Old 3rd March 2010, 14:47   #41  |  Link
Selur
Selur's Avatar
Hybrid ver. 100303
*added*
- 'Check average fps of mkv files' under Misc->Handling:
this will grab the time codes of incomming mkv files an adjust the frame rate according to the average frame rate calculated from the time codes.
*fixed*
- Linux mkfifo handling by removing it
*changed*
- removed all mkfifo dependencies
(you need to enable Misc in the Main-Tab to enable the Misc-Tab)
Reset Defaults in Misc-Tab on first start
-> updated links in 1st post
Old 3rd March 2010, 15:51   #42  |  Link
Riki
Im trying to encode to Baseline and its not working. Is there anything special that I need to do in order to do this?
I change the Profile to Base and the Level to 3.1 but it still outputs High/3.1
Riki is offline   Reply With Quote
Old 3rd March 2010, 15:53   #43  |  Link
Selur
Selur's Avatar
probably a small typo, brb
Old 3rd March 2010, 16:06   #44  |  Link
Riki
Thanks! I liked in sx264 when it would deactivate features when switching to baseline.
Old 3rd March 2010, 16:06   #45  |  Link
Selur
Selur's Avatar
-> redownload latest build, should be fixed now (removed it for some testing and forgot to reinsert it )
I'll recheck on that, don't know atm why this is not happening.
Old 3rd March 2010, 17:22   #46  |  Link
Riki
Thanks, because currently the encode crashes for me because I probably have non-baseline features defined. I tried disabling CABAC and B-Frames but its still crashing.
Old 3rd March 2010, 18:18   #47  |  Link
Selur
Selur's Avatar
did a silent update on the download links
Old 3rd March 2010, 18:19   #48  |  Link
Riki
Thanks Selur, fixed!!
Old 4th March 2010, 01:54   #49  |  Link
Alex_080
User of X264
Thanks Selur ur new Hybrid version works perfectly with dual audio files and it work nicely
Alex_080 is offline   Reply With Quote
Old 4th March 2010, 07:04   #50  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
anybody using JoshyD AviSynth x64 Build's with Hybrid?
MuLTiTaSK is offline   Reply With Quote
Old 4th March 2010, 17:18   #51  |  Link
Selur
Selur's Avatar
No sure if 64bit Avisynth would cause a problem for avsInfo and mplayer/mencoder,.. so if you try please report.
Cu Selur
Ps.: btw. where are current megui profiles located at? (haven't updated the megui profile import function for ages )
Old 4th March 2010, 17:37   #52  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
http://megui.org/auto/x264_presets_v33.zip
Old 4th March 2010, 17:37   #53  |  Link
Selur
Selur's Avatar
(ugly,.. seems like all 'new' thinks just show up in the custom command line,..)
Old 4th March 2010, 18:36   #55  |  Link
Selur
Selur's Avatar
"64bit capable?" No clue, needs to be tried out. (got no 64bit Avisynth running here )
(Source code: http://stashbox.org/812403/avsInfoSource.zip)
MediaInfo: http://sourceforge.net/projects/mediainfo/files/binary/ (don't take the gui, but the command line version)
don't think there are 64bit versions of the other tools and it's mainly ffmpeg, mencoder, mplayer and x264 that would (potentially) promise a speed gain when going for 64bit
Cu Selur
Old 4th March 2010, 19:45   #56  |  Link
Selur
Selur's Avatar
Hybrid ver.100304
*fixed*
- interlaced detection
- typo: vob -> VOB (was a problem for Linux DVD analysis)
*changed*
- use absolute paths in analyzers
Old 4th March 2010, 22:38   #57  |  Link
Selur
Selur's Avatar
Here's a 32bit Windows build with experimental MeGui-Profile-Import: - removed - (x264->Misc->Import)
Too groggy to test if this causes any problems so would be nice if someone could check if the profiles are imported correctly.
Cu Selur
Old 6th March 2010, 06:19   #58  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
--mbtree gets disabled and --slices are added for most MeGUI profiles
Old 6th March 2010, 08:54   #59  |  Link
Selur
Selur's Avatar
since most of them have <NoMBTree>true</NoMBTree> and <SlicesNb>0</SlicesNb> this should be right
Old 6th March 2010, 16:32   #60  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
Slices are only enabled in the Bluray profiles mbtree is enabled in most profiles
Hybrid adds --slices 4 --no-mbtree to all imported profiles
