Old 10th August 2017, 17:57   #5521  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by mastrboy View Post
So AMD is still way behind Intel in FPU performance pr core, or will there be future x265 optimizations for Ryzen/Threadripper that could close the gap?
it's intensive multicession encoding with x265: in this case Memory Banding limit speed for Ryzen/Threadripper. In simple 4K encoding 1950X produce better speed than 7900X (~20%).
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
Old 10th August 2017, 18:34   #5522  |  Link
Nah. It is just 2xFMAC256 magic vs 2xFMAC128 in Zen. ThreadRipper's Memory Bandwidth is pretty good.
Source -> https://youtu.be/G9JR_v-4BaQ?t=2m2s
Old 10th August 2017, 19:37   #5523  |  Link
Barough
Barough's Avatar
x265 v2.5+9-fdf39a97ecb8 (GCC 7.1.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
x265 [info]: HEVC encoder version x265 v2.5+9-fdf39a97ecb8
x265 [info]: build info [Windows][GCC 7.1.0][32/64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
Old 10th August 2017, 20:34   #5524  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Rysen use slow data fabric for internal L3 cache communication between each CCX module. You have really higher latence for intel with DDR4 and L3 too. Use multiple instance is not good idea for AMD.
If you make 4K encoding with X265, you don't saturate memory controler and in this case 1950X@stock will produce better result than 7900X@stock.
You have the same problem with R7 1800X and i7-6900K. In all test in 1080p, R7 1800X@stock and i7-6900K@stock are on par for x265 encoding but not in x265 fhd benchmark.
if possible, reduce the instance number (2x or perhaps 3x 1080p instance will be enough and you will see that relative speed will be really higher for AMD).
Old 10th August 2017, 20:38   #5525  |  Link
If you make 4K encoding with X265, you don't saturate memory controler and in this case 1950X will produce really better result than 7900X.
You have the same problem with R7 1800X and i7-6900K. In all test in 1080p, R7 1800X and i7-6900K are on par for x265 encoding but not in x265 fhd benchmark.
Similar results
http://pclab.pl/art75073-14.html
http://www.benchmark.pl/testy_i_rece...ona/28404.html
You are expecting too much from 2xFMAC128 vs 2xFMAC256.
ThreadRipper was designed to use as many processes as possible.
See benchmarks on youtube. Gaming + streaming to youtube + twitch + encoding something in Adobe Premiere.
REMEMBER! You have to use multiple x265 encoders to fully saturate all cores with very common 1080p resolution. So in practice there is no escape from that.
Old 10th August 2017, 21:12   #5526  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Similar results
not really. In pclab test 1950X produce 7% better result than 7900X and in your test it's 2% better result for 7900X.
Moreover, I don't like handbrake test because this gui use heavy filter (avisynth?) and don't use directly stream for encoding. I prefer direct benchmark with high speed ffmpeg frameserver (less than 5% of CPU charge for stream decoding).
Try your benchmark with less instance (just to assure to have CPU charge at 100%) and you will see that speed will be higher. Perhaps higher for Intel CPU too.
Old 10th August 2017, 21:34   #5527  |  Link
I have already done that on my E5-2690 in distributed encoding mode. 5 x265/x264 encoders vs 1 x265/x264. Difference in encoding time was in margin of error.
Old 10th August 2017, 23:06   #5528  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
1) Well I read before that your E5-2690 8C/16T is only at 70-75% for CPU charge in 1080p x265 encoding.
2) In this condition, why use 5x encoding instance, if 1x is enough?
Old 11th August 2017, 01:26   #5529  |  Link
adsun701
Hi here. I just created a patch that enables support for SMPTE ST 428,
SMPTE RP 431, and SMPTE EG 432 primaries. It also enables support for
SMPTE ST 2085, ICtCp, and both chroma-derived non-constant and
constant luminance matrices. They are all included in the latest spec.
Here's the link.
https://gist.github.com/Adsun701/472...0c90599ec4bb9a
adsun701 is offline   Reply With Quote
Old 11th August 2017, 13:35   #5530  |  Link
It looks like that 1950x in default creative mode (2 dies active) is sitting between 3.3 and 3.4GHz. While i9 7900x runs at constant 4 GHz.
Source -> https://youtu.be/Fr1ZlUu8v_Q?t=9m8s
Scalling in my benchmark is good.
Ryzen 7 1700 @ 3.7GHz (OC) = 25.5 fps
Threadripper 1950x @ 3.4GHz = 43.6 fps
Threadripper 1950x @ 3.7GHz = 47.4 fps (estimated)
Scalling factor = ~1.9x
Old 11th August 2017, 21:02   #5531  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
Here's the link.
you better post those patches to the x265 mail list, not here.
microchip8 is online now   Reply With Quote
Old 12th August 2017, 18:45   #5532  |  Link
x265_Project
Here's the link.
Thanks! We received your email (sent to x265contributions at multicorewareinc dot com), along with your signed Contributor License Agreement. We'll review your patch ASAP.
Tom
Old 14th August 2017, 15:05   #5533  |  Link
NikosD
x265 has nothing to do with the FPU or the FMACs or floating point performance in general.
It's a pure integer app using AVX2 integers not FMA3 or FADD or FMUL or any floating point in general.
If someone gets a Monsterripper or Killerofskyalakex 16C/32T 1950X try both modes.
UMA and NUMA using x265.
UMA should be faster, but who knows.
Also make sure you saturate all 32 threads.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 14th August 2017, 18:01   #5534  |  Link
Are you 100% sure that FMACs are not being used in integer calculations as well? Haswell is noticeable faster in x265 than Sandy/IvyBridge (clock vs clock).
Looking at architecture I don't see anything special except new FMACs
http://www.anandtech.com/show/6355/i...architecture/8
Chipzilla 16C/32T will destroy ThreadRipper 1950x in x265 by 1.6x factor.
Old 14th August 2017, 20:20   #5535  |  Link
NikosD
You seem to confuse vector SIMD integer instruction set with vector SIMD floating point instruction set.
Haswell and above have AVX2 instruction set which enables 256 bit vector SIMD integer instructions leveraged by x265
Sandy & Ivy have only AVX which is for floating point (mainly).
So, no speedup for those processors.
Of course AVX2 has FMA3 too, which doubles the floating point throughput compared to AVX but that's a different story irrelevant to x265.
If that becomes a reality - 60% faster than 1950X - prepare yourself to use liquid nitrogen to freeze that CPU coming directly from hell, especially if Intel is still using that mustard between the CPU and heat spreader.
And you will need around 500W for that performance.
Old 15th August 2017, 12:12   #5536  |  Link
What specific unit in CPU is responsible for calculating AVX2 instructions? My common sense tells me that FMAC does that. After all old SSE2 can also work on integers
https://en.wikipedia.org/wiki/SSE2
Zen has 2xFMAC128 while Intel since haswell has got 2xFMAC256. x265 benchmarks clearly show AMD 16C/32T = Intel 10C/20T. I see clear correlation here.
Old 15th August 2017, 18:27   #5537  |  Link
NikosD
OMG! You really are a stubborn b@st@rd !
The execution units leveraged by AVX2 instruction set are 256 bit SIMD integer for ADD, MUL, SHIFT.
Integer DIV remains 128 bit.
It's the last time I'm telling you that FMACs and floating point numbers have nothing to do with integers and x265 application.
Read here about all execution units of Haswell vs Sandybridge.
http://www.realworldtech.com/haswell-cpu/4/
Old 15th August 2017, 19:11   #5538  |  Link
Ok smart ass so explain us why zen architecture sucks so much in x265...
http://www.linleygroup.com/mpr/article.php?id=11666
Old 15th August 2017, 19:39   #5539  |  Link
NikosD
In case you didn't see it, I put a in my first sentence just to be polite with your tremendous ignorance regarding CPU architectures and ego (those two usually come together)
But now, after your reply, I can't be polite anymore.
Your comments made me laugh like no tomorrow regarding FMACs and x265, so keep on posting your thoughts after reading CPU architecture articles you don't understand.
It's so funny!
Thank you!
Old 16th August 2017, 01:58   #5540  |  Link
Asmodian
Maybe it is due to its much lower cache bandwidth or much higher cache/memory latency? There are major differences there. Teasing out the differences in the ALUs that might impact x265 is beyond me, so if anyone can help I would appreciate it.
Skylake-X:
Data-Cache Accesses: 2x 32B read + 2x 32B write
L2 Read Bandwidth: 64B
Zen:
Data-Cache Accesses: 2x 16B read + 1x 16B write
L2 Read Bandwidth: 32B
Does the massive L2 of Skylake-X help x265 at all?
madVR options explained
