31st July 2017, 17:52 | #5501 | Link | |
Compression artifacts will occur if you set the psy-rd strength and/or psy-rdoq strength too high. Psy-rd biases mode decision towards candidates that have a similar level of detail (variance) to the source block. A little psy-rd is good, but too much psy-rd strength will cause x265 to choose candidates that aren't the best match visually (blocks that have higher or matching energy levels, even though they are not the best candidate with the lowest Rate-Distortion cost). When psy-rd is too high, you'll typically see motion inaccuracy (for example, blocks that should be portraying smooth motion that instead appear to be staying in one place too long). When psy-rdoq is too high you'll just get compression artifacts. |
1st August 2017, 09:57 | #5502 | Link |
Lost my old account :(
Is there any plans of full HLG support? The arib-std-b67 transfer curve is implemented, but the DVB states that this should be flagged in the "alternative_transfer_characteristics" SEI message and bt2020-10 should be flagged in the normal VUI, this way it suppose to be more backwards compatible for non HLG equipment.
http://www.etsi.org/deliver/etsi_ts/...54v020301p.pdf Last edited by excellentswordfight; 1st August 2017 at 09:59. |
1st August 2017, 17:25 | #5503 | Link |
Broadcast Encoder
I gotta send a sample to a TV which requires constant bitrate (20 Mbit/s) HEVC 10bit 50fps .ts 'cause they are moving from .mxf XDCAM 1080i MPEG-2 25 Mbit/s interlaced contents to 4K HEVC 50fps progressive.
I used: Code:
@avs4x265.exe --preset medium --level 5.1 --tune fastdecode --profile main10 --bitrate 19500 --vbv-maxrate 19500 --vbv-bufsize 19500 --strict-cbr --ref 3 --deblock -1:-1 --overscan show --colormatrix bt709 --range limited --transfer bt709 --colorprim bt709 --videoformat component --no-open-gop --fps 50 -o "raw_video.hevc" "AVS Script.avs" Code:
@avs4x265.exe --preset ultrafast --level 5.1 --tune fastdecode --profile main10 --bitrate 19500 --vbv-maxrate 19500 --vbv-bufsize 19500 --strict-cbr --ref 3 --deblock -1:-1 --overscan show --colormatrix bt709 --range limited --transfer bt709 --colorprim bt709 --videoformat component --no-open-gop --fps 50 -o "raw_video.hevc" "AVS Script.avs" Code:
ColorBars(width = 3840, height = 2160, pixel_type = "yv12") ConvertFPS(50) ResampleAudio(48000) Normalize(0.89, show=false) trim(0, 1500) barsnote=last BlankClip(width=3840, height=2160, pixel_type="YV12", fps=50000, fps_denominator=1000, audio_rate=48000, channels=2, sample_type="float", color=$000000, length=1500) TextSub("Clock.ass") clock=last FFmpegSource2("sampleProRes.mov", fpsnum=50000, fpsden=1000, atrack=-1) ResampleAudio(48000) Normalize(0.89, show=false) sample=last barsnote++clock++sample (as to the 8bit processing done by Avisynth, that's because it's just a sample/test; I'm gonna use the 10bit "hack" in FFMpegSource2 to output 10bit, do some post-processing - light denoise and debanding - and then feed x265 directly with the 10bit stream thanks to Dither Tool in the real encode) I cannot upload publicly the encoded sample, due to copyright rights, but I might send a very little part of it via PM if it's absolutely necessary to solve this "issue", but I'm pretty sure I'm just missing some settings in my encode line. Last edited by FranceBB; 1st August 2017 at 17:52. |
1st August 2017, 17:50 | #5505 | Link |
Broadcast Encoder
Well, after I encoded the .hevc file with x265 and the AC3 audio file with ffmpeg, I muxed them in .ts using ffmpeg and I got my .ts file, but Media Info says:
General ID : 1 (0x1) Complete name : G:\Sample.ts Format : MPEG-TS File size : 370 MiB Duration : 2 min 58 s Overall bit rate mode : Variable (instead of Constant) Overall bit rate : 17.2 Mb/s (instead of 20 Mb/s) Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : 36 Duration : 3 min 0 s Bit rate : 16.0 Mb/s (instead of 19.5 Mb/s) Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 50.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.038 Stream size : 343 MiB (93%) Writing library : x265 2.5+6-d11482e5fedb:[Windows][GCC 7.1.0][64 bit] 10bit Encoding settings : cpuid=1050111 / frame-threads=1 / numa-pools=2 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=9000 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=25 / keyint=250 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=5 / lookahead-slices=8 / scenecut=0 / no-intra-refresh / ctu=32 / min-cu-size=16 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / no-signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=0 / subme=0 / merange=57 / temporal-mvp / no-weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=2 / early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=cbr / bitrate=19500 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=19500 / vbv-bufsize=19500 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.00 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=1 / overscan-crop=0 / videoformat=0 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 21 (0x15) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : 129 Duration : 3 min 0 s Bit rate mode : Constant Bit rate : 384 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 8.24 MiB (2%) Language : English Service kind : Complete Main Menu ID : 4096 (0x1000) Menu ID : 1 (0x1) Duration : 2 min 58 s List : 256 (0x100) (HEVC) / 21 (0x15) (AC-3, English) Language : / English Service name : Service01 Service provider : FFmpeg Service type : digital television |
1st August 2017, 21:06 | #5506 | Link |
But:
rc=cbr / bitrate=19500 ... vbv-maxrate=19500 / vbv-bufsize=19500 |
2nd August 2017, 11:31 | #5507 | Link | |
1. My broadcast/streaming service provider says no more than 20Mbps 2. I should encode with a maximum bitrate of 20Mbps(or to be safe, 19Mbps) 3. in order to maximize the quality under this constrain, make the bitrate constant as 19Mbps 4. Why the fxxk I cannot find a CBR mode? are you serious in telling me to use x264 instead of my favourite one-key encoder? |
2nd August 2017, 14:43 | #5508 | Link |
a) just a casual question to the x265 developers, no accusation intended: When there are no commits for several days ... are you usually hitting a complex issue all together, which takes some time to get investigated, or is it more likely that you have appointments outside the development office (e.g. fairs or customer meetings, maybe it's just vacation season, and hopefully no natural disasters)?
_ b) a question not only to the x265 developers, but mainly: what is the intended difference between "make clean" and "make clean-generated", or more specifically, in which situations should one use either of them? |
2nd August 2017, 15:14 | #5509 | Link | |
For my case I used ffmeg/x265 with these settings and they ended up close to "true" CBR. I saw no cases with a significant drop in bitrate. Code:
-c:v libx265 -pix_fmt yuv420p10le -preset slow -x265-params level=51:bitrate=24000:vbv-maxrate=24000:vbv-bufsize=24000:keyint=48:no-scenecut=1:b-adapt=0:bframes=8:rc-lookahead=48:strict-cbr=1:colorprim="bt709":transfer="bt709":colormatrix="bt709":range="limited" Last edited by excellentswordfight; 2nd August 2017 at 15:25. |
2nd August 2017, 15:47 | #5510 | Link |
Broadcast Encoder
@excellentswordfight... yes, I used a closed GOP 'cause open GOP it's not supported by their specs and I kept --ref 3 just to be sure that the reference frames won't be a problem. As to the bars-note, I had to insert 30sec bars-note to show them channels mapping, audio level (about -24 LUFS more or less, 'cause according to the law commercial breaks can't be louder than the program itself, that has to be normalised) and that both luma and chroma of the program are in range (bars 75%, luma 0.7) followed by the clock with the name of program, video specs, TC-In, TC-Out and the countdown, lasting for 30 sec in order to have the program starting at 00:01:00.00.
So... yes, probably it's just because of bars-note and the clock/countdown that the encoder lowered the bitrate, which shouldn't be a big deal if it's just for that. Anyway, I sent them a sample; I hope they'll accept it. |
2nd August 2017, 19:28 | #5511 | Link | |
However, if there isn't much motion in the content, there are only so many ways to spend the bits. Adding a bit of random noise and using --tune grain is a good way to boost bitrate |
3rd August 2017, 01:08 | #5512 | Link |
Broadcast Encoder
@benwaggoner I used that parameter (--strict-cbr) already. Anyway, excellentswordfight was right: it was just a few kbit/s at the very beginning due to the bar-note, but the program itself was constant at 19.5 Mbit/s, in fact they just called me to tell me that they accepted the sample.
Gentlemen, it's been a pleasure. XD No, seriously, thank you, everyone. |
3rd August 2017, 03:14 | #5513 | Link | |
At least in those systems, distclean should be used whenever a change to the build system occurs, while clean is sufficient if only the actual project code changed. |
5th August 2017, 09:03 | #5514 | Link | |
Also, it's entirely possible that MulticoreWare's "sideline projects" (I'm sure calling them that will make 'em angry) might require some collaborative poaching of x265 developers. Their recently developed LipSync technology is a perfect example of this, requiring an amalgam of both video analysis and artificial intelligence. |
5th August 2017, 19:52 | #5515 | Link |
@ WhatZit: I wasn't aware of additional projects with similar complexity. Of course, that's a quite probable reason.
@ qyot27: My impression was the opposite, "make clean-generated" only removing CMake generated and similar auxiliary files to force rebuilding from the end of the building sequence for maybe only sub-targets with updates. But it's not easy for me to understand make files without a real clue about their structure, syntax, dependencies ... Last edited by LigH; 5th August 2017 at 19:55. |
6th August 2017, 04:40 | #5516 | Link | |
6th August 2017, 04:41 | #5517 | Link | |
Tom |
10th August 2017, 15:03 | #5519 | Link |
AMD Threadripper 1950X in x265
https://cubeupload.com/im/bKv6yQ.png Source -> https://youtu.be/TJiP1bKxLkU?t=3m43s
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th August 2017 at 15:06. |
10th August 2017, 17:28 | #5520 | Link | |
(i have a tendency to drunk post) |
