Old 1st February 2022, 23:36   #21  |  Link
poisondeathray
Originally Posted by Mitra View Post
@poisondeathray, Thanks, I had forgotten MT, I enabled Prefetch(4) now it's faster but still not enough for real time.
I use an i7 10700k + Nvidia 1660Ti and think it is fast enough.
You should be able to get faster than realtime on that CPU . 8C/16T . Try Prefetch(16)
Don't go faster than preset="super fast" for QTGMC, otherwise yadif or bob is used for the repair mode . In that case you might as use yadif(1,1), or bwdif(field=3) .
Old 1st February 2022, 23:55   #22  |  Link
Mitra
@poisondeathray, Thanks, Prefetch(16) increased the speed by about 20%.
I will try yadif(1,1) and bwdif(field=3)
Mitra is offline   Reply With Quote
Old 2nd February 2022, 00:17   #23  |  Link
StainlessS
StainlessS's Avatar
If you are not gonna supply sample, what is rez [EDIT: and colordepth] of your source ?
Maybe other could give better args to QTGMC for HD source. [blocksize, subpel, and others, I usually just use a preset, if I use QTGMC at all]
EDIT:
your CPU has 8 cores, 16 threads with hyperthreading,
suggest at least try Prefetch(8), and maybe 12. [it varies but physical cores often recommended]
I sometimes post sober.
Old 2nd February 2022, 06:51   #24  |  Link
Mitra
EDIT:
Sorry, 1080i50 , YUV422 8bits
avisynth, blending, video
