21st December 2017, 10:37 | #4922 | Link |
Is the automatic subtitle downloading and download manager coming to BE at some point? I'm talking about the functionality that MPC-HC has.
Now that Eventghost remote control works with BE, this is the single issue left that's keeping me from using this player.
i5-3570K, ASRock Z77 Extreme4, 8GB DDR3, GeForce GTX 670, Samsung SSD 840 Pro - Win8 Pro x64, madVR, LAV Filters, MPC-HC |
21st December 2017, 12:22 | #4923 | Link |
I'm not planned. Only If any of developers want implement it and enjoy MPC-BE's team.
21st December 2017, 13:54 | #4924 | Link |
You can try out this one, that's what couple of us using:
https://forum.doom9.org/showthread.php?t=175007 Personally I don't think it's a big issue to manually download/place/resync subs if you need it, but it's up to you.
22nd December 2017, 04:45 | #4926 | Link |
@Klaus1189
Perhaps this line is in Inno Setup. "c:\Program Files (x86)\Inno Setup 5\Languages\German.isl"
22nd December 2017, 13:21 | #4928 | Link |
27th December 2017, 14:04 | #4929 | Link |
A Few Queries
Hey fellas I was a MPC-HC user for past five years or so, but as its stopped development I switched to MPC-BE and I just one or two queries.
You see audio is an important thing to me, so in MPC-HC I simply used the Normalise option, so for the movies/shows it used to equalise the loudness, which was a great feature for me. But in MPC-BE I can't see any such option, could anyone help me find it? I do see an Auto volume control option but I don't think its the same. I do love the Mix channels to 7.1 option though, freaking awesome. Thanks in advance. |
4th January 2018, 02:03 | #4931 | Link |
Has anybody played protected DVDs on MPC-BE/HC? I often get garbled video or no video or macrovision failed errors with identical playbacks. I'm wondering what's up here. Win10_64 1709.
Also, does anybody notice that DXVA/CUDA/QVS playback loses sync when using 64x lav? It happens even with internal filters, but doesn't happen with software. When I playback at 2x speed for an hour, I notice that lip movements don't line up with the voice, but the information toolbar think's it's synced. I think it has something to do with the x64 dss2 avs filter showing 24000/1001 fps video as 10000000/417083 fps when using DXVA/CUDA/QVS. Who do I even talk to about this, considering that even internal filters in MPC-BE are affected? |
4th January 2018, 21:56 | #4932 | Link | |
I think the devs can help you then. |
5th January 2018, 07:57 | #4934 | Link | |
If DVD-Video is in the ISO file, then the DVD emulator type is of importance. If I remember correctly, then I had problems with DAEMON Tools Lite.
5th January 2018, 08:06 | #4935 | Link | |
5th January 2018, 21:29 | #4936 | Link | |
Just to be clear on the method: I am playing a css-encrypted, commercial DVD through an internal DVD drive with bus encryption. When I rip, mount the iso, and then play what's mounted, the playback is correct. I take it that nobody has this problem. I'm due for a fresh install of Windows anyways, so that'll probably fix it. You're right. I just checked internal DXVA h264 again and it seems that I was wrong the first time -- I will take this report to a more appropriate place. Sorry. |
6th January 2018, 11:20 | #4937 | Link |
Is there a problem with the YouTube viewer code that is preventing 1080p60 video from working? I'm just getting 720p30 now on most 1080p60 stuff.
Example YouTube video: https://www.youtube.com/watch?v=7OaLCKwPt28 I've tried both 1.5.2 (build 3148) Beta and also 1.5.2 (build 3261) Beta and both feed me 720p30 video. In the YouTube section of the options I've set "Use the built-in web page parser" and have set it to MP4 and 1080p with 60FPS checked. Interesting. Here's a video that does 1080p60 no problem: https://www.youtube.com/watch?v=TOi1FxlsPAg Last edited by Schrade; 6th January 2018 at 19:13. |
6th January 2018, 16:22 | #4938 | Link | |
but not work with WebM format |
6th January 2018, 17:03 | #4940 | Link |
Life's clearer in 4K UHD
Doesn't all YouTube content that started its life as either h.264 or h.265 get re-encoded to vp9 when played in YouTube's video player. And converted/re-encoded again to h.264 when played in MPC?
