4th January 2022, 10:13 | #31081 | Link |
Life's clearer in 4K UHD
And what will be in this second video file?
4th January 2022, 21:10 | #31082 | Link | |
Sometimes "Just because I can." is the fun of it.
4th January 2022, 21:46 | #31083 | Link | |
That being said, in days gone by when I had loads of .iso movie files stored on my NAS, if I wanted to see a movie poster image, I'd simply create a .jpeg file and name it exactly the same as the .iso movie
4th January 2022, 22:48 | #31084 | Link |
"Movie poster menu image"? I didn't comment on that before but I considered that to be an odd description. Also, "Yuletide - 2019" isn't a movie you may buy. I made a recording for my Son during Yuletide and that's what I named it in the menu...with the default background. On the Disc, I wrote, "This is what Christians plagerise as 'Christmas'." which he really enjoyed. So, 2 different notes. BD-RB isn't just for making personal backups of bought discs. It's sweet to know there are different ways to implement ideas.
I have .jpg files for some movies also.
4th January 2022, 23:08 | #31085 | Link |
Well I'm totally confused now.
Either way, I'm of the opinion that whatever/whichever way @MrVideo is going about backing up his 'single video' discs. He's making life very difficult for himself - and I suspect others...
5th January 2022, 01:43 | #31086 | Link |
Life is not more difficult. If one just burns a video file, or files, onto a BD-ROM, not all BD players will honor any chapter marks. If you use tsMuxer to create a BD/UHD format for you, when said video is finished, it does not stop, it repeats. Also, you can only put one file onto a disc with tsMuxer. With BDRB, your can have as many files on the disc that will fit within the available space. You can have a nice looking menu. If only one file on the disc, it will return to the menu when done. Plus, chapter marks will always work.
Again, Because I Can! |
5th January 2022, 01:45 | #31087 | Link | |
Thank you for the application. It's definitely a welcome addition to the toolbox. |
5th January 2022, 10:14 | #31088 | Link | |
With regard to the newer 'open source' builds of TSmuxer GUI, I haven't had any problems creating single movie muxes with chapters. They all play on my OPPO perfectly. Even the ones with Dolby Vision.
5th January 2022, 11:06 | #31089 | Link |
I think I need to rephrase that. tsMuxer does indeed create files with chapters. The problem is the Blu-ray players ignore the skip button when the video is played as a file. I do not have any Oppo players. Do a BD format and all is well.
6th January 2022, 23:18 | #31091 | Link |
Sorry, a "file" in this case needs to be a MKV file. The M2TS file can keep subtitles, while a TS file can't. So, with a M2TS file and a chapter list file, I can build a MKV file with chapter marks. I need to be more specific.
7th January 2022, 00:59 | #31092 | Link | |
AUDIO_VOLUME=1.5 In this case the audio would be increased by 50% I tried testing the option to normalize -- but it slowed the encode down to 1/6th it's regular speed. |
7th January 2022, 11:09 | #31093 | Link |
Big Bit Savings Now !
As a sound engineer I guess blind multiplying might lead to users complaining about resulting clipping they didn't foresee.
Normalizing is safe and would be my way to go, users of any sane processing should have to accept that well-spent time for parsing all audio. What about making that a user's choice ?
7th January 2022, 13:12 | #31094 | Link |
Trying to reencode an UHD BD and I get an error during the CQM prediction. I looked into WORKFILES and saw the sample.m2ts is 0kb. So I executed the sample.bat, which I assume creates that sample video and this is the output
U:\BD-Output\WORKFILES>sample.bat U:\BD-Output\WORKFILES>"U:\BD_Rebuilder\tools\ffmpeg.exe" -ss 5414.0814 -i "V:\FULLDISC\RESIDENT_EVIL_4_UHD\BDMV\STREAM\00004.m2ts" -frames 48 -an -sn -codec copy -f mpegts - 1>>"U:\BD-OUTPUT\WORKFILES\00004.AVS.SMPL.m2ts" ffmpeg version 3.4 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.2.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 [mpegts @ 00000208a9356600] start time for stream 5 is not set in estimate_timings_from_pts [mpegts @ 00000208a9356600] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options [NULL @ 00000208aabf38e0] missing picture in access unit Last message repeated 1 times Input #0, mpegts, from 'V:\FULLDISC\RESIDENT_EVIL_4_UHD\BDMV\STREAM\00004.m2ts': Duration: 01:36:50.82, start: 600.000000, bitrate: 76142 kb/s Program 1 Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc Stream #0:1[0x1100]: Audio: dts (DTS-HD HRA) ([133][0][0][0] / 0x0085), 48000 Hz, 5.1(side), fltp Stream #0:2[0x1101]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 224 kb/s Stream #0:3[0x1102]: Audio: dts (DTS-HD HRA) ([133][0][0][0] / 0x0085), 48000 Hz, 5.1(side), fltp Stream #0:4[0x1103]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 224 kb/s Stream #0:5[0x12a0]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090) Output #0, mpegts, to 'pipe:': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 90k tbn, 90k tbc Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [mpegts @ 00000208ad5288c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [mpegts @ 00000208ad5288c0] first pts value must be set av_interleaved_write_frame(): Invalid data found when processing input frame= 1 fps=0.0 q=-1.0 Lsize= 0kB time=-00:00:00.12 bitrate= -0.0kbits/s speed=N/A video:257kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Conversion failed! Last edited by jdobbs; 7th January 2022 at 14:02. |
7th January 2022, 14:34 | #31095 | Link | |
What I'll probably do is have NVENCCRE look for ffmpeg.exe in the tools folder, and enable normalization if it is present. Last edited by jdobbs; 7th January 2022 at 14:58. |
7th January 2022, 19:00 | #31096 | Link | |
Personally, I can live without normalization. Fine control is what I'm looking for. By your example would using a lower or higher number allow more fine control? So say 1.1 would be 10%, 1.8 = 80%, etc? Or is it going to be limited to 50% increments? I don't know how much work for you that this entails. This is just something I would find extremely useful if it's doable without being a massive PITA. Edit: I previously mentioned an increased in decibels. I was mistaken. Normally when doing some conversions I need to add a gain of roughly 8. I erroneously said decibels. Last edited by DrinkLyeAndDie; 7th January 2022 at 19:55. |
7th January 2022, 23:50 | #31097 | Link | |
I've also added a menu item that will do normalization. It requires ffmpeg.exe in the tools folder (otherwise it is disabled). So if you put NVENCCRE.EXE in the BD-RB folder, it should work just fine. Normalization is the best way to increase volume -- as it uses the existing audio's volume and increases only to the point that can be reached without clipping. Last edited by jdobbs; 8th January 2022 at 00:26. |
8th January 2022, 02:43 | #31098 | Link |
For those who are interested, I've posted a new version of NVENCCRE. There is now an audio menu item called "Audio Normalization". There is also a hidden option called AUDIO_VOLUME in which you can set a multiplier to be applied against the audio. If normalization is selected, the AUDIO_VOLUME option is ignored. Normalization requires the FFMPEG.EXE exists in the tools folder (as it is in the BD-RB tools folder).
Note: Using normalization is much preferred over setting an arbitrary volume multiplier. It will set the maximum volume increase available that will not result in audio clipping. Last edited by jdobbs; 8th January 2022 at 02:46. |
8th January 2022, 04:09 | #31099 | Link | |
8th January 2022, 07:04 | #31100 | Link |
While I personally will never screw with the original audio level, but for those that do, isn't there some small print regarding adjusting E-AC3, TrueHD, DTS-MA, DTS-X? Won't screwing with anything other than DTS/AC3 result in the loss of the lossless audio and/or Atmos?
