from my SM-N975U using Tapatalk |
5th July 2021, 21:28 | #61677 | Link |
1. depends on your device 8 is often just the save choice.
2. if you have an nvdiia card and you are tone mapping yes send bt 2020 and this display is calibrated to BT 2020 should be correct. 3. no only matter if you want to change the gamma. |
5th July 2021, 21:47 | #61678 | Link | |
