2nd October 2018, 17:40 | #41 | Link |
lovely, i'll have a look then.
2nd October 2018, 19:01 | #42 | Link |
I don't think MadVR is able to prevent the TV from tonemapping - or at least it defintely doesn't in my C7. So if you tonemap with MadVR and output as HDR, the TV is still going to tonemap, which is of course unfortunate.
2nd October 2018, 19:03 | #43 | Link |
ah right, might explain why it doesnt look any different at all to my eyes, I thought someone had said that wasnt true, no point using then I guess, cheers anyway.
2nd October 2018, 19:15 | #44 | Link |
Yea I was trying to figure out if my C8 was disabling tone mapping or not if madvr was doing it and it doesn't appear to be the case. The TV is still tone mapping from what I can see. (Murder on the Orient Express was a much better test case for trying to figure that out in my case). What I don't understand is how the dynamic tone mapping on the Panasonic UB820 gets around this issue (if it actually does but in my testing it sure seems to). I tried with the LG's dynamic tone mapping on and off and it didn't seem to make any difference. I would have thought, and madshi agreed with the theory, that turning on dynamic tone mapping in the LG would mostly disable the tone mapping if it is already sent a properly tone mapped image for the max nit level for the display. That didn't appear to be the case, unfortunately.
2nd October 2018, 19:37 | #45 | Link |
oh cool, thanks
3rd October 2018, 14:33 | #46 | Link | |
My latest and working setup: Windows 10 1809 Kodi DS Player 17.6 AMD RX480, 8GB with driver 18.9.3 madvr 0.92.17 lav filters 0.72.0-15 xysubfilter 3.1.0.751 LG 65" C8 OLED (Frimware 04.10.05) / Black Level: high AMD settings: RGB Full, 10 bit madvr: 0-255
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set Last edited by Sunset1982; 3rd October 2018 at 14:40. |
3rd October 2018, 14:42 | #47 | Link |
no issues here in PC mode, switches 23/24 fine, something is wrong there, thats kind of the point of PC mode
3rd October 2018, 14:50 | #48 | Link |
you defo got deep colour enabled on all HDMI port?
3rd October 2018, 14:54 | #49 | Link |
it will switch fine, but you wont get the full 4:4:4 support...
3rd October 2018, 15:22 | #50 | Link |
you mean you cant set your PC desktop to 4:4:4 FULL RGB @23hz, are other resolutions greyed out, or does it just do nothing?. Doesnt MADVR output 4:4:4 full RGB 23hz when playing a movie?
i'll have a look at this later when I get home, i'm currently upgrading to 1803, and then to 1809 which i'm sure is going to be a mistake
3rd October 2018, 16:41 | #51 | Link | |
Edit: I use Nvidia with it's funky 12 bit depth limitation for hdmi, so I have display resolution 4K RGB 4:4:4 12 bits as my setting, not as a TV resolution option that it might be setting for 1080p. I never investigated further since what I needed worked. Last edited by blu3wh0; 3rd October 2018 at 16:45. |
3rd October 2018, 19:06 | #52 | Link | |
I question whether the madVR pixel shader is working at all. One person said 100 nits was working fine. In absolute PQ nits, this would make the image almost entirely black. The image should get darker and darker as the target nits is lowered. It isn't possible for the display to make the input brighter because PQ values are absolute in terms of luminance. So 100 nits peak should be shown at 100 nits; 500 nits at 500 nits, etc. Tone mapping might make the image darker (reduce the luminance of some input values to match the brightness capabilities of the display), but the majority of displays will not make the image brighter. I would expect the color would change in some way when you use pixel shader, but changes in brightness should be more apparent with lower target nits. If this isn't happening, I would think pixel shader is not working correctly.
3rd October 2018, 19:20 | #53 | Link |
just installing 1809 now, wish me luck !
.....although as i'm typing this i'm thinking... why are you doing this Mclingo...
3rd October 2018, 23:51 | #54 | Link | |
That situation is what led me to the conclusion that the TV's tone mapping is not disabled. If I go down to 100 nits it's the same brightness as 1000. Maybe my conclusion is wrong and that the pixel shading isn't working when HDR mode is enabled. No matter what I change in madvr with pixel shader enabled in HDR mode, the picture does not seem to change so your assertion could be more correct than mine.
4th October 2018, 00:34 | #56 | Link |
yeah, its went fairly well all things considered, It did cause the colour saturation issue on mine again which I now cant fix, I can only workaround it. Its really really odd that its only MADVR/SDR/23HZ material, everything else is ok. whats equally or even more odd is that when I calibrate in MADVR for BT2020 to fix this, it doesnt have any knock on effect on the other videos which were playing HDR / SDR @60hz, you;d think these would be changed in some way by MADVRs calibration for BT2020. odd.
This is why I think its a MADVR bug but MADSHI does not so it will probably never get fixed unless more people report the same issue, that doesnt look like its going to happen, either it is my system or there just arent that many people with similar enough setups. The over saturation can be quite subtle in some movies though, could be some people just arent noticing it. I could very happily live with the workaround permanently though, it has no other negative impact luckily.
4th October 2018, 07:34 | #60 | Link |
the option under "tone map using pixel shaders" is most likely a renamed from send HDR meta data to this because it make more sense.
the difference is that madVR will alter the image before sending it to the display but with that option it is still "HDR" type not SDR like with passthrough. |
