24th December 2015, 03:21 | #20101 | Link |
nevcairiel,
The latest nightly builds are crashing when playing DVD's, happens with MPC-HC x86 / x64 and Zoom Player. Zoom Player shows a crash report pointing to avutil-lav-55.dll as the problem. The problem seems to affect LAVFilters-0.67.0-14 and later builds. This is on Windows 7 x64 Pro. Thanks. |
24th December 2015, 09:56 | #20102 | Link | |
Fault bucket 120380086268, type 4 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: P1: mpc-be64.exe P2: 1.4.6.1053 P3: 567b658a P4: avutil-lav-55.dll P5: 55.10.100.0 P6: 01185798 P7: c0000094 P8: 00000000000235cb |
24th December 2015, 13:26 | #20103 | Link |
Hi nevcairiel.
1 - thanks for you code for VP9 DXVA2, work great on GTX 960. 2 - can help deal with a small problem : when use LAVVideo and close playback do first calling CLAVVideo::BreakConnect() with dir == PINDIR_INPUT. When use MPC-BE's Video decoder, close playback - do first calling ::BreakConnect() with dir == PINDIR_OUTPUT. I can not understand the reason for different behavior. Can you help me ??
24th December 2015, 19:41 | #20104 | Link |
I also tried my Queen Greatest Hits DVD today and it also has issues but with the latest official version. With internal mpcbe mpeg2 decoder there's no issue. This DVD always seemed to cause ffdshow issues in the past but haruhiko had fixed all of those. Is it worth uploading the menu for this somewhere. Basically the menus freeze and windows blue spinning icon appears.
25th December 2015, 06:22 | #20105 | Link |
https://yadi.sk/i/eFmQ-MWBiHWR3
About 50 second video stream changes (changing the frame size from 720x576 -> 1920x1080). In DXVA mode only Microsoft DTV-DVD Video Decoder can normally handle this situation. But - if you seeking this place, the resolution is changed and continues to play normally.
25th December 2015, 11:33 | #20107 | Link |
The option makes no difference if you don't force RGB conversion by disabling everything else. And once you do convert, full range RGB is more standard. There is usually a reason for the defaults to be what they are
27th December 2015, 13:23 | #20108 | Link | ||
You can't "nest" ordered chapters, the interaction with the top level and the levels further downwards would be very bizzare. For example, in your "00 Menu nested chapters.mkv", you have a top level chapter that says (Episode 2) "Play 0:00.000 to 0:07.487 from Segment #2", which is a clear instruction. Then nested chapters try to override this - the first nested chapter says "Play 0:00.000 to 0:02.000 from Segment #1". Is this supposed to override the first 2 seconds of the top level chapter? Or make it longer? Its just not clear what its supposed to do, because there is no clear spec. A more logical way to approach this would be to not have the top level chapters actually be ordered chapters, and only the level below - but alas thats not how it was designed, or how any other ordered chapters MKV works. So in short, top level chapters inside an edition are used for ordered chapters, any further nested chapters are purely cosmetical for navigation purposes. Quote:
If you really want to shove multiple episodes into one mkv, best would probably to use one edition for each. That way you can even share OP/EDs properly. Or don't use nested chapters, and just name them differently, ie. name them like LAV would name them if they are nested "+ [Name]" etc, that way it looks like its nested, but its all top-level. Otherwise, nested ordered chapters are not something that works. The top level chapters under the edition need to be the ordered chapter entries, no others will be used for ordered chapter handling.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 27th December 2015 at 13:30. |
27th December 2015, 14:18 | #20109 | Link | ||
Matroska find' ich toll
I have seen other menu chapter.xml files which have nested ordered chapters. A possible way for ordered chapters is set the ChapterTimeEnd equal to the ChapterTimeStart or let it empty. If you found such top-level ordered chapter and it has nested chapters too, than you could use this start and end times for ordered chapter handling. Quote:
Normally my Matroska menu editor creates for each episode an edition and an edition with all episode. It works like it should. Only if in the episodes an existing segment-link to another file then it doesnt work with nested chapters well. (but I think I can write a workaround) I know LAV Splitter has other priorities and maybe you have in future a little bit time to enhance the Matroska splitting. I would help you if you like. |
27th December 2015, 14:22 | #20110 | Link | |
Does it work with Haali Splitter? If the answer is No, then the specification does not allow it. There is no written specification for ordered chapters, whatever works with Haali is the specification. And I'm not going to invent any arcane use-cases that are never going to be used by more than 2 people anyway.
27th December 2015, 16:52 | #20111 | Link | |
The other reason is Haali was not a fan of a menu so i think he don't implement such a feature. Yes, that can I understand. How many people would be needed so that such a function is incorporated? |
27th December 2015, 18:20 | #20112 | Link |
i have a problem with 0.67.
when i install 0.67 i cant bitstream "Reclock encoded AC3" over "Realtek HDMI Audio" anymore. with 0.65 all fine. same settings used for both versions. i absolutely have no idea what happens. reclock shows that it gets 6 channels and reclock output say that it is in "ac3 enc mode (wave out)" but my denon avr stays in "analog" mode which indicates that no digital signal is coming. then i run 0.65 installer and after that it works again immediately. Last edited by thomaz909; 27th December 2015 at 19:40. |
27th December 2015, 19:45 | #20113 | Link |
Thats a ReClock bug. You can fix it by checking the legacy 5.1 layout option in LAV settings.
28th December 2015, 12:58 | #20116 | Link | ||
Do let me know if the issue persists.
28th December 2015, 13:03 | #20117 | Link | |
Since software mode behaves the same way, it seems like a problem in the FFmpeg decoder. Having said that, resolution changes are a bit on the complicated side as it is. If there is a clean cut in the video stream it should work OK, but not always.
28th December 2015, 13:12 | #20118 | Link |
It's working on Nvidia, but fail on ATI. But - Microsoft video decoder fine on ATI too.
28th December 2015, 17:07 | #20119 | Link | |
If you have it would you mind trying it with the latest nightly? |
28th December 2015, 17:20 | #20120 | Link |
The spinning icon would indicate a problem with the player instead, it gets stuck in its main thread, which LAV should have no direct control over.
I don't think I have that DVD.
