22nd August 2017, 20:42 | #22121 | Link |
I noticed two issues with the current nightly:
-YADIF doesn't work for VC-1 interlaced (without software deinterlacing, LAV reports interlaced content properly to renderer). -When changing the YADIF setting when LAV config is opened via MPC HC filter list, it makes the player invisibly hang in background after closing. |
22nd August 2017, 21:51 | #22122 | Link |
For people who still like WinXP - last working version of subj is LAVFilters-0.70.2-16 and it's a pity (as all non-modified LAV Video Decoders) it can't hardware decode H265 10bit via CUVID on nVIDIA's GM206-based videocards - it seems nevcairiel too hard understand how it was made working (but it's just few strings of code).
Next installer LAVFilters-0.70.2-29.exe says "This program does not support the version of Windows your computer is running." Best regards. |
22nd August 2017, 21:57 | #22124 | Link | |
Container (TS?)? Sample?
22nd August 2017, 22:10 | #22125 | Link | |
I can't reproduce that. All settings changes are really quite equal, change the value, save it. It doesn't do anything special for those settings.
22nd August 2017, 23:05 | #22127 | Link |
Seems like an odd way to do things, but I've found a work-around for the issue.
24th August 2017, 22:04 | #22128 | Link |
Hey, great work on LAV filters. I did have a quick question though.
Using a youtube clip downloader (https://yd.3dyd.com/), I downloaded a 60fps 4K clip on youtube (https://www.youtube.com/watch?v=ArPP6_QXqyQ) and watched it with the latest LAV + madvr available using D3D11 hardware decoding. It worked perfectly, lav video reporting that the active decoder is D3D11 native and madvr OSD showing the DXVA11 flag. I also tried to download another 60fps 4K clip, but with HDR (https://www.youtube.com/watch?v=GTGm7mye-_4). The file isn't hardware decoded, LAV video showing that avcodec is active. Both files are straight from youtube so encoded with VP9. Is this an expected behaviour ? Thanks !
OS: Win10 1703 GPU: GTX 1070 (latest stable drivers) Monitor: LG OLED55B6V TV / Yamaha RX-A860 AVR Media setup: MPC-BE x64, madvr, lav filters (nightly) |
24th August 2017, 22:14 | #22131 | Link |
OK thanks, I knew there was a bitdepth difference, but couldn't find the exact decoding capabilities of the 1070.
26th August 2017, 14:21 | #22132 | Link |
Quick question: updating from nightly 45 to 49 and later, I loose DXVA11 native decoding, the active decoder now being D3D11 cb direct instead of D3D11 native. Is this normal ?
26th August 2017, 15:15 | #22134 | Link |
I did leave it on automatic. A settings reset solved it. Thanks
27th August 2017, 16:20 | #22136 | Link |
madshi hasn't implemented deinterlacing for D3D11 DXVA yet.
https://forum.doom9.org/showpost.php...ostcount=44714 |
27th August 2017, 17:52 | #22137 | Link |
In build 0.70.2.66-git I have made the observation that in video filters if you select DXVA2 (native), it will display the expected NV12, 8 bit, 4:2:0 (DXVA2).
However, if you then change it to None, it continues to display NV12, 8 bit, 4:2:0 (DXVA2) even though software decoding should be in use at this point. If you change it to DXVA2 (copy-back), it will display NV12, 8 bit, 4:2:0. Then changing it to None, it displays NV12, 8 bit, 4:2:0. Repeating the process where you go back to DXVA2 (native) and then None, None once again holds on to (DXVA2). |
27th August 2017, 17:55 | #22138 | Link |
It doesn't change without re-starting playback.
