11th March 2010, 11:22 | #121 | Link |
If it's the only way to do it, then it's ok.
It would be nice if there an option to chose directory name between "<filename>_attachments" and just "attachments"
Sorry for my bad English. Last edited by Anton1986; 11th March 2010 at 11:36. |
11th March 2010, 23:30 | #122 | Link |
Attachments from each file have to be stored separately or have different names. So "<filename>_attachments" is fine, but just "attachments" is not. I will make it so users can choose to save attachments in a separate directory - "<filename>_attachments" or the way it's done now - "<filename>_AttachmentName.ext" in the same directory.
15th March 2010, 08:27 | #124 | Link |
v 0.4.1.2 Released
Changes:
* About Dialog completely redesigned. All links now open with default browser. * Logging is now enabled and more verbose. * Log file size can be controlled. Default size is 10 MB (See Help file on how to use) * All attachments are now extracted to "destination folder\[filename]\attachmentname.ext" Last edited by sheck; 16th March 2010 at 04:20. |
15th March 2010, 09:06 | #125 | Link |
For those who are using Linux Distros, I was able to run MKVcleaver in Wine. You must place the file somewhere in your home directory, otherwise mediainfo error comes up. Don't ask me why, I don't know.
16th March 2010, 04:11 | #127 | Link |
v 0.4.1.3 Released
Fixes:
* Fixed path generation code * Fixed path detection when D&D used Changes: * MKVcleaver can now detect errors from mkvextract.exe * User is notified if errors and/or warnings occurred while extracting * Added status bar message if extraction finished successfully |
14th April 2010, 15:32 | #130 | Link |
There's a bug in 0.4.1.3:
If you drag and drop multiple files into the application, all the files are assumed to have the same path. Lets say you are running Windows 7 and type *.mkv into the explorer search box to find all movies in all subfolders of the selected folder. You then select them all and drag them to the application. This will result in a "The following files were omitted, because they were not recognized as Matroska" dialog box since all the files were assumed to have the same path as the one you were dragging. Thanks for an excellent tool |
15th April 2010, 16:20 | #132 | Link | |
15th April 2010, 16:21 | #133 | Link | |
Also videohelp.com has the files on their servers. |
24th April 2010, 19:53 | #136 | Link |
v 0.4.1.4 Released
Fixes:
* Redesigned Drag & Drop code * MKVcleaver now allows to Drag & Drop mix of files and directories * MKVcleaver now allows to D&D multiple directories * Fixed bug where MKVcleaver assumed that all files are located in the same directory when D&D used Changes: * MKVcleaver will now display channel information for audio tracks in the left pane |
27th April 2010, 04:23 | #137 | Link | ||
Unavailable
Thanks for the tool, and especially
for always listening to the end-users's comments and suggestions. *THUMBS UP* That's the stuff! Quote:
I mean, it depends on what one is trying to look for, and when one does it. Actually, Google has become more of an advertising machine than a search engine... It seems you didn't have the opportunity to know the original version of Altavista. +++++++++++++++++++ UPDATE: 10 days later... now = 2010/05/07, 13:38 GMT, and... Quote:
27th April 2010, 20:09 | #138 | Link |
just wanted to say thanks for this tool, much better than mkvextract which has not been updated in years. (Though can be a little hard to find hidden in this forum, would love to see a open source version of this at sourceforge or google code )
28th April 2010, 03:12 | #139 | Link | ||
I will research into SourceForge and GoogleCode. By the way, MKVcleaver is already open source. Read the help file on how to get the source code. |
batch extract, extractor, matroska, mkv, mkv batch, mkv decoder, mkvextract |
