Old 20th April 2018, 08:56   #50281  |  Link
Sunset1982
I just exchanged my GTX 1070 from my Htpc to my gamig rig. My RX480 is now back in my htpc.
Is there anything I need to know in regards to madvr? I know that it is not as powerful as the gtx1070 with NGU.
What about automatic switching with hdr files? does this work differently with amd cards?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 20th April 2018, 09:12   #50282  |  Link
austinminton
Originally Posted by Manni View Post
Quick update on nVidia drivers status:
Thanks Manni, that was a very useful post.
austinminton is offline   Reply With Quote
Old 20th April 2018, 11:14   #50283  |  Link
mclingo
Originally Posted by HillieSan View Post
yes I am, to a Samsung 49KS7000 and a JVC X5000 4K projector. I use HDR only for HDR movies.
Hi, do you have FSE and use DIRECT3D11 unticked in MADVR?
Is your TV in PC mode or Bluray/media center mode?
Old 20th April 2018, 13:38   #50284  |  Link
HillieSan
FSE unticked and Direct3D11 ticked.
You need the latest LAV filter (nightly build) for Direct3D11 to work.
TV is in default HDMI mode with Full-RGB HDMI signal. I think PC mode works fine as well.
HillieSan is offline   Reply With Quote
Old 20th April 2018, 14:05   #50285  |  Link
mclingo
Hi, what do you mean you need the latest nightly, DIRECT3D 11 has been working for ages on my system, its required for HDR to work.
What does it fix?
Old 20th April 2018, 14:41   #50286  |  Link
mclingo
Hi, there are a few used RX580 cards now on ebay for around £200 so prices have come down a little, they are all 4gig though, I currently have a 4 gig RX 460, can anyone hazzard a guess how much more MADVR grunt i'll get from this, roughly as a percentage, trying to work out if its worth selling the RX460 and getting one.
Old 20th April 2018, 16:31   #50287  |  Link
Warner306
You should be able to run NGU high plus some artifact removal at 1080p -> 2160p. But I haven't heard from any RX 580 owners to confirm. AMD Polaris still struggles with NGU image scaling.
Old 20th April 2018, 16:58   #50288  |  Link
mclingo
only having 4gb of ram going to be an issue?
Old 20th April 2018, 18:00   #50289  |  Link
ashlar42
and there is a big issue when you use nvidia for deinterlancing is is really really bad at it.
so think about YADIF in lavfilter for "better" quality.
At least for SD that's most definitely not my experience. I find yadif results really subpar.
Old 20th April 2018, 18:16   #50290  |  Link
Warner306
No, 4GB of VRAM is just the right amount.
Old 20th April 2018, 19:06   #50291  |  Link
if you like wrong positioned chroma...
Old 20th April 2018, 20:47   #50292  |  Link
Sunset1982
What about Vega?
Old 20th April 2018, 21:13   #50293  |  Link
someone reported normal result with a 56/64 vega card.
Old 20th April 2018, 21:55   #50294  |  Link
strumf666
Vega doesn't particularly struggle with NGU.
strumf666 is offline   Reply With Quote
Old 20th April 2018, 23:23   #50295  |  Link
tzr916
tzr916's Avatar
....Here are some profile rules if you want to use them. I wrote them in a way that accounts for non-standard resolutions.
Create these profiles under "scaling":
if (srcWidth > 1280) "1080p"
else if (srcWidth <= 1280) and (srcHeight > 720) "1080p"
else if (srcWidth > 960) and (srcWidth <= 1280) "720p"
else if (srcWidth <= 960) and ((srcHeight > 540) and (srcHeight <= 720)) "720p"
else if (srcWidth <= 960) and (srcHeight <= 540) "SD"
I understand why profiles are needed for each type of source material, but I am lost on setting them up. What to do with the code you provided? I see Scaling where I can create a profile group. I check all four of the boxes, then I end up with Profile Group 1. Then what? Do I add three Profiles in the group? Are there some screen shots of what it's supposed to look like when done?
GTX1660Ti 6GB, H270M, i5-7500 3.4GHz, 16GB PC4-19200,Win10 Pro 64, JriverMC, Silicondust Tv Tuners, Denon AVRX2200, Sony XBR-Z9D
tzr916 is offline   Reply With Quote
Old 20th April 2018, 23:51   #50296  |  Link
Warner306
Originally Posted by Sunset1982 View Post
What about Vega?
The Vega 11 iGPU can do NGU low luma doubling from 1080p -> 4K. I'm not sure if that's good or not. It's about as powerful as a GT 1030, so you'd have to know what the GT 1030 can do.
Old 21st April 2018, 00:03   #50297  |  Link
Asmodian
You can check out my settings.bin for some complicated examples using profiles; at the end of the third post in the link in my signature.
madVR options explained
Old 21st April 2018, 00:16   #50298  |  Link
Warner306
Create three profile groups. Name them "1080p" "720p" and "SD". Paste the code into the top of the profile group. You should get a green checkmark if done correctly.
Old 21st April 2018, 00:22   #50299  |  Link
tzr916
tzr916's Avatar
Yay! I got the green check mark. Running at 4k now. Initial testing looks very good. Thanks so much.
Old 21st April 2018, 15:19   #50300  |  Link
el Filou
el Filou's Avatar
Originally Posted by oldpainlesskodi View Post
I always thought that the best setup was Madvr Full Range, GPU RGB full range and Tv set at full range.
With correctly functioning hardware (TV and GPU drivers), it still is.
However, on my Samsung 4k suhd ks8000 set, this resulted in the wrong color mapping and clipping in blacks and whites, for non-hdr, which was further amplified for hdr material especially,
Are you using an NVIDIA?
With some older driver branch - don't remember which one - I had kind of the same issue you have, with clipping. I had to set the GPU (and TV of course) to Limited to get it fixed permanently but of course you then lose in picture quality.
Is YCbCr the only mode that fixes it on your TV, or does RGB Limited works too?
Do you by any chance have another device to test with?
If you have an NVIDIA, try changing the "Content type reported to the display" setting and see if it changes something. When I had that issue with NVIDIA drivers, changing that option to literally anything else than the one currently selected fixed the problem until the next display resync, at which point I had to change it again.
The problem was then fixed in the following driver branch.
