Old 16th July 2009, 17:43   #2001  |  Link
Trahald
Wewkiee
Trahald's Avatar
Originally Posted by ACoolie View Post
If we're free to post ideas here, I tried working on it but don't really have the experience to get it done. An option --encoder-fps would tune your options every so many frames to try to match fps to --encoder-fps value. Bframes would be lowered or raised, refs decreased or increased, etc. It would be very useful if performing faster than a certain speed is crucial. The only issues I'd foresee is that certain options (like bframes) probably can't be changed very easily in the middle of encoding.
bframes (the amount used in a GOP not the parameter per se) can change naturally based on the material. Changing that as a parameter mid-stream (from 3 to 0 for example) is trivial. other parameters require changing the sps/pps which is more significant but doable. Some encoders do this but usually based on changes in a section of the source, not to meet a speed requirement.
It would be interesting for the sake of better quality @ same bitrate. Doing it for encoding fps sake doesnt seem a good enough reason IMHO.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 16th July 2009, 18:53   #2002  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
This patch already exists, and it's called speedcontrol. If you need it, contact Michael Kazmier at firstinitial lastname [AT] availmedia [DOT] com.
Old 17th July 2009, 10:09   #2003  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1183 32bit
download ; release notes
  • built on Jul 17 2009, gcc: 4.3.3
  • fprofiled, -march=i686
x264 r1183 64bit
  • built on Jul 17 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
  • fprofiled, -march=core2
patched with:
[I'm human, no debug]
Old 18th July 2009, 03:12   #2004  |  Link
imk
|ン、)
imk's Avatar
Windows:
x264-r1183M-imk-win.7z
win_build_info.txt
OS X (x86 + x86-64 Universal Binary):
x264-r1183M-imk-osx.7z
I'm not going to include the AutoVAQ patch just yet. I might include the threaded slicetype patch if enough people use it or want it.
imk is offline   Reply With Quote
Old 20th July 2009, 23:27   #2005  |  Link
techouse
Strictly Rhythm
techouse's Avatar
x264_x64_r1184_unpatched | MD5
GCC 4.4.0 20090524 (x64.core2.Komisar), unpatched, generic, fprofiled
________________________________________________________________________________
x264_x86_r1184_techouse | INFO
GCC 4.4.0 20090524 (x86.core2.Komisar), fprofiled, -march=core2
x264_x64_r1184_techouse | INFO
GCC 4.4.0 20090524 (x64.core2.Komisar), fprofiled, -march=core2
Patches used:
x264_hrd_pulldown.13_interlace.diff
x264_win_zone_parse_fix_05.diff
techouse is offline   Reply With Quote
Old 21st July 2009, 08:40   #2006  |  Link
imk
|ン、)
imk's Avatar
x264-r1184M-imk-win.7z
win_build_info.txt
Old 21st July 2009, 13:30   #2007  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1184 32bit
  • built on Jul 21 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
x264 r1184 64bit
  • built on Jul 21 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
patched with:
  • x264_win_zone_parse_fix_05.diff
  • x264_hrd_pulldown.14_interlace.diff
One less patch to apply, the AutoVAQ is in.
EDIT:
Now used the 64bit VM Komisar build system to build both, the problems with the 32bit build should be over. I personally haven't edited my build environment in quite some time so I have no idea what caused the problems from r1179 onwards.
Last edited by JEEB; 21st July 2009 at 18:06. Reason: Updated the build, short commands work now
Old 21st July 2009, 14:34   #2008  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Jeeb: did you change something in the code except patches ? coz I tested this command : x264.exe -h w/ your build and it crashes... it works fine with --help or --longhelp though (OS: win 7 32bits). Note that I've no crashes w/ my own build (gcc 4.4.0) using the same command.
Does anyone confirm or not ?
Old 21st July 2009, 14:39   #2009  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
Confirmed here on XP 32-bits.
x264 -h doesn't show anything, it just quits without any error/warning.
Edit : Imk's build is ok for me.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 21st July 2009, 14:49   #2010  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
In fact it seems all the "short" switches will cause x264 to exit immediately ("-h", "-w", "-B", etc). The x64 build is not effected though...
Old 21st July 2009, 15:09   #2011  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Very weird. My building script consists of rm -rf'ing all of the current build folders -> updating the git repo (using one folder that never gets used for building) -> copying to the needed folders -> configuration and building. No additional patches were applied and the 32bit version gets even a standard ./configure because x264 by default optimizes for i686 IIRC.
I remember using the short commands myself earlier, so I will definitely have to take a look at it as I get home. And patching logs seemed to be all right.
Also, the 64bit build being not affected makes me think even more...
Too bad I don't have the msys environment on my hands via remote desktop :/
Possible culprits:
- my toolchain (hasn't been updated in a while though, so if it actually worked on the older builds...)
- that modified HRD patch (that has been there for some time as well; hurf, I was worried something might happen, because it was my first case, but let's see as the change was quite small...)
- getting updated code from the git repo went not-so-well?
- something else?
Will test some older binaries via wine on my laptop now.
EDIT:
r1184-83-81-79 32bit:
err:seh:setup_exception_record stack overflow 820 bytes in thread 0009 eip b7d269be esp 00520ffc stack 0x520000-0x521000-0x720000
r1173 32bit:
Works
Hurf, I think you can guess the reason and I will go cry myself to sleep with my patch that I made by applying it manually to the codebase and then doing diff magic. Will switch to the 1178 version by komisar and go hang myself ^^;
Although why the hell does it work on 64bit D:
EDIT2:
wtf, it even happens without any patches, I guess my build environment got changed somehow o_O I haven't touched it for months. Anyways, fun stuff.
EDIT3: Re-built the build with Trahald's v14 hrd pulldown patch on Komisar's msys/mingw - problems fixed, which is the main part - now to know why on Earth it failed on my 32bit building environment...
Old 21st July 2009, 15:40   #2012  |  Link
Trahald
Wewkiee
Trahald's Avatar
No really big changes. Just code clean up. The 3 length values in the code were at maxes, which works but wastes bits, were lowered to reflect options given. I ran a few encodes at it and the calcs make sense to me, but be ready to revert if there is an issue.
Old 23rd July 2009, 16:01   #2013  |  Link
Tarutaru
A deadly Taru!
Tarutaru's Avatar
x264 0.68.1185M 2956905 built on Jul 23 2009, gcc: 4.4.0
* patch -p1 < /local/build/x264/patch/x264_hrd_pulldown.14_interlace.diff
* patch -p1 < /local/build/x264/patch/x264_win_zone_parse_fix_05.diff
* fprofiled, -msse4.2, -march=native(core i7)
* built with pthread, gpac
Tarutaru is offline   Reply With Quote
Old 24th July 2009, 17:10   #2014  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
since this thread is also used for discussion and usage of patched builds, tossing the following out...
in addition to the release of gcc 4.4.1 as of a couple days ago, the mingw team has also revealed an official 4.4.0 release (which unlike 4.3.0 isn't stated as alpha/testing).
so those still using 3.4.5 should definitely upgrade...
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 24th July 2009, 17:21   #2015  |  Link
LoRd_MuldeR
Software Developer
Is there a MinGW 4.4.1 binary yet? It seems TDM's builds have not been updated until now...
Old 24th July 2009, 17:32   #2016  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
you always have the option to compile your own from source (like what i do)
Old 24th July 2009, 17:35   #2017  |  Link
LoRd_MuldeR
Software Developer
Too much trouble
And I prefer using some "semi official" MinGW/GCC build, because it's more tested by the community.
Old 24th July 2009, 17:48   #2018  |  Link
Selur
Selur's Avatar
I agree, tdm's builds are nice&handy
(btw. is there something similiar when aiming for 64bit builds?)
Old 24th July 2009, 17:55   #2019  |  Link
LoRd_MuldeR
Software Developer
People seem to use Komisar's MinGW x64 builds:
http://komisar.gin.by/mingw/index.html
Old 24th July 2009, 18:09   #2020  |  Link
komisar
komisar's Avatar
My last stable build of gcc -- 4.3.4 20090620.
After 20090620 my trying to build correct gcc and x264 fail.
gcc 4.5.0 (svn) totally unstable (imho).
4.4.1 i can try to build after weekend.
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
