Go Back   Doom9's Forum > Video Encoding > MPEG-4 ASP
Old 12th May 2004, 18:31   #61  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Some more screenshots from the Star Trek: First Contact comparison (Andreas 78er, Andreas einfache 99er, Andreas doppelte 99er, Bulletproof's Heavy Compression, Bulletproof's High Quality, Angel BestLow):
Please excuse if my English is crappy.
Archive of my Xvid builds
http://www.videoaudio.pl
Jawor is offline   Reply With Quote
Old 13th May 2004, 11:57   #62  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Even more screenshots from Star Trek: First Contact (Angel BestVeryLow, Low Bitrate Matrix, Very Low Bitrate Matrix, Ultra Low Bitrate Matrix, Selur's Matrix, Ultimate Matrix, EthanoliX FourRooms):
Old 22nd May 2004, 22:34   #63  |  Link
odysseus
Is there a suggested quantization for mostly high motion?
Not movies with occasional high motion but lots of motion all the time?
Like handheld cams with lots of global motion, but also besides the global motion, lots of motion in the scene itself.
Like for example following soccer players and not recording during breaks (so all the low motion parts are gone & the video is all high motion, with rare low-motion sequences).
Things like Matrix have lots and lots of low motion scenes, to get the best compression you need settings that compress both low and high motion well.
What I'm looking for is, I don't care if the settings do badly on low motion but I'd love them to do well on high motion.
odysseus is offline   Reply With Quote
Old 24th May 2004, 07:04   #64  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
All that I can tell you is that my matrix copes quite well with high motion. Look at the screenshots from The Matrix Reloaded.
Old 18th June 2004, 12:57   #65  |  Link
iago
retired
iago's Avatar
Additionally I can say that it copes with low motion quite well too. Finally I had the time to give Jawor's matrix a try (together with his latest XviD_15062004_p3 build).
I used a resolution of 640*352 with LanczosResize accompanied by undot only and headed for a 1CD encode of a low-medium motion, mainly dark source with XviD settings: AQ - Trellis - VHQ1 - cm - b-frames 2/1.50/1.00.
And I'm really impressed by one of the most visually pleasing results I've got so far. At least I can say that Jawor's matrix is actually fine-tuned for 'my' eyes . Ah, also for compressibility I guess, but without losing the good details and the natural look especially on faces.
Good work. Thanks.
iago
iago is offline   Reply With Quote
Old 19th June 2004, 07:26   #66  |  Link
CruNcher
CruNcher's Avatar
you should better watch a 2 time :P
It is about Time
Old 19th June 2004, 11:52   #67  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
That makes two of us
To be frank, I was surprised when I saw, that the matrix keeps so much detail. First I thought it would be sort of HVS - Worse Picture due to quite high coefficients I used.
@CruNcher: Maybe CruNcher's Visual System is different than iago's Visual System and Jawor's Visual System
@iago: Thanks for testing both the matrix and the VBV build.
Old 22nd June 2004, 19:12   #68  |  Link
Teegedeck
Moderator, Ex(viD)-Mascot
Teegedeck's Avatar
I don't really encode at those bitrates but still: Damned fine work; good man! That makes for my new recommendation for low-bitrate-matrices.
It's a man's life in Doom9's 52nd MPEG division.
"The cat sat on the mat."
ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl!
Teegedeck is offline   Reply With Quote
Old 23rd June 2004, 11:03   #69  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
I'm just trying to do my best
Old 26th June 2004, 16:19   #70  |  Link
Alxemi
Happy XviD user
Alxemi's Avatar
What about a Jawor´s 2CD quantization matrix?
Mira detras de ti... ¡Un mono con tres cabezas! (Guybrush Threepwod)
Alxemi is offline   Reply With Quote
Old 28th June 2004, 13:28   #71  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
I'm not designing any quantization matrix at the moment. Of course you can use this 1CD matrix for 2CD encodes
But seriously, I wouldn't recommend this.
Old 29th June 2004, 12:47   #72  |  Link
spyto
spyto's Avatar
2CD, you may use HVS Matrix
Jawor´s 1CD is a best at low/medium bitrate.
spyto is offline   Reply With Quote
Old 22nd March 2011, 16:50   #73  |  Link
srk3461
Soul hunter the link is dead.... !
can u provide a nw link for the The Evil Matrix - v0.1 ... ? thnx in advnce !!!
srk3461 is offline   Reply With Quote
Old 22nd March 2011, 19:16   #74  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Which link? >.>
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 23rd March 2011, 05:21   #75  |  Link
srk3461
hey thnx fo th reply.............
i need downld link fo evil matrix of urs its gud,,jus want try it out..... ! u posted th downld link fo th evil matrix in th first page of this discussn bt its dead...! can u post it agin ??
Old 23rd March 2011, 12:41   #76  |  Link
Didée
Found it in the guts of an old HDD. Evil.v0.1.qmatrix
Just FYI, this is evil v0.1:
- We´re at the beginning of the end of mankind´s childhood -
My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!)
Didée is offline   Reply With Quote
Old 24th March 2011, 15:44   #77  |  Link
srk3461
hey Didée thnx fo th link !
dnt wrry i'll keep it safe...... xD !
Old 18th April 2017, 15:10   #78  |  Link
orion44
None
orion44's Avatar
The link is dead. Can anyone upload the latest version of the evil matrix?
orion44 is offline   Reply With Quote
Old 25th July 2017, 20:23   #79  |  Link
hartford
hartford's Avatar
This is all that I have; Hope it helps.
evil v0.1
Intra:
8,12,12,12,20,60,255,255
14,10,12,12,14,34,255,255
12,12,20,22,30,255,255,255
12,12,20,46,255,255,255,255
16,12,28,255,255,255,255,255
56,32,255,255,255,255,255,255
255,255,255,255,255,255,255,255
Inter:
12,18,18,20,38,255,255,255
18,14,18,18,26,255,255,255
18,18,30,42,82,255,255,255
18,18,36,255,255,255,255,255
30,24,80,255,255,255,255,255
hartford is offline   Reply With Quote
Old 29th July 2017, 04:43   #80  |  Link
orion44
None
orion44's Avatar
evil v0.1
Intra:
Inter:
Thanks!
