Old 2nd May 2020, 20:11   #7581  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by Patman View Post
I use the git source (not hg source) and there the build number is a bit different.
Could you please tell us what is your "trick"?
https://bitbucket.org/multicoreware/x265_git/commits/ does not list de09ab80e
Old 2nd May 2020, 20:19   #7582  |  Link
Patman
Patman's Avatar
The mirror on github based on hg source (https://github.com/videolan/x265)
The Synchronisation between https://bitbucket.org/multicoreware/x265 and https://bitbucket.org/multicoreware/x265_git doesn't work properly
Tools for StaxRip | x264 - x265
Patman is offline   Reply With Quote
Old 2nd May 2020, 21:46   #7583  |  Link
filler56789
SuperVirus
Thanks!
And probably the x265 devs themselves are not very fond of git...
Old 2nd May 2020, 21:57   #7584  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
If the ywant to continue to use Bitbucket, they'll have to migrate to Git tough:
https://hub.packtpub.com/bitbucket-t...t-by-may-2020/
Old 3rd May 2020, 08:23   #7585  |  Link
almanteka
I use the git source (not hg source) and there the build number is a bit different. Download x265-3.3+22-gde09ab80e build, it's the same.
thanks!
almanteka is offline   Reply With Quote
Old 4th May 2020, 04:37   #7586  |  Link
stax76
stax76's Avatar
Sorry to repost, MediaInfo.NET supports a special presentation for x265 parameters, it can be enabled in the settings.
Meanwhile, it was ported to run on .NET Framework 4.8 (so people don't need to install .NET Core) and it has a PowerShell based folder view.
https://github.com/stax76/MediaInfo.NET
https://forum.doom9.org/showthread.php?t=176886
Old 5th May 2020, 03:23   #7587  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Hey that's really neat! Thanks for adding this ^
Old 5th May 2020, 13:52   #7588  |  Link
filler56789
SuperVirus
x265.exe 3.3+26-193db49
http://msystem.waw.pl/x265/
Fix bug in frame-dup + multi pass
Add save-load regression test CLI for Frame Duplication
Old 5th May 2020, 21:06   #7589  |  Link
Patman
Patman's Avatar
Updated to version x265-3.3+25-ga6489d2fb (git source). See my sig
Old 6th May 2020, 10:22   #7590  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Well seem don't change anything. I make test for benwaggoner encoding challenge and I must make 3 pass to have good rate control. 2 pass encoding have too agressive quantizer curve compression at the start of encoding.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
Old 6th May 2020, 12:11   #7591  |  Link
tuanden0
Thank for your build
tuanden0 is offline   Reply With Quote
Old 7th May 2020, 16:31   #7592  |  Link
filler56789
SuperVirus
x265.exe 3.3+29-1e3dbf0
--- Cleanup
--- save-load-tests: Fix CLI
--- EQT Updates.
1. Improves documentation in help and x265readthedocs for rskip cli options.
2. Renamed rskip variable in x265_param structure & rectified regression clis.
3. Removed rskip mode 3 which is same as mode 2 with min-cu-size 16.
Old 8th May 2020, 00:40   #7593  |  Link
Patman
Patman's Avatar
Updated (git source):
x265-3.3+4-g6a7df3229-* (marked as 3.4 branch, but the version shows 3.3+4 / maybe stable) [* built with msvc1925 and gcc11.0.0]
x265-3.3+27-g4780a8d99-* (master branch) [* built with msvc1925 and gcc11.0.0]
Downloadlink, see my sig
Old 10th May 2020, 10:58   #7594  |  Link
RainyDog
Thanks for your builds as always
Is there a reason why they no longer support raw .avs (no piping) input?
RainyDog is offline   Reply With Quote
Old 10th May 2020, 14:00   #7595  |  Link
Patman
Patman's Avatar
You're welcome. My builds have never supported direct avs input. Maybe I will add avs input support in future releases.
Old 10th May 2020, 14:05   #7596  |  Link
stax76
stax76's Avatar
Are there builds that support both avs and vpy? libavformat supports both, that's how mpv opens avs and vpy, but does not support portable mode, blocks DLL loading from path env var.
Old 10th May 2020, 14:58   #7597  |  Link
RainyDog
Hmm, I was sure there was a point last year when I had the piping tool option set to none in StaxRip across the board. Unless it was just with my x264 set-up...
In any case, be good if you can make your x265 builds work with raw input too. Thanks
Old 10th May 2020, 16:41   #7598  |  Link
Patman
Patman's Avatar
Yeah, x264 support that. I do my best and give you a feedback
Old 10th May 2020, 18:56   #7599  |  Link
RainyDog
I've now remembered how I was previously using raw input with x265... It was when Stax was using Wolfberry's builds. So seems it is possible to implement at least, unless something's changed with x265 itself since then.
I'll leave it in your capable hands anyway
Old 11th May 2020, 22:28   #7600  |  Link
MeteorRain
結城有紀
Direct AVS input was there for a while. x265 official denied my attempt to enhance the I/O part, so I have been keeping all patches out of the tree.
No one wrote direct VPY input so far.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
