10th December 2012, 01:06 | #2722 | Link |
It should not be necessary to actually install the AppleApplicationSupport.msi.
I've created a script to extract the necessary files for qaac from e.g. the QuickTimeInstaller.exe: http://www.mediafire.com/?1ysj4ph04vt3b8g Please report in case I have missed a file. I have only tested it with QuickTimeInstaller.exe and done one quick encode. Last edited by sneaker_ger; 10th December 2012 at 01:27. |
10th December 2012, 04:26 | #2723 | Link |
Anime addict
Hi, megui detect qaac as installed but profiles doesnt showed. But I can export profiles with qaac. What do I wrong??
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
10th December 2012, 04:35 | #2724 | Link |
I seem to have a problem file. I was indexing an old MPG file which was a TS recorded with an OTA card, with the commercials edited out. Indexing with DGIndex crashes. Indexing with FFMSIndex generates an error that Audio changes modes (presumably because of residual commercial information.)
I've searched around, but I haven't found how I can fix this. Any hints? |
10th December 2012, 10:48 | #2726 | Link |
After clicking the checkbox "Enable QAAC" in the "External Program Configuration" tab of the "Settings" dialog, you'll get the message:
--------------------------- Restart required --------------------------- You have to restart MeGUI in order to get access to the QAAC profiles! --------------------------- OK --------------------------- |
10th December 2012, 11:23 | #2728 | Link |
I had to restart twice to get the profile, this was how it worked with me:
Tick the QAAC box in settings. Restart MeGUI Prompted to update and download QAAC Profile not in drop down Restart MeGUI Profile now in drop down Is it possible to prompt for a restart from the updater if downloading QAAC for the first time? |
10th December 2012, 12:09 | #2729 | Link | |
Anime addict
EDIT: Already show it. Thanks
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 10th December 2012 at 13:16. |
10th December 2012, 18:23 | #2730 | Link |
I have a lot of avi files that have ac3 audio in them and now I have to use VirtualDubMod to extract the audio. Would it be possible to add support for extracting ac3 audio from an avi container or to add support for muxing ac3 audio in a avi container into a mkv container?
14th December 2012, 09:18 | #2732 | Link |
Since "Target Playback Device" is replacing x264 presets, any chance we could get some more devices listed? Would very much like to see BD5 and BD9 get added.
Also it looks like some of the profiles could benefit from separate 720p vs 1080p settings. Last edited by DoctorM; 14th December 2012 at 09:20. |
14th December 2012, 12:56 | #2733 | Link | |
1) Open your avi in upper window. 2) Select the avi and click over 'Generate data source from files' 3) Select the audio track to extract and right-click -> 'extract binary' There are a important difference between audio tracks extracted with AVIMux_GUI and VirtualDubMod when the audio track have a fake delay in avi container. The VirtualDubMod extracted files have garbage (normally bytes '0') at the begining of the file, before the first valid header, to emulate the delay. AviMuxGUI remove this garbage. The VirtualDubMod extracted files with garbage can be rejected by MkvMerge or stored without the garbage and you lose the delay. When you select the audio track in point 3), AviMuxGUI show the delay than you need add to the extracted track when you mux with MkvMerge.
21st December 2012, 16:59 | #2736 | Link |
2236 [Log] renamed Haali Muxer to Haali Splitter and fixed a problem displaying the warning icon in Windows 7/8 2235 [AviSynth Script Creator] fixed "Suggest Resolution (mod16)" handling added option to select 2/4/8 as mod values for "Suggest Resolution" Last edited by Zathor; 21st December 2012 at 17:12. |
22nd December 2012, 00:20 | #2738 | Link | |
22nd December 2012, 01:10 | #2739 | Link | |
I cannot reproduce that. Please provide more details. Additionally please upload the file joblist.xml and the folder jobs (saved after closing MeGUI and a second copy a while later when MeGUI is running and not showing the job status window) |
22nd December 2012, 01:28 | #2740 | Link | |
You will see that clicking on the 2nd status window does nothing. The 'tick' does not go on and off like the first status window. (It is not on another screen somewhere). Does this just pertain only to my computer? Last edited by Wam7; 22nd December 2012 at 01:33. |
